Question about Kenmore 15129 Built-in Dishwasher
Kenmore Dishwasher does not wash
We recently installed new kitchen cabinets. We had to take out our dishwasher. Once the cabinets and counter tops were installed, we reinstalled the dishwasher. (It was uninstalled for about 8 weeks) We turned it on and the water started going in just fine. We noticed that the "wash" cycle never started. After 5-10 minutes, the water was then drained/released from the washer. Then the water for the next rinse cycle entered the system. Once again the "washing/rinsing cycle did nothing. Later once again the water was release. Eventually the "green" wash complete light came on like it had finished. We opened the door and the dishes were still dirty. We then closed the door and the green light started to blink and now the start button will not start the machine. The green light continues to blink. Any thoughts or information would be appreciated.
  • 1 more comment
  • luv2kidz Nov 15, 2007
    Please help! We had some tiles repaired in front of our dishwasher, I started a cycle and about 1 hour later I went to check and it was no longer working- no power at all. There is water at the bottom inside and it is starting to stink. I checked all wiring up front and everything looks secure- it wasn't moved at all. I can't find my darn manual to look for the restart button. Any suggestions would be GREATLY appreciated. Thanks.
  • Anonymous Jan 17, 2008
    I have a similar problem. I had to move the dishwasher and now the clean light just blinks and the washer will not work.
  • Anonymous Mar 13, 2014
    i get an e15 code on my dishwasher mid cycle, i have done the tilt and it reset the dishwasher and let me start a new cycle . now when I turn on a cycle it starts gets 5-7 minutes in the gives the error code e15 again the water is on pipes unkinked and dish washer seems to work for the first few minutes , washing then draining.
My problem is the motor hummms for a minute or so and turns off. Could this be the capacitor? how do you test a capacitor?
herb
Posted on Jul 14, 2008
    President:
  • 878 Answers
Stew, Im not really sure what model you have 665, 587, 363 or what. If it's a 665, it sounds like the wash motor is not getting power. Remove the toe panel and look at the start capacitor. See if one of the wires came off during the reinstallation. Should be on the left side of the wash motor. If one of the wires is off, wash motor won't run. If that's ok, check the main harness to the motor. Catriver
Posted on Sep 17, 2007
SOURCE:
Healeyman
  • 1198 Answers
SOURCE: dishes not clean enough. as if rinsing in dirty
If your dishwasher drains it's water to a garbage disposal, give the disposal a spin while the dishwasher is pumping out. Check around the bottom of the dishwasher to make sure something is not clogging the drain.
Posted on May 01, 2009
rylee_smith
  • 8619 Answers
SOURCE: doesn't seem to rinse completely; soapy film left on dishes
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Posted on Oct 05, 2009
ginko
  • 19396 Answers
SOURCE: Kitchen Aid Model # KUDP01ILWH2 Dishwasher dishes
Hi.
Using too much rinse aid will not work. Stick to user manual factory prescriptions. If you use correct amount of rinse aid, and the right product for your dishwasher, that is not the cause of the stains.
Ensure that you are using the right detergent along with rinse aid. Check specifications on manual.
Ensure that the drain well is clean.
Ensure that spray arms have enough pressure, check water level and impeller pump.
If you still get stains on dishes, and you are sure that they had been caused by limescale, that means that the water in your house is too hard. This will also damage your appliances in the long term, causing faults due to accumulation of limescale and rust.
The best thing to do is installing a water filtration system on the appliance inlet.Call your local appliance shop or technician to discuss about the problem and purchase a filtration system for your appliance.
Posted on Apr 08, 2010
  • 677 Answers
SOURCE: Doesn't clean properly. fills with water, washes and Rinses.
www.dishwasherfilter.com will solve your problem. its hard water causing the spots and not your dishwasher.
Posted on Jul 10, 2010
SOURCE: I have a ADG450 about
check the pipe leading from the dishwasher to the outlet, maybe under sink. this needs to be raise up as water will flow back into washer. Had this problem myself, felt foolish when the repair man just tied it up and left. !
Posted on May 12, 2011
How do I mount Kenmore dishwasher model 65515779 to granite counter top?
Joanne,
You need a granite/stone counter-top mounting kit. It will be a metal strip that you can attach to your cabinets and allow you to screw some short screws up into that metal strip. I would think that most major home repair dealers would have something like that. Dishwasher Undercounter Mounting Kit W10426979 The Home Depot
May 13, 2015 | Kenmore Dishwashers
Why won't the door latch?
Make sure the door is not hitting the sides of your cabinet. Also make sure it is not hitting the screws that hold the mounting tabs (located at the top of your dishwasher) to your counter-top. If that's okay, try removing the racks and see if the door will close then. If still no, then you might have a broken latch or bent or broken hinges.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jul 05, 2014 | Kenmore 24 in. 15932 Built-in Dishwasher
I have a new kitchen aide dishwasher. Does any of the insulation padding come off before installation
No. It is supposed to remain on the dishwasher. It helps cushion the machine noise from vibrating through your counter.
May 26, 2012 | KitchenAid Kitchen Aid - KUDC10FXSS...
Water will not come into tub to start washing dishes
Paul,If this dishwasher has just been installed or there has been some plumbing work done in the sink cabinet. Please check the shut off valve for the water going to the dishwasher. it is connected to the hot water pipe in side on the sink cabinet. if the shut off valve is already turned all the way to the right it is in the closed position. This would mean the water is off. turn the valve to the left to turn the water on.This is very common after new counter tops are installed.Please also check water line going to the dishwasher to be sure it is not pinched
Hope this helps
Nov 10, 2011 | Frigidaire Dishwashers
What are the product dimensions
Hi and welcome to FixYa, I am Kelly. The installation guide with the dimensions can be found here:
http://www.managemylife.com/mmh/installation_guides/3932/KENMORE-Dishwasher-L0504234?brand_name_search=665.15952 (7.87 mb file)
The top of the cut out is 33 & 7/8" Min. to 34 & 7/8" Max (adjustable legs for height)
Minimum space to counter top parent material 1/4" (Top of dishwasher cabinet is screwed in at the top)
Depth 24 & 1/4 inch minimum
Width 24 & 1/4 inch minimum (Allows for 1/8" clearance on both sides)
Thanks for choosing FixYa,
Kelly
Feb 22, 2011 | Kenmore 15952 Dishwasher
How do I properly secure the dishwasher to the cabinets so it does not move when I'm unloading it?
The feet should be properly leveled and either secured from the top to the counter top using 1/2" screws or in the case of granite tops use side mount brackets and pre drill holes in the cabinets to prevent splitting. The side mount brackets usually come with the dishwasher but you might need to order a set. Here is a video on properly installing a dishwasher http://appliancehelponline.com/dishwasherinstallvideo.html
Aug 17, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
I have a Whirlpool integrated dishwasher ADG 7560/1. Can you tell me if there are any points where it should be screwed to my kitchen unit sides or surface to stop it moving when I open the door. Thank...
There should be two metal tabs on top of the exterior cabinet that you use to screw the dishwasher to the underside of the kitchen counter top. The feet are also adjustable on most models so they are not only level, but also to make the unit fit better inside the access opening under the cabinet where it is installed.
Aug 13, 2010 | Whirlpool Dishwashers
Kenmore Ultra Wash III Dishwasher will not drain properly
Fixerfailure, is the knock-out plug still inside if the garbage disposal inlet?
Stick a screwdriver in there to make sure.
spazmo1969, could be the rubber flapper is broken off in the pump discharge outlet.
Dec 27, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Water gets into disher when not inuse
dishwasher drain enters sewer system tapped into waste pipe below kitchen sink
water flowing from kitchen sink passes the opening of the dishwasher pipe
If the dishwasher hose does not loop up higher than the kitchen sink before going down to the bottom of the dishwasher water may flow downhill through the dishwasher drain into the dishwasher
ensure the dishwasher drain hose is screwed to the underside of the kitchen counter, to provide a stop to water flow.
The installation instructions suggest this
but often the dishwasher is at the end of its 'stretch'
and the installer assumes looping is just to use up excess hose, and doesnt.
an extension drain hose is available at most appliance stores
Oct 27, 2008 | Kenmore 22422 Top Load Washer
Kenmore Dishwasher installation
taking astab at this but your kit floor has been replaced and to close to counter now????, your either shimming up counter or removine the floor from under d/w
Mar 11, 2008 | Whirlpool 24 in. GU1500XT - Multiple Color...
Kenmore 15129 Built-in Dishwasher Logo
1,036 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
