Question about Dryers
When you press the start button the dryer hums and doesnt turn
Dryer hums and wont spin its a frigidaire electric LEQ2152EE1 series
  • 221 Answers
Check the fuse's and or breaker's to make sure on of them is not blown or tripped, check the belt to make sure it's not broken and check the tensioner, check to see if the drum spin's with little or no friction, if there are no blown or tripped fuse's and belt and tensionet are good the motor may be burned out.
Posted on Apr 18, 2009
  • 32 Answers
First thing you need to do is open the door and try to rotate drum by hand it it is not turn by hand that mean there is some thing stack in your blower fan. if you can turn the drum by hand you need two people to check this problem..one open the door there is one push button, push that button and hold now second person need to push the start button when you heard hums sound the turn the drum by hand again if your dryer stat spin that mean you have bad motor. (forgive me for my english)
My Frigidaire Affinity electric dryer will not start. Its only just over 2 years old. the timer counts down but the drum will not turn nor is there any heat. I've tried jumping the dryer but it still will...
Listen, when you push the start button to hear a low hum, if you do hear this it maybe that your belt is broken. This is an involved job but can be done if you are handy.
Jan 22, 2011 | Frigidaire AEQ6000ES Electric Dryer
I have a Frigidaire Affinity dryer that shows power but when I press start it has a humming noise and wont spin.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 01, 2010 | Frigidaire Affinity AEQ6000WH Dryer
Press the start button on dryer, it hums but wont turn. With 2 people pressed the start button again, held the door switch, reached in turned the drum, it hummed stopped humming then no more nothing....
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
Dec 27, 2009 | Dryers
Will not turn on when I turn to ''start''. I can hear the motor hum but the unit will not start.
i have afrigidaire electric dryer all electronic control panel when i push the start button i hear a click from a relay on the control panel. but does not start or spin.thougth it was the motor i replace it with the new one it still the same.does not do anything
Oct 30, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Dryers Logo
510 people viewed this question
Top Dryers Experts
