Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Need valve adjustment for a for a briggs and straton 31p777-0348-
Had to replace a bent pushrod, having trouble getting it to start, need to adjust valves
  • kenjenchloe Apr 25, 2009
    What is a good setting for both intake and exhaust valve clearance? I have a B/S 23 H.P. OHV.
  • 15 Answers
Try .003-.005 on the intake, .005-.007 on the exhaust.
Posted on Apr 23, 2009
I HAVE A 24 HORSE Poulan riding lawnmower pro that keeps bending the rods and it has no power. I was wondering if this could be a timing problem.
It a design problem. Where you adjust valves it happen. You need correct valve adjusted, check valve seats they can move. I've had mine 17 years. One problem, adjusted one valve to tighen. Bent a pushrod
Feb 25, 2016 | Poulan Garden
What causes push rods to bend on left bank of a 20 HP V- Twin
Here's some generic answers, not relating to this engine specifically:
  • The timing could be off, so the piston is hitting the valve.
  • A loose pin in the piston could be allowing it to extend too far, shoving on the valve.
  • I guess the valves could need to be adjusted so there's a gap.
Jun 02, 2015 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and straton 5 horsepower overhead valve lawnmower 1978 is backfiring through carborator
Remove the top engine cover and check that the aluminum flywheel key is not sheared, then remove the valve cover and ADJUST the 2 overhead valves. They have to be adjusted periodically on ALL small engines with overhead valves.
Aug 13, 2011 | Garden
Briggs straton ohv on tiller , govener will not work, runs at high speed all the time, starter rope has become extremely hard to pull, will not spin engine.
The hard to pull, will not spin the engine issue could be because you need a valve adjustment. A valve adjustment is critical because it enables the built-in compression release on the Briggs OHV engine to function correctly and enable an easy start; plus of course, smoother running. Remove the valve cover and adjust those valves at 1/4" down past TDC on the power stroke. You WILL see a difference in the engine once you do the adjustment.. Here is a Briggs spec chart which has those values for their engines. Yours should be listed in the OHV engine section.
http://www.briggsandstratton.com/engines/support/frequently-asked-questions/~/media/71BB9DA0BD4D4C19A0DA611923A0B80A.ashx
Here is the Briggs recommended tutorial on HOW to adjust those valves. Scroll down this page to "Adjusting Overhead Valves"
http://www.briggsandstratton.com/engines/support/frequently-asked-questions/Servicing%20the%20valves/
May 22, 2011 | Garden
Valve adjustment
To adjust the valves on your Ironhead, the engine must be stone cold. You want to adjust the tappets so that you have zero backlash on the cold engine. As the engine heats up, the cylinder and heads expand upward creating valve lash in the valve train. This is why you want zero lash with the engine cold. If you get the valves set too tightly, it'll hold a valve open ever so slightly and make starting difficult.
To adjust the valves, bring one piston to TDC on the compression stroke, both valves closed with tappets in their lowest position. Pop the pushrod covers loose and loosen the lock nut on one of the tappets. Adjust the top part of the adjuster outwards until the pushrod can no longer be turned with your fingers. Turn the lock nut down but don't lock it yet. Gradually turn the top adjuster downward until you can spin the pushrod with your finger and finish locking the lock nut. Recheck the pushrod to see if it still spins but has no up and down movement. Do the same with the other pushrod on that cylinder. Remember, if's better to get the pushrods adjusted slightly loose rather than slightly tight. It might rattle a bit more but it'll start easier as well. Put the pushrod tubes back together and then do the same thing with the other cylinder.
May 21, 2011 | 1979 Harley Davidson XLH 1000 Sportster
I'm replacing bent valves in my head on my 2000 hyundai Sonata. Is there an adjustment for valve lash?
its always best to get a book with the specs because almost every engine has lash adjustment. allthough not alway just adjustable. what i meen is that some engines, fords did it , u have to change the pushrod. on overhead cam engines u had to change lifters theres a lot of ways to do it but u should probly get the specs.
Nov 18, 2010 | 2000 Hyundai Sonata
Craftsman 16 HP Electric start 41" mower - on a overhead valve briggs and stratton two stroke engine the hollow push rod bent. We pulled the head and everything seemed in working order. The replacement...
On any pushrod engine you have to make sure that the timing is correct or nearly correct when first firing it up, if you had the cam in the wrong position the pushrod had no place to go when the cam lobe came around=bend push rod.
Sep 24, 2010 | Garden
I have crafsman 48" riding mower with a 24 hp intek motor
Bent push rods are a function of the valve guide coming loose in the head. The valve binds and you end up with a bent pushrod. Fix: Replace head. $94.00
Jul 13, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
4,960 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
