Question about LG 15LW1R 15 in. LCD Television
I click on power on the remote and on the tv "connecting" comes
Up. And also says check transmitter. The blue light, however, doesn't come up. It looks like there is no connection between the tv and the transmitter. So the tv is not working. I don't know what to do with it. I pressed the botton on the transmitter and it worked for a while, because the tv turned on but not anymore. Please help
    Top Expert:
  • LG Master
  • 74,999 Answers
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly. [open and clean] [open and clean]
Posted on Aug 08, 2017
  • 86 Answers
SOURCE: My 42"LG 50 TV will not turn on
One important step to see if you are having an internal problem is to perform a power drain.
1. Unplug the product's power cable so that the device is not grounded to the house. Do not simply turn off the power-bar if one is in use.
2. Press and hold in the products power button for 1 minute to release the retained electricity from the capacitors and circuit board. 3. Plug the product back into the wall outlet rather than a power-bar to rule it out of contributing to the problem and turn the device back on.
If this does not work but you are still seeing a LED lit up, there is probably a problem between the TV's power supply and the mainboard and service maybe required.
Posted on Oct 14, 2008
  • 903 Answers
SOURCE: Screen color is blue
A blue screen normally comes on in AV or EXT mode, try changing the tv settings back on the controls in TV mode
I hopethis helps
Posted on Nov 20, 2008
  • 298 Answers
SOURCE: Loud pop Blank screen 42 inch Viore Plasma
Unfortunately, that board is the inverter board. And for this model the inverter board is only supplied with the the PDP panel. The panel is quite expensive, here's a link if needed:
LG 42PX5D Replacement Part PDP Plasma Display Panel
Posted on Dec 29, 2008
  • 3153 Answers
SOURCE: Same problem
Out of range usually has a very different meaning when looking at LCD TV's
It usually means that a resolution that was beyond the design capacity was chosen.
eg some TV's can only do 720p but people may try to set them to 1080I
this would give an OUT OF RANGE" error this is also common to many computer displays too.
Posted on Sep 08, 2009
  • 148 Answers
SOURCE: i have a lg 26lc7d tv and the red light is orange
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol! If this helped you (or not )please rate, thank you!d539576.jpg
Posted on Feb 04, 2010
Blue light comes on then u press remote to switch on tv, but it wont do it. tv wont come on when pressing on button on the remote.
The blue light merely indicates power is getting to the TV. The TV is not turning on because of an open internal fuse or power supply failure.
Apr 26, 2016 | Televison & Video
Why is that not working?
The antenna in the helicopter might be broken
May 08, 2014 | Electric 3CH Mini Sport RTF RC Helicopter...
Power light blinks three times then nothing
A green LED that blinks On and Off is an indication on some models that the TV is receiving commands from a remote. By modelling, it just check SYN, SYN-ACK signal between transmitter and receiver. No worries.
Nov 23, 2013 | RCA F36650 36" TV
Protron tv 3250 tv went off. only blue light blinks
Your TV has two poweroff functionalities. First power off button is on saver mode least displaying any transmitter programs. Using the remote control to power off the device achieves screen saver poweroff mode. Second manually pressing on the power button after power saver mode has been achieved with the remote control device should shut down the TV tube entirely. The blue light should not display in whihc instance. Howerever, a full power off mode is incapable of being controlled by the remote control device whenver poweron is required later. The TV power shut down button has to be pressed again to alow for current circulation once more. Powering off the TV with the button on the set requiries momentary duration waits whenever to achieve display of signals depending on the size of the TV, and how many pheriperal device connnections are attahced to it.
refer to the TV user manual for possible diagnostic to any persistant conditions.
Good luck
Jan 08, 2011 | Protron PLTV3250 32 in. LCD Television
The blue light on the transmitter is not coming on. It had begun to alternatingly be on/turn off. What is the problem?
Check that the transmitter AC power adapter is fully inserted into the wall outlet and the power cord from the AC adapter is firmly connected to the transmitter power input jack. So if you
Jan 05, 2011 | Cables Unlimited Audio Unlimited 900MHz...
Remote control not working with tv
The remote control is an acess to the TV device for example only from a distance. A remote controll for functionality would require to insert batteries a power source making possible communiction with devices requiring reception transmittion of signals. The remote is handheld pointed to the direction of TV requiring signal before button pressed woudl achieve response. a common button to start the remote control experience is pressing on the power button, that displays a signal on the TV. The TV should momentarily produce a sound and lighting effect,, and displaying on the dark screen a light blue screen. The initial signal response from remote control to TV indicates devices are functioning as required. Additional buttons on the remote controll could perform functions of several available.
The remote control has master button, menu on which every additional function is deriveable. Once the menu button is pressed with remote pointed in the direction of TV, should dicplay a list of options on the blue screen already established by power button. Every additional remote control device functionality is achievable by only after the first two buttons have been powered and pressed to display option results on a screen of TV. The remote controll buttons remaining perform complementary functionalities. For example, the arrow keys on remote control make movement of the options displayed on the screen, where a comfrimation button or identified as select allows to confirm remote functions displayed on the screen. A remote control could have several functionalities only accessible once made to display in screen. The three most common buttons on a remote control are First power button that powers on the TV, menu button that displays a list of functionalities on the powered on bl;ank blue screen, and using the arrow buttons on the remote would moves an indicator arround the screen area options. The selection button makes confrimation of the option.
Dec 02, 2010 | Philips Televison & Video
When I start up my Samsung 52 it has a VERY long delay
Are you retarded? remote batteries? Sounds like your power supply is toast.
Jul 30, 2009 | Samsung LN52B750 52 in. LCD TV
Samsung's yp-t10, can it be paired with freepulse?
Yeah, they were quite well together i have them both.
To connect
1. Hold the switch button on the Free pulse until it flashes
2. Go to bluetooth setting in the T10 and add Headphones
3. Turn on headphones when turning on T10 should automaticaly connect.
Jan 06, 2009 | Logitech FreePulse Wireless Consumer...
Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Aug 17, 2007 | Hampton Bay 04383 Calibre Ceiling Fan
LG 15LW1R 15 in. LCD Television Logo
65 people viewed this question
Computer Repairing
Computer Repairing
