Question about Car Audio & Video
Power off issue
I just bought a remanufactured jbl gto7001 mono amp. direct from harmon kardon.. the amp does not power off when the ignition is turned off.. is this normal or is the amp defective? will it drain my battery if i leave it be?
  • octoberburni Apr 18, 2009
    thank you very much... very good info.. i will get it done asap
  • 655 Answers
Hello octoberburni,
No it is not normal for the amp to stay on when you turn the ignition off. And yes, it will definitely drain your battery if this condition is not corrected.
Use a multimeter set to volts and check between the ground connection (right connector) and remote turn-on connection (center connector) on the amp itself. You should have approximately 12V when the ignition and your head unit is on. And 0V when they are off. If you measure voltage when the ignition and head unit are off, either the incorrect wire is connected to the remote terminal, or the defect is in your head unit. If you measure OK, that is voltage present when ignition and head unit are on, and no voltage when they are off, then the problem is most likely in the amp itself. If you find voltage on the remote wire all the time, check to see that it is coming from the correct output from the head unit. Most aftermarket head units use a blue or a blue/white wire for the remote amp turn-on lead. Many (most) stock OEM receivers do not have a remote amp turn-on lead. But they may have a power antenna lead which will serve the same purpose. In any case, just insure that the correct wire is connected to the amp. It should have voltage when the head unit is on and no voltage when the head unit is off.
In either case, if everything else is still working with the amp, you can simply wire in a manual toggle switch to turn the amp off or on whenever you desire. A SPST (single pole-single throw) toggle switch is what you need. If the problem is in the head unit wire, put the toggle switch inline with the remote wire and mount it somewhere handy on or near the dash. If the problem is not in the remote wire, you'll need to put the toggle inline with the main power wire, the one marked "12V" (left connector) on the amp. In this case, you need to make sure that you have a heavy duty toggle switch, one that will handle more amps than your primary fuse. You may need to look under the hood for the fuse to check it's value.
Hope this helps.
Posted on Apr 18, 2009
I need to know the color code or the resistor's value for r134 on the Creature's pcb. If anybody knows, please respond.
Hi I done a search on Google and found a schematic it might help. Type in. Harman kardon jbl creature schematic photo :::: I done this search on my phone ...good luck
Jul 13, 2016 | Harmon Kardon Jbl Creature 3-piece Powered...
Harmon Kardon Receiver "Protect" Mode issue
If your receiver enters protect mode with no speakers connected, it is an indication that you will have to start troubleshooting inside.This will involve visual checking and checking with a multimeter to isolate the problem. A further issue is finding out why your JBL woofer keeps blowing fuses. It could be shorted.
Dec 12, 2013 | Audio Players & Recorders
My power is 0.93 A hou manny volt iss that
Perhaps make it more Clear then i can help u!
Dec 29, 2012 | JBL GTO7001 Car Amp
Can I connect a Harmon Kardon TS200 speaker system I bought an auction to my iMac or do I need some kind of amp/receiver?
Does the speaker system have its own Built in amp to the sub, If it has a built in amp, Then you can hook it up to thje computer with the proper patch cord,
Dec 02, 2012 | Harmon Kardon Harman/kardon Hkts 200 Bq...
How do you bridge a JBL GTO7001 amp
JBL do not suggest bridging this amplifier. As it is a mono block, the "stereo outputs that are on the amplifier go to the same contacts inside", so effectively both Left and Right outputs are the same, (like using a headphone splitter.) this is designed for ease of use when installing more than one subwoofer. if you run your sub/s at two ohms you will be able to get the full 700WRMS out of this unit.
so in effect if you "bridge" this amplifier it will not be any different if you hadn't. Bridging is designed for TWO or more channel amplifiers to increase the power going to the speakers, but not needed in a mono block amplifier.
I hope i have helped you with your problem and please dont forget to rate my solution.
cheers
Jan 14, 2011 | JBL GTO7001 Car Amp
MY GTO 7001 HAS ITS LIGHT WORKING, BUT NO POWER COMING OUT.
Make sure your rca jacks are plugged into both your headunit and amp. Also make sure that the amps filters are set so that the amp plays all frequencies and doesn't block out any.
Jan 10, 2011 | JBL GTO7001 Car Amp
I want dimensions of speakers &woofer of model hcs200 but i didnt find on any site of JBL &specs for speakers set & avr134. the entire model no is HCS200.5...
http://www.harmankardon.com/EN-GB/Products/Pages/ProductDetails.aspx?PID=HS%20200/230&accT=1&tsT=0&ovT=0
If this link does not work just look up harmankardon.com where you are
Hope this helps
Thanks for using FixYa
Aug 09, 2010 | JBL 5.1-Channel Home Theater Speaker...
Need a replacement amp circuit board for a jbl venue sub 10 - part # is 104HKTS1400v-E
The boards can be repaired - look for we repair and your model number on ebay -
Nov 22, 2009 | JBL Venue SUB10 Subwoofer
Car Audio & Video Logo
90 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
