Question about Maytag UMV1152 Microwave Oven
UMV1152BAB Maytag Microwave ... door look
UMV1152BAB Maytag Microwave ... door look broke.... how can i replace the door
  • Anonymous Mar 14, 2014
    how do I change door on maytag microwave?
  • 686 Answers
REMOVE THE CABINET(COVER) AND YOU SHOULD BE ABLE TO SEE WHAT TO DO.
Posted on Apr 18, 2009
I have a Maytag Microwave Model MMV5207BAB. The door handle broke off and I would like to replace it. What parts do I need to buy?
The support page for model MMV5207BAB is here. Your exploded view with parts list is here.
The service manual is here, and it will you important safety and disassembly information.
Unfortunately, the door handle is not available separately. You would have to order the entire door assembly.
It is part number DE94-01381J and it runs $106.99 from Sears here. (prices subject to change)
William E. Miller
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Jan 15, 2017 | Maytag Microwave Ovens
Door handle broke on my Maytag MMV4205AAQ microwave. It broke once before while under the first year warranty so I know that repair requires replacing the whole door.If I purchase the part (PS909599), how...
Hi ,
There is a inner door trim on the inside of the microwave door that can come off to expose the screws for the handle. This trim is held in place by clips built into the trim, ( some older models may also have screws - look for them and remove before going any further ) the tabs on this trim can break easily but with a putty knife and some patience, the trim can be removed to get at the handle screws. See picture help. This trim can be pushed so the clips will "pop" back into place after the handle repair.
Sep 30, 2008 | Microwave Ovens
Tip
Maytag MMV4205 door won't stay shut.
After tearing apart my microwave, I found a little spring broke off the latches. Open the door to the microwave, pop off the plastic piece that the latches on the door go through. You will see a spring behind the latch. If the spring is not connected to the latch it won't operate properly. The spring was held onto the latch with a tiny plastic piece that broke off. An easy solution instead of buying a new latch is to heat up one side of the spring without burning yourself and melt it through the latch piece where it was originally connected then put everything back together.
Hope this helps,
Pillarair
on Jul 21, 2009 | Maytag MMV4205 Microwave Oven
MVP V door handle broken
Maytag mvp v microwave door handle parts Questions ...
www.fixya.com > Forum > Tags > mvp v microwave door handle parts
Maytag mvp v microwave door handle parts related problems. Ask your Maytag mvp v... The handle on my maytag microwave oven broke off ... door handle ...
Maytag Microwave Handle Parts from RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Maytag-Microwave-Handle-Par...
Shop for your Maytag Microwave Handle from our huge inventory. Return any part for any ... Repair Help for Microwaves .... Microwave Oven Door Handle.
CMV1000ADW Maytag Microwave Parts and Repair Help
www.partselect.com/Models/CMV1000ADW/
Dec 22, 2015 | Microwave Ovens
My push button to open door broke. how do I get the door to open?
Disconnect microwave from power socket, remove cabinet outer cover,and lift the top or bottom door latch at micro-switch bracket with a screwdriver, the door can then be opened.
Oct 24, 2015 | Maytag Appliances Over-the-Range Microwave...
Door frame on microwave broke apart
If it is out of warranty, I'd just buy another. Most repairs would cost more than a replacement nowadays.
Nov 13, 2013 | Maytag MMV5208W Microwave Oven
Door Handle snapped off
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you then have to gently rotate the handle to unlock it.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 09, 2009 | Maytag MMV5165 Microwave Oven
The handle on my maytag microwave oven broke off at the bottom. How do I replace ? Model MMV5165BA
The door handle can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
This is not difficult. To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
Replacement parts can be found at any of the following sites:
appliancepartspros.com
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
I hope this helps you.
Aug 12, 2009 | Maytag Appliances Over-the-Range Microwave...
The entire door handle snapped off
I have the same problem- funny when we built we went all Maytag and got a bunch of lousy handles- the stove, micro, fridge, and freezer... I glued the pieces of the handle together and used plumber's putty to fix it. It's MightyPutty, but without the repackaging and cost. Just knead the putty until mixed, fill the cavity of the handle and press on the door where it was... No problem after six months so far.
Nov 30, 2008 | Maytag MMV5207A Microwave Oven
Maytag UMV1152 Microwave Oven Logo
558 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
