Question about Kenmore 24 in. 16222 Built-in Dishwasher
Dishwasher lime/scale build-up
Do they make a product that will thoroughly clean-out scale build-up, is so info please. Thanks!
  • 318 Answers
Most d/w's in the USA do not have a salt dispenser to soften the water. what will work to remove the scale and soap residues is called "d/w magic". it comes in a plastic square bottle and you can get it at any grocery store, lowes, or sears.
you just remove the cap, put in the top rack and run a full cycle with the water heat boost option and it will clean out almost any residue from your unit. if it is really bad you may need to repeat this 2 times.
then in the future use dry powder soap, not tablets, fill both cups only about half full, use the normal cycle with the water heat option. also make sure the rinse dispenser is full with jet dry or similar product. then you should not get the residues returning.
Posted on Dec 31, 2008
  • 209 Answers
This sounds like your dishwasher has ran out of salt (not the kind you have on the table)this and "rinse aid" is all that is needed, and these are used anyway, mine goes cloudy if the salt runs out, always check washing blades spin freely anyway, hope i have helped, if so rate me please
Posted on Sep 18, 2007
6ya staff
SOURCE:
How do I clean the residue from.the bottom of whirlpool dishwasher 10431031a
Use a dishwasher cleaning product and run the normal cycle without dishes or dishwasher tablets/powder. The dishwasher cleaning product will get in and around all of the pipework especially behind the scenes and breakdown the grease and lime scale build up. Depending on how often your dishwasher is used, you may have to repeat this every two weeks or once a month.
Hope this helps
Sep 25, 2014 | Dishwashers
Whirlpool dishwasher model GU2275XTVQ1 cleans poorly on top only
Check your hose, pump and all water lines for lime scale build up. Sometimes if you dont use some kind of lime away product every few months your machine will/can get lime scale build up from hard water causing it to not properly dispense the water through out your machine. You can also try to run a load with no dishes and no soap but put just lime away in your machine. It might just clear any clogs you might have or starting to get.
Jan 27, 2013 | Whirlpool Gold GU2275XTVy Dishwasher
I would like to clean off the calcium deposits that are in the dishwasher. How can I do this or what product should I use.
there are few things you can do to remove the calcium deposits.....
Change the detergent you use. Powdered dishwasher detergent is more efficient in removing grease and oil than gels. Decreasing the gunk left on surfaces may help slow lime scale buildup.
Put a quart of vinegar or lemon juice in the bottom of an empty dishwasher and run it up to the "dry" cycle once a month to keep up with accumulating scale. Extended exposure to mild acid and hot water dissolves most scale.
Clean circulator arms with vinegar or lemon juice and a vegetable brush or toothbrush. Let the acid sit on the scale before scrubbing. Use a needle or hat pin to pierce clogged holes, then rinse by running a cycle with vinegar.
Use plain salt or baking soda to scour surfaces with a sponge or rag. Rinse with boiling water or run a cycle with an empty dishwasher. Do not run the dry cycle.
  • 2 Put a quart of vinegar or lemon juice in the bottom of an empty dishwasher and run it up to the "dry" cycle once a month to keep up with accumulating scale. Extended exposure to mild acid and hot water dissolves most scale.
  • 3 Clean circulator arms with vinegar or lemon juice and a vegetable brush or toothbrush. Let the acid sit on the scale before scrubbing. Use a needle or hat pin to pierce clogged holes, then rinse by running a cycle with vinegar.
  • 4 Use plain salt or baking soda to scour surfaces with a sponge or rag. Rinse with boiling water or run a cycle with an empty dishwasher. Do not run the dry cycle.
  • Read more: How to Remove Lime Deposits in Dishwashers | eHow.com http://www.ehow.com/how_5611602_remove-lime-deposits-dishwashers.html#ixzz0wtABvYq2
    Aug 17, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
    Have a whirlpool GU2400XTPT1 undercounter dishwasher for the past 5 years. Has worked perfectly until a few weeks ago the glasses and such on the top rack haven't been coming completely clean. Everything...
    have you change you dish soap -to a phosphours free agent there has been rumor that these new cleaner will leave residue on glass.you can alos make sure the the dishwasher is clean after time they can build up lime and scale,calcium you can use any kind od dishwasher cleaner this may help
    Jun 10, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
    Whte residue left on glassware and dishes
    use a dishwashing cleaning agent in the machine. or some thing the has a grease cutting agent.run this on an empty cycle.
    there are times residue grease and oils can accumulate down in the sump area where the water sits and can cause film on the dishes.
    this could also be some lime or scale build up for that you can use some C.L.R or any kind of lime and scale remover to clean your machine.
    make sure tht that this is done on an empty dishwasher
    May 19, 2010 | KitchenAid 24 in. KUDS02FRSS Stainless...
    Not cleaning well
    the bottom spray arm just pulls up how ever you need to try and put some lime away in the dishwasher and run an empty cycle for a while.this may need to be done two to three times.
    there are also products that can be purchsed from you local home improvement store or parts store that can assist with the removal of lime and scale build y up.once you start the dishwasher with what ever kind of scale remover there is let it run for about 10 to 15 minutes then shut it off for the same amount of time and then restart and let finish the cycle
    Apr 01, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
    My heating element has white scale and build up on it
    Hello, You should buy some lime away from home depot ot Lowe's. Put 2 cups inside the dishwasher and run a pots and pans cycle. This should clear up the calcium deposit on the heater. You may have to repeat depending on how bad the build up is. Hope this helps. Mike
    Nov 23, 2009 | Dishwashers
    Can hard water be used i n front loading washing machine
    Hi.
    No prob, but it would be adviseable to use a product called CALGON, it is a water softning powder, and will prevent build up of lime scale in washer due to hard water.
    Please rate my solution.
    Thanks.
    Oct 23, 2009 | Whirlpool Washing Machines
    Preventive maintenance?
    You should buy some c.l.r. (calcium,lime,rust) remover.It's packaged in a grey bottle at any supermarket,drug store,ect.Pour a cup in and run a cycle once a month.This will prevent any lime build up from scaling the dishwasher due to hard water.
    Mar 19, 2009 | Dishwashers
    Clogged water dispenser in Bosch dishwasher
    Hi, Logmanup (slight bouts with dyslexia, sorry)
    By "spinning water dispensers", I assume you mean the spray arms, right? OK... if they are getting clogged with debris it would be nice to know what kind of debris. Pieces of broken glass? Plastic? Lime scale? Iron? And yes, when they get clogged they won't rotate, won't allow pressurized water through and therefore won't clean the dishes.
    For the purpose of this solution, I'll assume that there are little white particles clogging up the jets on the spray arms. This indicates hard water and lime scale build up.
    Other than completely disassembling the entire motor/pump assy. (you really don't want to go there), the best way to clear this out of the system is to use an over the counter chemical called Dishwasher Magic or something similar. If the lime scale build up is really bad (and it sounds like it is), use a couple of bottles to start with and follow up with a bottle per month thereafter.
    As an aside... If I assumed correctly about the lime scale build up, that means that it's also affecting other appliances as well. Mainly, your hot water heater. If you haven't done it before, please read this to perform maintenance on it. And a product something like this for your washing machine.
    I hope this was helpful. Let us know if this works or not. If not, please write back and we'll go a little deeper.
    Mar 12, 2009 | Bosch Dishwashers
    Kenmore 24 in. 16222 Built-in Dishwasher Logo
    1,562 people viewed this question
    Top Kenmore Dishwashers Experts
    Fred Sops
    vince
    D. E. Hev
    Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
