Question about Kenmore 15762 Dishwasher
I have a Kenmore dishwasher that will not pump water through the spray arms. It fills ok and drains fine but wont go into the wash cycle? Any idea of possible problems
  • 10,865 Answers
Look inside of the dishwasher to be sure that the tubes leading to the spray arms are not disconnected. If those tubes are in place, then the problem is with the main motor/pump in the base of the unit. That Kenmore part is about $150.00 plus labor. That being said, it may be time to consider a new dishwasher UNLESS your dishwasher is less than five years old because there is a five year warranty on the motor/pump. If it is under warranty, call sears repair and they should repair it at no cost to you.
Posted on Apr 18, 2009
I have a whirlpool Adp8540 that seems to go through the wash cycle completely but when we open it up the water has not gone through the spraying arms and the soap is a solid mass at the bottom of the...
It is likely the water circulation system is faulty. This dishwasher uses a single motor to run the water pump and the drain pump. If you hear the wash pump operate during wash cycle then it is likely there is a blockage in the water circulation manifold which distributes the water through the arms.
If you do not hear the pump operate during wash cycle then the sensor is faulty. The sensor tells dishwasher to switch to drain cycle from wash cycle.
Try following the diagrams at top of this website to get idea of parts.
Oct 13, 2011 | Dishwashers
My Kenmore dishwasher does not drain out, What could be the problem?
No drainage, or poor drainage issues are usually caused by either a failed drain pump, or the sump area under the sprayer is clogged with debris. The sump is the area at the bottom of the tub where water collects on the initial fill. A wash pump cycles the water throughout the wash cycle, followed by the same water being drained from the unit by means of a drain pump. This area is usually covered by a coarse screen and fine screen to prevent debris from accumulating. But, over time, some debris may still get past the screens and collect in the sump. This usually results in poor cleaning results due to restricted water flow through the spray arms, and poor draining.
I would recommend you remove the lower spray arm and screens and check the sump area for obstructions. If the unit still has standing water inside, use a wet/dry shop vac to drain. Remove the drain line from your sink and pull a vacuum on the end of the dishwasher drain hose. If the water drains freely from the unit, then you probably have a bad drain pump. If the water will not drain, you have a clog somewhere. Check your drain lines and pump for obstructions.
If you have any questions, please post back with a MODEL NUMBER. I hope this helps you.
Aug 15, 2011 | Kenmore Dishwashers
Hi, My dishwasher is about 6 years old and lately it is not properly washing the dishes. We've noticed that the glasses look foggy and the plates are sometimes not as clean as they used to be. Also usually...
Hi
If you are observing that the dishes are not clean, then you’ll need to follow certain steps to be sure where exactly the issue. First thing to check for is the detergent cup and spray arms. Check if the dishwasher’s spray arms are working fine and all the holes of the arms are clear. Now try using a different detergent like gel or liquid based detergent to see if it helps.
Dishes are left unclean when the dishwasher is not filling in properly or when the water pressure is low. Check for water pressure and water inlet valve. The water inlet valve if faulty will draw very little or no water. However, if you observe that water pressure is fine and there is no issue with the Fill valve then check whether the dishwasher is draining. If it’s not draining then see if the drain hose is plugged or clogged. If drain hose is fine and the dishwasher is still not draining then there is some issue with the drain pump or drain filter. To check this you’ll need to disassemble the dishwasher and trace back the drain hose to a pump, remove the drain hose from pump and clean the debris from the pump and filter. Make sure you have lots of towels as there would be a lot of water coming out from the pump.
Next thing to check if the dishwasher is draining and filling properly is water temperature. Water temperature should be between 120 and 140 F. If water is not hot enough then heating element has gone bad, to check the element you’ll need a multimeter. Use the multimeter and check if the Rx1 reading on the meter shows reading between 1200 (1.2K) ohms and 1500 (1.5K) ohms, if not the heating element has died.
Please post back if more information is required.
Daniel
Aug 07, 2010 | Kenmore Dishwashers
My kenmore dishwasher model 587.1414 does not
Check spray arm for obstructions and if it is clear the motor impeller could be slipping or water system may need a good cleaning with CLR.
Eric
Jan 14, 2010 | Kenmore Dishwashers
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher fills with water but does nothing else.
If your dishwasher drains and fills as it should and cycles normally, there is a problem with the spray arm assembly or recirculation pump. Esure that the spray arm is not clogged. Manually free up moving parts if the assembly can be removed.
Jun 25, 2009 | Kenmore Dishwashers
Whirlpool Quiet Partner 2
More likely: the solenoid which directs the water to either the drain or the spray arm is clogged/jammed. Located underneath near the drain line.
Jun 13, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Top rack dishes have grainy particles on them after washing and will not come clean.
Run the dishwasher and observe the spray arm,if split it will spray water down: Also check water in tub, is it filling up sufficiently to get near the heater? If it has a upper spray arm does it spray water? If not you may have a clogged upper spray arm.
May 23, 2007 | GE 24 in. Profile PDW7800 Built-in...
Wash cycle
Check first that the filter located inside the machine (on bottom) is clean. In case it clean - The problem is with the pump. It could be a blockage between pump and the tub, or just a defective pump (The pump takes suction from the tub and forces water up through the spray arms, which spray the dishes. The water then simply drops back into the tub for recirculation). Good luck !!
Jul 01, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
No pressure to drive swing arm.
Check first that no debris is blocking the holes in the spray arm where the water comes out, and clean out the holes. In case it will not solve your problem, it's look like a pump problem (the pump has two functions : drive water to the spray arms and to drain water out the washer). Open the rear panel and listen if the pump works during the wash cycle. In case it doesn't work, it should be replaced. Good luck !
Jun 20, 2006 | Danby 22 in. DDW399 Free-standing...
Kenmore 15762 Dishwasher Logo
442 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
