Question about Samsung Refrigerators
Model RS26ZUSH ice making making machines is not
Model RS26ZUSH
Ice is done in tray, but it doesnt turn to throun them to ice box. water supplie and temperature are ok
We had the same problem.
We sprayed Pam cooking spray in the tray and wiped it gently. Worked like a charm!
Posted on Oct 07, 2009
Ice maker not getting water on new refrigerator
Check if the unit has a cold water dispenser that it will fill a cup. If so than problem is with Ice Maker. If not than problem is with water supply to unit.
If water to machine works make sure that the arm on the ice maker is in the down position. If it is up it will disable the ice making unit. Cycle the am a few times to insure that the switch connected to the arm has not gotten stuck in the off position.
On some ice makers there is a separate switch to disable the Ice maker usually right on the ice-maker not easily missed.
It is possible that the water feed tube into the Ice Maker has become frozen where it enters into the back of the freezer at the top. You can look through to see where the water fills into the cube tray. If ice is present it would be an indication that the feed tube has become frozen If suspected the safest way to fix would be to turn off the unit and allow for a manual defrost.
Next check the operation of the ice maker. Locate the arm in the up position prohibiting the ice maker from cycling. Wait three hours or more. Open freezer door and return the arm into the down position. After a few minutes you should observe the ice fingers rotating to release the cubes into the tray. If the fingers do not rotate I would suspect the ice maker or the connecting electrical circuit. Remember after dropping the arm the Ice Maker has to warm up to melt the ice cubes from the tray before the fingers are told to rotate,
If the fingers rotate then I would expect that the water supply solenoid has failed inside of the unit near to the location the the water supply is made. Replacing this part needs to be done by a qualified experienced technician.
Nov 15, 2015 | Refrigerators
Scottsman SCE170A-1B how can i have to make ice faster
The only way to make ice faster for this machine is done with cooler ambient room temperature and colder water temperature from supply water before it reaches water sump tray.
Jun 06, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
The ice maker
see this causes and fix it. God bless you
Makes to much ice or won't shut off.
Check shutoff arm. This may be hung up on ice or food item.
Makes no ice.
Check shutoff arm. Check to make sure it is getting water, check water solenoid. Check water supply line it may be frozen or plugged up. Check freezer temperature to low of a temperature could cause the line to freeze up. Check for power at motor. You will need to remove the ice maker. Find the leads that go to the auger and connect a voltmeter. Press the dispenser lever you should have power if not replace the control board or micro switch. Check control switch or microswitch. Put icemaker in test mode. Only some are equipped.
Ice cubes to large or small.
Adjust size by removing cover and turn adjustment screw + or -. Check water solenoid. Check water supply line. Make sure it is level.
Ice tastes bad
Clean ice tray. Check supply line. Check water solenoid. Change filter. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Ice is discolored.
Check water solenoid. Check supply line. Change filter. Clean ice tray. Run at least a 3 gallons of water thru the line after replacing filter this will flush all old water.
Most ice maker problems require either replacing the ice maker unit or the ice dispenser control board or micro switches.
Sep 28, 2012 | Washing Machines
My ice maker doesn't work. Where do I start? Model number 561
HI.FIRST MAKE SURE U HAVE TURNED IT ON.SWITCH OR LEAVER.2- WATER ON 3-WATER IN ICE TRAY.4 IF EMPTY PUT SOME ON MANUALY.AND TRY.IF IT WORKS ONCE AND STOPS THEN U HAVE A WATER SUPPLY PROBLEM.CHECK PIPE;WATER VALVE.IF ALL OK THENNNN...ICE MACHINE?HOPE THIS HELPS.ALI
Jun 30, 2012 | Sub-Zero Refrigerators
Danby ice maker service manual
I took mine apart today and found the plastic armature that the motor connects to in order to turn the water tray right side up and up-side down was broken. Essentually the water tray has a plastic pivot arm on both sides. The one side has a slot that the motor fits into which allows the motor to turn the tray. When that little plastic arm breaks, the motor will be unable to move the tray thus causing the fault symbol. I have my tray out and trying to fabricate a part that will hopefully last a lot longer than the original. I hope this helps someone with their issue.
May 16, 2012 | Refrigerators
My ice machine model f-450 mah makes ice but once it's full the water keeps running and runs out of the machine how do I fix this?
Make sure the plug in the water tray is secure and not allowing water to drip out. Check to make sure the float turns off the flow water once up to level.
Mar 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
I have model 3XART720F02 ART706 TYPE 2055A The water ice distribution area needs cleaning. Can this area be dismanteled
Prepare the Ice Maker For Cleaning
Step1Lift the power located above the ice maker storage tray.
Step2Unplug the refrigerator.
Step3Allow the refrigerator and to defrost. This will melt any large blocks of ice that have accumulated in the ice maker
Clean the Ice Machine
Step1Remove the ice machine storage tray.
Step2Dump any water in the ice machine storage tray.
Step3Wash the ice machine storage tray using warm, soapy water. Rinse and allow to dry completely.
Step4Sanitize the lines of the ice maker. Consult your manufacturer's
directions for steps to do this, because it's not available on all models.
Reassemble the Ice Maker
Step1Replace the ice machine storage tray.
Step2Plug the refrigerator into the outlet to restore power.
Step3Lower the internal power bar located just above the ice machine storage tray. This allows the ice machine to make new ice.
How to Clean an Ice Maker
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Aug 21, 2009 | Whirlpool Refrigerators
Brand new ice maker, water fill to tray will not shut off
The new ice maker should tell the dual water valve on rear of refrigerator to turn on if the tray makes a complete cycle. So the new ice maker is defective or the water valve on back is stuck open that leads up to the ice maker. Unplug the wires to the water control valve on back of the refrigerator and then turn the ice maker on. If the water continues to flow I recommend replacing the water valve. If the water stops coming to the ice maker I recommend returning the new ice maker. You only need to unplug the side of the water control valve leading to the ice make. I also recommend a pre-filter for the incoming water before the water control valve. Makes the water and ice better and keeps trash from damaging the water control valve. Let me know your results or if you need more assistance, Thanks, Sea Breeze
Jul 14, 2009 | Whirlpool ET8WTKXK Top Freezer...
Whirlpool refrigerator stopped making ice.
If there are ice cubes in the icemaker sitting there waiting to be dumped then the problem is in the icemaker. If the icemaker is dry then you have a water supply problem, even if you have a water in the door working.
1.Check the fill line inside the freezer at the icemaker, if it is clogged with ice then remove this ice and replace the water valve.
2. Check the water supply. Turn the water supply off, disconnect the water line from the Ref, turn the water back on an fill a small glass. If the water supply is good the solenoid on the water valve should be checked. This is done with an OHM meter.
If you got this far and need more info to DIY - ronbuice.com
Dec 13, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Samsung Ice Maker on Mdl RB215LASH
It is quite possible the water line near the ice-maker is frozen. I would try a warm hair drier to thaw it out.
Apr 21, 2008 | Samsung RB215LASH
Refrigerators Logo
106 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
