Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Motor problem hi i have question about my husqvarna lawn tractor 48``. I bought the tractor like month ago and it was working fine but today i cut the grass for the firs time and after maybe hour the motor stop workin properly was making noise like up and down did not go smooth
  • Anonymous Apr 21, 2009
    mine did the same thing i returned it to lowes they replaced it i haven't tried the new one yet
  • 246 Answers
Hello bartekzag:
From your Description it Sounds like Water in the Gas, Valve Clearances Require Setting or the carburetor Solenoid Requires Replacing.
>>If this is a New Mower and Under Warranty, then Return the Unit to the Dealer.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
How do you lock differential?
The locking is automatic:
Husqvarna riding lawn mowers, lawn tractors, garden tractors
www.husqvarna.com/us/products/riding-lawn-mowers/
Husqvarna GroupThe available, electronic or automatic locking rear differential increases ... forHusqvarna lawn and garden tractors, you are ready for every season. ... Why use your ride-on mower only for lawn mowing, when it has the capability to do so much more. ...Kawasaki V-Twin engine; Fast hydrostatic transmission; Cruise control ...
Husqvarna Riding Lawn Mowers YT48XLS CARB
www.husqvarna.com/us/products/.../960430205/
Husqvarna GroupBy using this site, you agree to our use of cookies. Learn more. Got it. Close .... Wedeveloped our LS series yard tractors with the discriminating landowner in mind. Engineered for added ... Automatic locking rear differential increases traction while cutting wet grass or on slopes. ..... WORKING FAST WHILE STAYING SAFE.
Husqvarna Riding Lawn Mowers GT54LS
Dec 06, 2015 | Husqvarna Fast Tractor YTH24V48 48" 24HP...
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut hydrostatic transmission slipping
first i would check the belt tension also check the belt for oil is so look for the cause of the leak the repair the leak and replace the belt
Jul 30, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Husqvarna 48" deck how to test charge system
use a volt meter test the voltage when the engine is off then start it up and see if the voltage goes up it works
Jun 28, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I bought the 23 HP 48" Husqvarna tractor after I cut my lawn the first time it would not start by itself. It is always dead and I have to jump it. It is only a month old. I take the key out of the ignition...
Try removing the battery after the next cut and have it tested. If it test good leave it out. If it keeps it's charge you have a draw on the battery. The simple fix is to install a switch on the negative side of the battery. If it drains out of the unit you have a bad battery.
Thanks for choosing Fix ya
May 25, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna YTH1848XP Riding Mover stalls with throttle increase.
Check your Vacuum line going into the back of your air intake box.
Jul 06, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
I have a 2005 husqvarna lawn tractor. 24 hp, 48 in deck, the transmission runs fine on level ground but when i go to an incline the tranny slips and i hear a clunking sound, and if i travel farther up hill...
sorry. I don't have an ansewer for you however I might have some helpful hints. Your mower should be going dam near 5 MPH. But yes can't cut in reverse. you have a belt going from the trans axle to the motor. It could be slapping against the frame. The idler puller or the tension pulley could be wobaly where the bearings are gone out. If you remove the 4 bolts on the back of the mower under the seat and gas tank it should visable tell you the story. My question is mine hits gears real hard as if trans mission needs oil or internal damage.
May 09, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My Husqvarna lawn tractor started smoking terrible about half way through cutting the grass today. Oil dripped out of the muffler. What is that a sign of? Have I blown the engine? I check tires and oil...
You mean Briggs and Stratton. Sounds potentially expensive. Call a local small engine repair shop. They'll tell you how much it will cost. A new engine might be $1k. Repairs a few hundred.
May 08, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
209 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
