Question about RTO Image 15.0R Treadmill Walking Belt
The treadmill belt keeps sliding to the right no matter how i align and tighten it. It had been working fine and all of a sudden it keeps sliding
It seems like the same problem I'm having I took it apart to replace the motor belt because it had gone bad but when I went to put it back together I can't get the front roller to go 100% streight the front roller is held in place by a bolt and the angle of the roller is adjustable with this bolt, but I can't get the roller streight to tighten the bolt in it so that it will hold out far enough to not let the belt slip. If you can get the front roller further up on that bolt the belt will stop slipping to the right.
Posted on Aug 19, 2010
Bremshey treadmill maintenance treadmill belt slipping
Fit new belt ,check for slide adjuster slots.
Aug 13, 2014 | Exercise & Fitness
Belt keeps sliding from side to side
You have not properly aligned and / or adjusted the tension. If it is SLIDING then you do not have enough Rear Tension. Once you get the right amount of REAR TENSION, then you have to adjust the left right (balance the belt). Your belt should go straight, right now you have it too far to the FRAYED SIDE. Turn the Machine on, have your Hex Wrench in the Bolt and turn it slowly CW and as the belt come back to Center, watch the adjustment. If it continues to go past, then loosen it a little until you have the right balance. Remember REAR TENSION FIRST... THEN BALANCE for Alignment
Mar 03, 2014 | Proform Crosswalk 395 Treadmill
I currently replaced the walking belt on my C954i/C956i treadmill. When I plugged it back in and turned on the power, the treadmill has no power. What could have happened?
Dear Sir:
I can read you trouble, and follow the next steps:
ALIGNING AND ADJUSTING THE RUNNING BELT
The correct alignment of the running belt is critical to the smooth operation of the treadmill. The belt is properly aligned at the factory. However, during shipping and handling or by use on an uneven surface, the belt may move off center and require a few simple adjustments. Before aligning the running belt, check its operation by following the procedure in Checking the Alignment of the Running Belt. If you determine that the belt needs alignment, follow the instructions here. CAUTION: Special care must be taken when aligning the running belt. Turn OFF the treadmill while adjusting or working near the rear roller. Remove any loose clothing and tie back your hair. Be very careful to keep your finger or any other object clear of the belt and rollers, especially in front of the roller and behind the deck. The treadmill will not stop immediately if an object becomes caught in the belt or rollers. Realigning the belt takes a few simple adjustments. If you are unsure about this procedure, call Precor Customer Support (see Obtaining Service.) Take the following steps to align the running belt on the treadmill. To ensure your safety, make all adjustments while the treadmill is OFF. 1. Make sure the treadmill is OFF and the running belt has completely stopped. 2. Locate the right belt adjustment bolt in the rear end cap of the treadmill. (To determine left and right, stand at the rear of the treadmill and face the display.) See Diagram 24. The direction you turn the bolt depends on how the belt is tracking. Make all belt adjustments on the right rear corner bolt using the hex key provided. • If the belt is off center to the RIGHT, turn the adjusting bolt ¼ turn clockwise, which moves the running belt to the left. • If the belt tracks off center to the LEFT, turn the bolt ¼ turn counterclockwise; this moves the belt to the right. Important: Do not turn the adjusting bolt more than ¼ turn at a time. Overtightening the bolt can damage the treadmill. 3. Turn the unit ON. 4. Stand beside the treadmill and press QUICKSTART. 5. If you are prompted for a password, press INCLINE ??¼, SPEED ??¼, SPEED ??². The running belt starts automatically after the 3-second countdown appears on the display. 6. Press the SPEED ??² key until the display shows a speed of 3 mph (5 kph). 7. Walk around to the rear of the unit and observe the running belt for a few minutes. The belt should run centered along the running bed. If the belt drifts off center, you will need to make adjustments. CAUTION: If you hear any chafing or the running belt appears to be getting damaged, stop the running belt immediately by pressing the red STOP button. Contact Precor Customer Support. 8. If the belt needs additional alignment, repeat steps 1 through 7 until the belt is properly aligned. 9. After aligning the belt, press the STOP button and RESET. Turn OFF the treadmill. Tighten any loose fasteners or other components on the equipment. If you hear unusual noises or you feel that the treadmill is in need of repair or service, contact Precor Customer Support. Refer to Obtaining Service.
Finally, check if the power cord is loose, connect it again. a) See if the breaker of Home is tripped? b) See if the breaker of the Treadmill is tripped. If do the Belt is very Tighted! loose a little. Try again.
Thank you in advance, if you need assistance, you can contact me, Blessing. sincerely.
E. CUADRA Managua, Nicaragua. C.A.
Sep 26, 2011 | Precor C954i Commercial Treadmill
I dont know how to line up my cams, witch dots do i line up
Manual is not clear either, but do you have "3V" marks on the gears? You have the 3VZ engine, so I would use those.
To install:
  1. Turn the crankshaft until the key groove in the crankshaft timing pulley is facing upward. Slide the timing pulley on so that the flange side faces inward.
  2. Apply bolt adhesive to the first few threads of the No. 1 idler pulley setbolt, install the plate washer and pulley and then tighten the bolt to 25 ft. lbs. (34 Nm).
  3. Install the timing belt on the crankshaft timing, No. 1 idler and water pump pulleys.
If the old timing belt is being reinstalled, make sure the directional arrow is facing in the original direction and that the belt and crankshaft gear matchmarks are properly aligned.
  1. Install the lower (No. 1) timing cover and tighten the bolts.
  2. Align the crankshaft pulley set key with the key groove on the pulley and slide the pulley on. Tighten the bolt to 181 ft. lbs. (245 Nm).
  3. Install the No. 2 idler pulley and tighten the bolt to 29 ft. lbs. (39 Nm). Check that the pulley moves smoothly.
  4. Slide the left pulley, facing the flange side outward. Align the knock pin hole of the camshaft with the knockpin of the timing pulley, then install the knock pin. Tighten the left camshaft timing pulley bolt to 80 ft. lbs. (108 Nm).
  5. Set the No. 1 cylinder to TDC again. Turn the right camshaft until the knock pin hole is aligned with the timing mark on the No. 3 belt cover. Turn the left pulley until the marks on the pulley are aligned with the mark on the No. 3 timing cover.
  6. Check that the mark on the belt matches with the edge of the lower cover. If not, shift it on the crank pulley until it does. Turn the left pulley clockwise a bit and align the mark on the timing belt with the timing mark on the pulley. Slide the belt over the left pulley. Now move the pulley until the marks on it align with the one on the No. 3 cover. There should be tension on the belt between the crankshaft pulley and the left camshaft pulley.
  7. Align the installation mark on the timing belt with the mark on the right side camshaft pulley. Hang the belt over the pulley with the flange facing inward. Align the timing marks on the right pulley with the one on the No. 3 cover and slide the pulley onto the end of the camshaft. Move the pulley until the camshaft knock pin hole is aligned with the groove in the pulley and then install the knock pin. Tighten the bolt to 55 ft. lbs. (75 Nm).
  8. Position a plate washer between the timing belt tensioner and the a block and then press in the pushrod until the holes are aligned between it and the housing. Slide a 1.27mm (3VZ-FE 1.5mm) Allen wrench through the hole to keep the push rod set. Install the dust boot and then install the tensioner. Tighten the bolts to 20 ft. lbs. (26 Nm). Don't forget to pull out the Allen wrench!
  9. Turn the crankshaft clockwise two complete revolutions and check that all marks are still in alignment. If they aren't, remove the timing belt and start over again.
  10. Install the right engine mount bracket and tighten it to 30 ft. lbs. (39 Nm).
  11. Position a new gasket and then install the upper (No. 2) timing cover. refer to the illustration for bolt positioning.
  12. Install the spark plugs.
  13. On the 2VZ-FE, install the right engine mount insulator. Tighten the bolt to 47 ft. lbs. (64 Nm), the bracket nut to 38 ft. lbs. (52 Nm) and the body nut to 65 ft. lbs. (88 Nm). Install the No. 1 stay and tighten it to 38 ft. lbs. (52 Nm). Install the No. 2 stay and tighten the bolt to 48 ft. lbs. (66 Nm) and the nut to 38 ft. lbs. (52 Nm).
  14. On the 3VZ-FE, install the control rod and tighten the bolts to 47 ft. lbs. (64 Nm). Install the right stay and tighten it to 23 ft. lbs. (31 Nm).
  15. Install and adjust the drive belts.
  16. Install the fender apron seal and the wheel.
  17. On the 3VZ-FE, install the No. 2 stay and tighten the bolt to 55 ft. lbs. (75 Nm), the nut to 46 ft. lbs. (62 Nm). Install the No. 3 stay and tighten it to 54 ft. lbs. (73 Nm).
  18. Install the coolant overflow tank and the washer tank.
  19. Install the power steering reservoir tank and the cruise control actuator.
  20. Connect the battery cable, start the car and check for any leaks.
Jul 18, 2011 | 1992 Toyota Camry V6
Belt is slipping.... does this mean I need a new belt?
Typically you can tighten the belt with an allen wrench at the rear of the belt, treadmill be sure to align belt before tightening. Alternate each side as you tighten
Nov 25, 2010 | Proform XP 580 Trainer Treadmill
Treadmill slows suddenly and when i step off it starts again. only happens to me.
hi it sounds like the belt is too loose, i had the same problem when the wife uses the treadmill works perfect, untill i step on it really slows down and once i step off it runs fine. so i tightened the belt just a fraction and now works fine. check your instruction manuel it will explain how to do this. normally its two screws at the backend of the roller. hope i have helped.
Nov 15, 2010 | Proform XP Weight Loss 620 Treadmill
My weslo cadence 200 treadmill belt keeps slipping to the left. i keep tightening and loosing it to keep it even but i keeps sliding to the left
please look under the bottom of the treadmill and be sure that your alignment brackets are not benmt/missing. (put the machine in the storage position and look about 2/3 way down the side of the belt) you should see a metal bracket on each side pressing in on the belt. They should be pressing in about 1 1/2 -2 inches to help track the belt.
Nov 24, 2009 | Proform XP Weight Loss 620 Treadmill
Tread is sliding and rubbing agianst right side of track.
Make sure treadmill is running when you adjust belt. The treadmill belt tracks as the belt goes around. I usually put machine on 2-2.5 if belt is not rubbing instantly. If belt is already against plastic, turn adj. counterclockwise on the opposite side about one full turn. You can usually move belt with your foot to see if it aligns any with turning on the treadmill. Once belt is not rubbing, turn treadmill on and continue alighing the belt.
Jul 20, 2009 | Nordic Track NordicTrack Treadmill, A2550
RTO Image 15.0R Treadmill Walking Belt Logo
758 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
