Question about Onkyo DX-7555 CD Player
Onkyo DX-7555 Cd player malfunction
Sometimes the CD player doesnot read the CD, and sometimes the CD player stops. The problem is intermittently.
bluenadas
  • 203 Answers
SOURCE: cd tray mechanics
It can be repaired but in all of my years in consumer repair, I dread the CD/DVD tray alignments the worst.
There are many things involved in getting them to operate without fail. Using the mfgs documentation you can get them up and running but most of the time they failed because something is amiss to begin with. So you spend an hour getting everything setup and it will work once or twice but them fail. Only to find out that a location sensor is bad or a gear is missing a tooth....
Posted on Nov 21, 2007
SOURCE: ynex Wireless Optical Mouse DX-WOM100 - Mouse doesnot recognize
pls send solution
Posted on Sep 19, 2008
SOURCE: Onkyo DX-C200 cd player
I have a Onkyo DX-C200 cd player face plate for $25.00. cyberhe@optonline.net
Posted on Oct 26, 2008
SOURCE: Onkyo 6 disc cd changer DX-380 has CD stuck under carousel
This has just happened to us. Often when the changer tries to select a CD on random play, it somehow knocks one CD off the carousel, usually on top of the other 5 CDs and then you can retrieve it easily. This time it knocked it down behind the carousel so the drawer could not close. We left the drawer open, carefully took the player out and tipped it upside down and then tipped it forward. We then closed the drawer while it was still upside down and then turned the player back up the right way. The loose CD fell onto the carousel and we could then open it and retrieve the CD. No damage to either CD or changer and we are now listening to music again!
Posted on Mar 04, 2009
petraman7
  • 1175 Answers
SOURCE: Servicemanual for Onkyo DX-7051
http://www.user-service-manuals.com/onkyo/index.shtml
Posted on Apr 07, 2009
2004 Toyota Corolla Verso has intermittant sound and control problems. The radio will play fine and suddenly the sound will go off as well as the back lights illuminating the radio face and knobs.trying to...
The problem sounds like intermittent power supply. There might be an inline fuse which sometimes does cause problems. Remove the radio and check the power line to see if there is such a fuse. If so, remove and clean it with a bit of sandpaper, put it all together and see if it helps.
Sorry, can't be more helpful.
Aug 29, 2017 | 2004 Toyota Corolla
Intermittent display. sometimes none, sometimes partial.
hit the thingymajiggermabob inside of it with a hammer than it shall work if not get a new one problem solved
Dec 19, 2010 | Sony CDP-CA8ES CD Player
The player only intermittently recognizes CDs inserted; it does not seem to make any difference whether they are commercial, recorded at home, etc. Sometimes it says "insert disk," sometimes "no disk." ...
A CD tray is usually powered by a rubber strap, the belt can slip through, causing the electronics to miss the input timing, including a microswitch or copper contact which is activated at the closed disc tray so that the laser is focussed to read the table of contents Due to the fact that the spindle motor is activated. And in some players (interchanges there is also a selects witch that can be contaminated. a suggestion to help in the link
How to Fix DVD or CD Player That Won Open
Jun 30, 2017 | Philips CDR950 CD Recorder
American Audio Mcd-810 dual cd/mp3 player
i know its the tray belt.because,the same thing happened to me.my player would sometimes say error. or sometimes it would not read any cds.because,the tray would not close tightly.im shure its an easy fix.i did mine by my self.
May 31, 2009 | American Audio Mcd810 Dual Mp3 CD Player...
Cd player malfunctioning after cd lens cleansing
Ive replaced sooo many Bose systems for that very same reason. Id replace radio. Problem with Bose radios sometimes have no amp inside radio and if you replace the radio, you have to replace the entire system, very expensive, depends on year of vehicle too.
May 14, 2009 | Car Audio & Video
Cd drive
Try using a DISC cleaner because sometimes the cd drive is dirty that's why you have that problem.
May 12, 2008 | Onkyo DV-CP704 DVD Player
Player does not reliably repeat
1. Laser dirty.
2. Mech stiff.
3. Laser faulty.
capital98
Dec 21, 2007 | Sony CDP-CE375 5-Disc CD Changer
DVD cannot read DVD's anymore
Have you tried cleaning lense with soft cloth and alcohol? Sometimes cd or dvd cleaners do not work well for some systems.
Aug 30, 2007 | Durabrand DUR-1700 Portable DVD Player
My VCD player doesnot recognize a cd
Try cleaning the laser lens with a cleaning disk like you might find a Wal-Mart or Radio Shack and see if that helps. If the lens on the laser is too dirty to read that it has a disk then it will not attempt to spin the disk. If cleaning doesn't solve your problem then it may be a much bigger problem like weak laser etc. Good luck.
Jan 28, 2007 | LG ADR-620N CD Player
Onkyo DX-7555 CD Player Logo
138 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
