No power getting to washer - Washing Machines
  • 686 Answers
Post model number
Posted on Apr 18, 2009
  • James Chandler Apr 18, 2009
    post model number
    is this a top load or front load, and the brand is? M512 has not helped me in the search. Some washers have fuses in them but not all.
My power has been off for almost 5 days. I unpluged my washer and now that the power is back on it will not start, can't change setting. What should I do?
Not sure about your post. Is there lights on the dryer that come on telling you that there is power at the washer or are you not getting any power at the washer. If you are not getting power at the washer I would first check your breaker panel to see if any breakers have tripped when power was restored.
Sep 14, 2017 | Washing Machines
How to check for power?
Do you mean you confirmed there is no power to the washer, or do you just mean it doesn't seem to power on? Have you checked the circuit breaker panel to confirm the breaker for the washer isn't tripped? Do you have a circuit tester or multimeter to confirm you are getting power to the output the washer is plugged in to?
Oct 15, 2016 | Estate ETW4400XQ Top Load Washers
How do I get the soap to work on a power washer
you have to use a large tip in order to get soap and also check to see if the soap hose inlet is open
Sep 17, 2014 | Devilbliss DeVILBISS Devap DVH2600...
Frigidaire affnity no power washer does nothing
see this causes and fix it. God bless you
see the diagram attached and troubleshooting.
1. No power to the washer
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
2. Lid switch
The washing machine may not function if the lid switch is defective. The switch is usually located near the door. Replace if found defective.
Sep 30, 2012 | Frigidaire Affinity ATF7000E Front Load...
Karcher 1600 pressure washer will not get power. It was working then stopped getting power. It is not that old.
ok im a technician... cheak d power swtich. i think most of karcher power knob switch they got a error problem.
May 30, 2011 | Karcher K2.26 Electric Power Washer
How do I get my Power Washer to spray with soap in the water?
You will need to adjust the pressure to low pressure by adjusting the lance. This way the machine will draw chemical at low pressure.
May 21, 2010 | Karcher G3025OH Pressure Washer
WE just installed both the duet washer and dryer. The dryer starts up just find but the washer will not turn on. Checked the outlet and it is working..so there seems to be no power getting to the machine....
Hi, check the following trouble spots below. you will find the issue in one or, all the areas stated.
2. Lid switch/door latch
The washing machine may not function if the lid switch or door latch mechanism is defective. The switch is usually located near the door. Replace if found defective.
**If you are getting power to the washer and, step 1 and 2 check out ok, replace the timer control or control Board and start switch as well.(You can test the continuity or, resistance level of the Lid/door switch with a multimeter(ohm).
Sep 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GHW9300 Washer does not come on
Aug 06, 2009 | Washing Machines
Whirlpool duet steam washer has no power!
call whirlpool, sounds as if you have a faulty electronic control board( power supply board) warranty issue, non need for you to get involved with the repairing of this
Feb 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
