Question about NetGear WGT624 Wireless Router
Netgear installation I tried to install a Netgear router in my laptop for wireless connection but when I plugged it in, the status says that I am connected to Internet but I cannot surf online. What can be the problem? How to install the netgear correctly so I can use wireless on my laptop and my pc in another room? Thanks.
  • piska Sep 28, 2007
    Thanx for reply. I sorted out by phoning the netgear customer service. I couldn't believe that I was so stupid and didn't set up the Netgear Wizard first. I did the 192.168.1.1 but did not set up a wizard installation. So now it's working perfectly well. Thanks again for the link. I may use it for the future!
  • 46 Answers
Have a look at this site it will help you http://www.lycoming.edu/acad/Netgear%20Wireless%20Router%20Setup.htm
Posted on Sep 17, 2007
  • Anonymous Sep 28, 2007
    if that hasnt cured it try changing the frequencies on the laptop until one works my friend just had the same problem and that cured it
    regards
SOURCE:
I am trying to set up my Avertec N1200 laptop with Windows XP to my Netgear wireless router. The router does not have a USB connection, but I have a Netgear wireless USB adapter. Also, I am getting the msg...
The Netgear Wireless USB adapter should be connected to your Avertec N1200 laptop to act as a wireless antenna. The driver for your Netgear Wireless Adapter should also be installed on your laptop. Once installed, click on the Windows Orb button on the lower left corner of your screen and go to All Programs. Look for the installed program for your Netgear Wireless Adapter to open up the wireless utility of your wireless adapter. That's where you should connect the wireless connection and not on Windows Wireless Manager.
Aug 27, 2011 | Computers & Internet
Hi I have installed a netgear wireless usb adapter wg111v3 onto a PC (on another PC i have a netgear DG834GT router). After installing the adapter the "signal strength" is EXCELLENT and the "status" is...
You might not be getting a correct ip from your wireless router.
first, try to power down the computer and your netgear router for about a minute or two. turn the router on first. once the lights are stable on the router, boot up your computer. if your still not able to access the internet. try this
go to start > control panel > network and internet > network connections or network and sharing center > right click on wireless network connection and go to properties > highlight "internet protocol version 4 (TCP/IPv4)" > left click on properties, the wireless network connnection properties will then be opened.
make sure that the radio buttons are on "obtain an ip address automaticaly" & "obtain DNS server address automaticaly".
Sep 17, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Installation of netgear dgn2000 wireless router on vista.
I understand that you are facing trouble with the installation of the router as the CD does not work. Please perform the below steps to install the router without using CD:
1. Connect the cable/phone line coming from Internet Service Provider to the WAN port of the router(isolated port).
2. Connect the computer to the router using any one of the 4 available ports.
3. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
4. Access the router, usually by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
5. Login to the router (username = admin password = password unless you have changed it).
6. Click 'setup wizard'(at the top of list) from left menu.
7. Select yes and click next.
8. It should give you a "PPPoA Detected" and then click next.
9. Enter the login and password of ISP click apply.
10. Once the settings are updated click on 'router Status' and click on 'connection status' button(at the bottom of the page).
11. Click on connect button.
12. Connecting to server should show 'connected'.
13. If you receive 'CHAP authentication failed', close the 'connection status' window and click on 'Basic settings'. Check the login and password for ISP and apply the setting again.
14. Open up another browser window and try to access internet.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jan 04, 2010 | NetGear DGN2000-100NAS Router
I have bought a laptop from someone and it has a edimax EW-7305Pg wireless LAN Cardbus. I am having problems connecting it to a netgear wireless router supplied by sky. I have sky broadband. I uninstalled...
is the mac address registered through your wireless router, your router maybe running wireless mac filter, if not try registering your wireless mac address on your router then try reconnecting your computer to your router.
Feb 01, 2009 | Computers & Internet
Problems connecting my laptop to wireless router
Make sure that you do the setup via cable, not through wireless!
If you change form WPA to WEP, the length of the key changes and you will have to provide this new key if you want to connect wireless to your router.
You can leave your laptop connected via cable and check if your wireless card can connect.
No, you don't have to reinstall everything again. Just plug in the cable, connect to your router (192.168.x.x) and check your wireless setup.
Dec 28, 2008 | NetGear WGR614 Wireless Router
Problem linking my wireless laptop into newly installed network
you may have to turn on the wireless feature in the router.netgear will help you to fix it.go to their site or call them for help.
Jan 07, 2008 | NetGear DG834G Router
Wireless connection
NETGEAR Technical Support Engineer 1. access 1st the router's setup page * open up a browser * http://192.168.1.1 or http://www.routerlogin.com/ 2. go to wireless settings under setup if you have a wireless phone at home change the channel of the router, make sure they dont have same channel 3. change the mode of the router to w/c your laptop's wireless adapter support (eg. b only, g only ) 4. try to change security option wpa instead of wep (make sure your laptop's adapter support it) 5. change SSID (note: if you've change the SSID of the router, remove the profile on your computer under preferred networks 6. change your passphrase 7. Disable Advanced 108Mbps Features 8. Disable Setup Access List (it can be found in wireless settings under advance) 9. upgrade firmware of the router * before upgrading make sure you backup the settings (go to backup under maintenance) * if latest firmware is installed * flush firmware (flushing it is just reinstalling even if the latest firmware is installed) 10. power cycle frequently (turn off for 10 seconds then turn it on again) 11. If all of these didnt work call your laptop manufacturer for help 12. call gearhead -> 1-888-615-3488 13. or call our technical support 1-888-netgear lucky if you got me ***caesar *** NETGEAR technical support engineer
Feb 13, 2007 | NetGear WGT624 Wireless Router
NetGear WGT624 Wireless Router Logo
175 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
