Question about Kenmore 73952 Gas Dryer
Kenmore gas dryer doesn't stay running have to hold button down.
Kenmore gas dryer. Last week I started the dryer and after 2 min it stopped running. When you push the start button and hold it dryer runs. But if you let it go, it stops. We replaced the push to start switch and it's the same thing.
  • 3 more comments
  • Anonymous May 02, 2009
    MY DRYER DOESNT RUN ON IT OWN
    I PUSH THE BUTTON IT WILL RUN AND THEN STOP BY IT SELF
  • Anonymous May 04, 2009
    I have the same problem and found that it was the door latch.
  • adamtomorrow May 05, 2009
    Kenmore 73952, working fine, put the next load in and pushed start and it just reved, if you hold the start button down it runs fine?
    worked fine until I put the next load in and when I pushed the start button the motor just reved, then I held it down and it runs fine?
    Kenmore model--- 110.73952101 thanks.....
  • 686 Answers
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Posted on Apr 18, 2009
Kenmore Elite 11072972101 gas dryer will not stay on after I push the start button. What is wrong and how do I fix it.
If you HOLD the start button down and the drier heats and runs, then your problem is most likely a relay which is supposed to energize (close contacts), which "latches" the condition when you push the start button. The most likely cause of such a failure, is a fuse or a thermal cut out, which has prevented normal operation. For safety reasons, being a gas appliance, I would NOT ATTEMPT to fix this problem yourself, unless you have licenses to service such equipment!
Apr 17, 2017 | Kenmore Dryers
My Kenmore gas dryer starts but does not stay on
This is very likely a relay problem. There is a black relay in the control head that engages when the start button is pressed. The relays tend to go bad now and then. They are a simple replacement and cost less than $15 or so.
Sep 26, 2014 | Kenmore 73952 Gas Dryer
Stops and all the lights come on
Instructions
    • 1 Make sure the home's gas supply valve is turned on. Check your Maytag owner's manual to find the location of the dryer's gas shut-off valve. This is usually behind the dryer's front panel or in the back of the unit. Open the valve to allow gas to flow into the dryer.
    • 2 Open the lower front panel of the dryer to access the pilot light assembly. Press and hold the starter button as you light the pilot with a handheld lighter. If you have trouble getting it to light, release the starter button and wait a few minutes before trying it again. Once the pilot is lit, hold the starter button down for another minute to make sure it will stay burning.
    • 3 Close the dryer's front panel and run a test cycle to see if it is producing heat. Call a repairman to evaluate the problem if lighting the pilot did not restore the heat.
Jan 15, 2013 | Kenmore Dryers
Dryer won't stay on
The motor centrifugal switch is not switching from the start winding to the run winding. The switch should stay in the run winding when the motor picks up speed unless power to the motor is interrupted or cut off. The switch is replaceable on most dryer models but sometimes it is an integral or built-in part of the dryer motor and failure of the switch requires the replacement of the motor. Indicate the exact model number of the dryer for more accurate troubleshooting and repair advice.
May 24, 2010 | Kenmore 63932 Electric Dryer
Dryer will not stay running
CHECK THERMAL FUSE #3392519 @ $15.00...RDS
Apr 21, 2010 | Kenmore 63942 Dryer
Kenmore gas dryer doesn't stay on
I think it is probally the thermocouple not holding letting gas valve work properly, timers do not go out very often, its not getting hot enough to release the gas, valve wont let it, chheck thermocouple, let me know im not there, but its in the heat not getting hot enough
Feb 25, 2010 | Kenmore Dryers
Dryer noise sounds like bearing out or a roller is bad model # 417-98702891
my dryer makes a funny noise about 10 to 15 min. into cycle. then shuts off. if you try to restart will not restart unless you hold start button down. once you let go will stop. wait about an hour and dryer will run for another 10- 15 min and start process over again.
Feb 22, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Dryer (Model #11073952101) starts, but WON'T stay ON
your motor maybe going out. theres a switch on the motor that starts it . on most models the start switch is built into the motor. however some models the switch can be replaced by itself.
Aug 30, 2009 | Kenmore 73952 Gas Dryer
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
Kenmore 73952 Gas Dryer Logo
648 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
