Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Whirlpool Icemaker not working
I found two troubleshooting manuals, the Whirlpool "consumer services technical education group R-92", which is fairly good but misses some information, and a diagnostics link http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34 In the link, the test points are described. Using those, I've measure the voltage from L to N and found no voltage. This is supposed to indicate that the icemaker has no power. The optical boards are testing out just fine, so how come the icemaker has no power? I've also measured the wiring harness attached to the icemaker because there is something that looks like a fuse mounted by the heater, and all the wires measure good connectivity straight through the harness. I don't have a wiring diagram for the wires coming from the freezer, however. As always, any help is very much appreciated.
  • 5 more comments
  • WillN2Try Sep 18, 2007
    Catriver,
    Thanks for your advice, I'm thrilled that you weighed in. I got as far as I did mostly due to following one of your earlier posts. I've been trying every combination that I could to get something to happen, but was more systematic this time about following your directions.
    Here's a step by step of what I did and what occurred:
    1. Powered off the frig.
    2. Disconnected the unit from the wiring harness.
    3. Hooked up my VM to test points L & N.
    4. Powered on frig.
    5. With freezer door open, held door switch closed and left flapper closed to clear optical path.
    6. Initially, still no 120VAC at L & N. After about 10 seconds, 120VAC appeared at L & N. Motor started rotating! (I haven't seen that in about 4 months!). Based on something I read earlier, I shut off the power to the fridge when the fingers were at about 10:00 (when looking from the module side).
    7. Waited about 5 minutes (and recorded my step by step so that I could post it).
    8. Powered on the fridge.
    9. Waited about 45-60 seconds. Heard the water fill for about 5 seconds or so. (Another long awaited milestone!). It seems like the water fill is a bit shallow, but I can worry that later.
    10. Opened the freezer and noticed that the fingers were at the 2:00 position (again, when looking from the module side).
    I did not jumper T&H, since things were moving. What do I do now? Sit tight?
  • WillN2Try Sep 19, 2007
    Catriver,
    When I came home tonight, the ice was frozen on the surface, and the ejector was sitting at the bottom position (6:00?), seamingly embedded in the ice. Do I still sit tight, or did something not operate correctly?
    Catriver,
    I have attached a photo of the module. I noticed earlier that it looks like the clips are there, but they are not quite on the gear. Since the teeth appeared to be rotating, however, I thought that maybe the teeth and the white gear on the outside weren't attached quite the way that I expected.
    Thanks very much for your time. I certainly don't mind buying a new module, but I didn't want to do it if the problem was somewhere else.
    Catriver,
    As I was typing the previous post with the image, I heard a clicking sound in the fridge. I open the door and the unit seems to be straining to operate. The ice was melted and ready to move, and the ejector had moved a little bit. I "helped" the large white gear turn a little, and the unit completed the cycle, dumped the ice, and filled the water. It seems like the gear is slipping. Do you agree?
    Catriver,
    I looked harder. It wasn't obvious externally, but you were right on the money. One of the clips was broken.
    Thanks so much for your time and help. You definitely deserve the guru title.
  • Anonymous Dec 12, 2007
    ice maker quit making ice
  • Anonymous Feb 25, 2009
    clip broke on in gear should i replace whole maker? module is almost as much?
    New Friend:
The receiver board on the right side was noticeably burnt and inoperative. I replaced both optic boards. It immeditedly started the cycle and after one cycle the receiver board burnt again. Any suggestions.
Posted on Jul 17, 2010
If there is no power after the power check,look at the plug that goes into the ice maker. If the prongs are laying below the plastic plug, they will not contact the ice maker. My solution was to slightly raise them back up with an awl ( an ice pick would also work). I find this site very helpful and interesting. Rocky
Posted on Oct 09, 2007
    President:
  • 878 Answers
Willn2try. On the indoor ice maker the immitter board and receiver board will determine when to send power to the module. This is probably why you are not reading any voltage on your test points. When the thermostat closes, the emitter board sends out a infared pulse. If the path of the pulse is not blocked (like no ice in the bin) it will then send power to the module and start a cycle. Since you stated the optics are good, try testing for your voltage by holding down the left side receiver board, light switch and do not block the beam. You can bypass the thermostat by jump starting the cycle. Place a jumper in T&H, place the IM on a shelf out of the way of the boards. Close the door and unplug the refer for 30 seconds. Plug the refer back in and wait 45 seconds. When you open the door the cycle should be started. Cativer
Posted on Sep 17, 2007
  • 1 more comment
  • Ron Marek
    Ron Marek Sep 18, 2007
    Sit tight guy, you successfully jumped the icemaker and it should cycle approx. every 2.5 hours. The hardest part about repairing this system is jumping it out to start a cycle. Sometimes it takes me 2 to 3 times to get it going. Another way to do it is by jumping out the right side board but that can lead to some sparks flying if you are not careful. It's easier to do it the other way. Glad your back in business..Catriver
  • Ron Marek
    Ron Marek Sep 19, 2007
    WillN, sounds like you need a new module, look at the white center plastic gear, See if one of the clips that secure it in place is broken off. There should be two clips holding the gear in place. Pretty common problem for the clips to break and the gear comes off the shaft. Catriver
  • Ron Marek
    Willn, just by looking at the photo, it looks like the lower clip is busted. This gear will ride out if it is not held in by the clips. A classic example of the gear riding out is the ejector blades stopped in the 6:00 position, frozen in the ice. I do believe that your module is the problem and that the rest of the system is good to go. Catriver.
SOURCE:
Can't remove wires from ice maker in whirlpool
We are not technicians, we do not have technical training, or technicians here in customer service. We can
offer troubleshooting. Unfortunately, we do not have the provisions to assist you with detailed technical advice, provide
repair manuals, tell you how to take it apart, or advise on which parts need to be changed to repair the unit. We do not offer
repair assistance in customer service. If you are unable to resolve an issue on your own, we can only recommend service, as
we do not have any technical line that customers can use.
Most companies do not offer technical assistance due to liability issues.
Mar 05, 2018 | Whirlpool Refrigerators
Dehumidifier manual
Hi, consumer. We're sorry to hear about the difficulty with your dehumidfier. Below are links to our Use & Care guides, Parts Diagrams, Troubleshooting information and the Service are of our website. We hope this helps! http://bit.ly/112Lu7q
Aug 24, 2014 | Whirlpool Dehumidifiers
I HAVE A WHIRLPOOL 25 Pint Dehumidifier model AD25BBL2 serial starts with QM. Anyway it Seems to work ok as water does collect in water tray. About every 30 minutes it makes a single KNOCK NOISE. Unsu
Hello, Consumer. We're sorry to hear about the difficulty with your dehumidifier. Below are links to our Use & Care guides, Parts Diagrams, Troubleshooting information and the Service are of our website. We hope this helps! http://bit.ly/112Lu7q
May 21, 2014 | Whirlpool 25-Pint Dehumidifier
Ice maker doesn't work.model kbfa25erss01
Hi and welcome to FixYa, I am Kelly.
Often when ice-makers stop working the real problem is that the freezer is not cold enough (It must be 14-16F for the icemaker thermostat to cycle) Check for signs of ice or substantial frost in the back of the unit / evaporator coil area. If you have ice / frost in this area you should do a manual defrost by unplugging the unit and directing an external fan into the freezer compartment for about 2 hours while it makes a water mess that will need to be tended too. Once the 2 hour thawing is complete wipe up the excess water and return the unit to normal service. If the problem was caused by excess ice it will operate normall for 2 - 3 days before ice production slows or stops totally. Should the manual defrosting correct the icemaker problem you most likely have and automatic defrost problem in the form of a problem with one of these 3 components:
1. Defrost control
2. Defrost heating element
3. Defrost thermostat
Having said all of that... You can use this manual to check out your icemaker:
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
Make sure to test the coils on the inlet water valve for continuity. If one of the coils is open *** must be replaced. The inlet water valve is NOT repairable.
Your water valve can be found here:
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-water-inlet-valve-item-number-ap4080917.aspx
Here is another link on how to test out the icemaker:
The ice-maker thermostat must be at or belw 16 F for the above tests to work.
NOTE the freezer door LIGHT switch must be taped down also.
Before you get too deep into troubleshooting checkout the freezer door light switch first. If the switch is bad the freezer compartment light will not work and the ice-maker also will not work.
Thanks for choosing FixYa,
Kelly
Jun 24, 2011 | KitchenAid Refrigerators
Getting a error 5010 on my printer. It has been working fine until today.
soft-manufaktura.ru/manual/hp/mp500sm.pdf
Hi please find above a service manual, this will assist you to troubleshoot and repair your issue.
error 5010 The scanner has not retracted to the normal starting point. This often means a faulty sensor, or faulty main board. use the service manual to troubleshoot and repair.
This seems to be a fairly common problem.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp500
Above is your support link, use this as well...
Dec 14, 2010 | Canon Pixma MP500 All-In-One InkJet...
The ice maker is not making ice.
Usually when an Icemaker stops making ice the problem is either caused by:
1. An automatic defrosting problem (Freezer above 16 deg F.
2. There is a problem with the ice maker water valve
3. The icemaker itself has a malfunction.
Download this manual and follow the troubleshooting procedures:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
You should be able to resolve the problem
Here is yet another link that can be a big help: (Better than anything I could tell you here)
Thanks for choosing FixYa.
Kelly
Sep 03, 2010 | Whirlpool 25.2 cu. ft. Side-by-Side...
Cancel my subscription today! 10/26/09 and confirm. Vera L. Smith
Read the following:
Who should I contact with FixYa Account questions? If you have a question regarding your FixYa member account, please email us at [email protected]. Please do not email us technical questions regarding your consumer products. You may post your gadget, electronic and/or consumer product technical questions on the FixYa.com troubleshooting forums, and receive technical support from the FixYa community. Who should I contact with Premium Services questions? If you have a question regarding Premium Services - including Premium Live Chat, Premium Problems, and Expert Payments - please email us at [email protected]. Please do not email us technical questions regarding your consumer products. You may post your gadget, electronic and/or consumer product technical questions on the FixYa.com troubleshooting forums, and receive technical support from the FixYa community.
Oct 26, 2009 | Refrigerators
"whirlpool duet makes big noise on hi spin cycle and sandy grey staf is coming out from drain hose"
You have a big problem here. It sounds like the bearings on the drum shaft are going. this is over $400 for the back half of the outer drum and you have to be a very good mechanic to get it all apart. I currently have mine apart for the same problem which I verified by opening the door of the washer and lifting the inner stainless steel drum up and down with the machine off, of course. The tub is supported by two large ball bearings on the shaft that is supporting the stainless steel drum, and they don't sell just the bearings and seal, only the back half of the drum. If it has gotten bad enough to rub against the front half of the outer tub, it will probably have to be replaced also, about $120. This was probably caused by overloading the washer or washing something that was unbalanced and heavy; this destroys the seal between the inner drum and the heavy bearings, also not available separately, and lets water into the bearings in the aft outer tub which support the inner tub shaft. If you want to try to take this apart to verify, try looking at Whirlpool consumer services technical education group presents #L-68, Job Aid Part No. 8178076. I found it online. It has detailed instructions how to take this machine apart if you are a technician or a talented amateur, as I am. Good luck.
Apr 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Repair manual
Somebody stated in a consumer product review that he found a repair manual mounted inside the front panel of the machine. He also gives some details of repair work that he did to his washer, so you may want to read the review for yourself. Link below: --> http://www.dealtime.com/xPR-Whirlpool-GVW9959K~RD-380361477764
Aug 04, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
3,667 people viewed this question
Top Whirlpool Refrigerators Experts
Bruce Denton
Steve Allison
Steve Allison
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
