Lamp light coming on my wd52527 when lamp was just replaced tv saying lamp is about to exceded its life
  • 23 Answers
There is a reset of thew lamp timer which should have been done at time of replacement. It is usually the combination of holding 2 or 3 buttons at the same time. The manufacturer usually has it posted on the web or the instructions with the lamp should have the procedure....
Last resort is call the manufacturer tech line
Posted on Apr 18, 2009
VT595 LCD Won't come on. Power light orange Status red Blincks Once every sec or so.
If the lamp life has exceded its safe working limit, it will probably go into a permanent standby mode, I used to have an NEC MT830, I had to hold down the off button for 20 seconds to reset the lamp life, maybe it will be something similar. If you have your manual, it may give instructions, if not there will be a downloadable manual on the NEC website.
Good luck
Aug 09, 2011 | NEC VT595 LCD Projector
After lamp replacement new lamp will not come on. we do not have the remote. what may cause new lamp to not work
It could be the lamp life has exceded its safe limit and engaged a permanant standby mode. I had an old NEC which I had to hold the off button down for 20 seconds and that reset the lamp life. You could try this. Not sure if your manual will help. You could probably download one from NEC website
Good luck
Aug 08, 2011 | NEC NP905 LCD Projector
THE PLASTIC FEMALE END WERE THE LAMP HOUSING PLUGS INTO IS BROKE I CAN'T GET TO IT WITH OUT A SCYMATIC OF THE TV PARTS DO YOU HAVE ONE?
The wire you speak of comes as part of the light engine. IT is not a replaceable part. Your best bet would be to contact local repair shop and see if they have one from a scrap set.
Feb 21, 2011 | Mitsubishi WD52527 52" Projection HDTV
I replaced the lamps in my DS+65 but it is still saying that the it has exceded the lamp life. Is there a way to reset the lamp timer?
Yes you have to tell it you have put in a new bulb.
The status or lamp menu will have a reset counter option.
Please dont forget to vote if you liked my answer
thanks
Feb 09, 2011 | Christie DS+65 Projector
Lamp light is red
pull lamp from unit and investigate it for integrity
Jul 07, 2009 | Mitsubishi WD52527 52" Projection HDTV
No picture lamp light on
You can find the lamp acces door on the lower back left side. You will have two philips head screw to remove and you will see the lamp. Remove it and look at it. It will probably be shattered. There is also a filter right beside the access door. Be sure to clean that.
You owners manual can provide you with info to ordered a lamp and have it sent to your home
Nov 23, 2008 | Mitsubishi WD52527 52" Projection HDTV
Problems with my tv
When ever i turn on my Mitsubishi WD52527 TV it comes on, I hear sound but no picture for around 7 seconds, then the red light under lamp comes on, and the sound go away
Oct 16, 2007 | Televison & Video
Mitsubishi WD52527 lamp light
Replace the lamp, model 915P028010.  There is a lamp door on the back left bottom of the set (while looking at it from the back).  Take off the door (two screws) and then take off the two screws holding the lamp in place and pull on the handle.  Replace the lamp the same way.  Then make sure to clean the air filters (below the lamp, two screws; and bottom right).  If the set gets too hot it may destroy the set and/or the lamp.  Also, don't turn the set on and off again within a few moments.  It will destroy the lamp.  Take it from someone who had the same problem, keep the filters clean by cleaning at least once every couple of months....Dave
Sep 20, 2007 | Mitsubishi WD52527 52" Projection HDTV
Televison & Video Logo
117 people viewed this question
Top Televison & Video Experts
Electro Med Services...
