Question about Onkyo A-9555 INTEGRATED DGTL AMPLIFIER (BLK) System
Remove terminal caps
I have an Onkyo A-9555 amplifier and I can not remove the speaker terminal caps in order to connect banana terminals. The cap is flat and doesnot have any slot or anything to remove it. Please help...
    Brigadier General:
  • 8,546 Answers
They should just plug into the ends of the caps without any modification as this quote from the features section of the manual implies...
Banana Plug-Compatible Speaker Terminals
Posted on May 05, 2009
Onkyo shorted speaker
Hello
Disconnect the speaker connections and switch ON the set. Set a multimeter to measure volts, and measure the voltage acorss the shorted speker terminals at amplifier end. There should not be any voltage at all. That is, the voltage measures at the speaker terminals must be approximately equal to Zero. If hter shows any voltage, make sure that the output amplifier to that side is shorted. never connect an other speaker, even for checking. It will also burn out.
Connect speaker to this channel, only after rectifying the fault, if any.
Feb 06, 2012 | Onkyo TX-SR500 Receiver
Tip
How To Bi-Amp And Bi-Wire Speakers!
What is the difference between bi-wiring and bi-amping?
Bi-wiring is using the same power source (amplifier) but separately connecting that power source to a woofer and a midrange/tweeter on a speaker.
Bi-amping is using two separate power sources (amplifiers) and connecting one amplifier to a woofer and the other amplifier to a midrange/tweeter on a speaker.
How do I bi-wire?
Your speaker must have two separate positive and negative connections (one set for the woofer and one set for the midrange/tweeter). Connect one wire between the positive terminal on the amplifier/receiver the positive terminal on the speaker. Connect the other wire from the negative terminal on the amplifier/receiver to the corresponding negative terminal on the speaker. Remove the jumper straps connecting the two sets of speaker inputs. Repeat this process for the second set of terminals on the speaker, connecting them to the same positive and negative terminals on the receiver/amplifier. Repeat the steps for each speaker you wish to Bi-Wire, connecting them to the appropriate terminals on your receiver/amplifier.
How do I bi-amp?
Bi-amping is similar to bi-wiring, but involves separate amplifiers: one for the woofer and one for the midrange/tweeter. Passive bi-amping involves a direct hookup between each amplifier and the speaker terminals. True bi-amping involves hooking the preamp to an electronic crossover that replaces the passive crossover network in the speaker. The active crossover then connects to multiple power amplifiers.
on Jul 13, 2010 | Audio Players & Recorders
I do not see any inputs to connect a subwoofer to my Onkyo A-9555 integrated amp. I would like to know if it is possible to connect it and what kind of subwoofer should I buy for that wit the best...
You amp has no OUTputs for a sub, but if you really want to attach a sub you'll need to get one that is self-amplified and accepts >>>stereo<<< High Level or Speaker Level inputs.
Otherwise your amp's volume control won't also control the sub's volume.
You would feed it full-range audio from the speaker terminals on your amp and its internal amp would use that to develop its own power output for the sub.
Here's one example.
http://www.ch.onkyo.com/files.download/skw-205_manual_e.pdf
Jan 29, 2011 | Onkyo A-9555 INTEGRATED DGTL AMPLIFIER...
Can i play only 2 speakers throuh my surrond onkyo amp?
Of course you can use 2 speakers with your Onkyo assuming you will not hear the surround effect. Just connect your speakers at Speakers A terminals and go on.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "flags".
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 05, 2010 | Onkyo A-9555 INTEGRATED DGTL AMPLIFIER...
How do I hook up banana plugs to a infinity PC 350 speaker
The illustration in the manual I found at retrevo.com isn't detailed enough to show the axial connection option, which would normally accept a banana plug inserted straight in if the opening is conductive and about 4mm wide. I suspect it is as they mention a "variety of wire connectors".
Their only illustrated example show bares wire ends inserted into a small hole drilled through the termial post and the red or black plastic piece tightened down to secure it.
WIRING THE SYSTEM
IMPORTANT: Make sure all equipment is turned off before making any connections.
For speaker connections, use a minimum #16-gauge speaker wire with polarity coding.The side of the wire with a ridge or other coding is usually considered positive polarity (i.e., +).
NOTE: If desired, consult your local Infinity dealer about speaker wire and connection options.
The speakers have coded terminals that accept a variety of wire connectors. The most common connection is shown in Figure 5.
To ensure proper polarity, connect each + terminal on the back of the amplifier or receiver to the respective + (red) terminal on each speaker, as shown in Figure 6. Connect the – (black) terminals in a similar way.
See the owner’s guides that were included with your amplifier, receiver and television to confirm connection procedures.
IMPORTANT: Do not reverse polarities (i.e., + to – or – to +) when making connections. Doing so will cause poor imaging and diminished bass response.
Feb 20, 2010 | Infinity PC350 Center Speaker
I have a 1600 watt amplifier wiring kit w/0.5f digital stiff cap and it has no instructions how can i get some?
Place the amp where you are going to permanently mount it. The cap. should be as close to the amp as possible. Run the positive cable from the pos. terminal of the battery to the pos. terminal on the cap. Then from the cap's pos.terminal run a cable to the pos. terminal on the amp. Dont install the fuse into the fuse holder just yet. Make sure you place the fuse holder at most 10 inches or closer to the battery. Find a good ground point to run the negative cable to the cap. make this one as short as posible, use any good solid metal part of the car's chassis or bolt that runs into the body. Run another ground cable from that piont or nearby point to the amp's negative terminal. run the rca cables from the back of the head unit outputs to the inputs on the amp. Then run the small gauge remote wire from the amp remote output from the head unit to the remote turn-on terminal on the amp. run your speaker wires from your amp to your speakers. Install the fuse, it will spark a tiny bit when installed, its normal thats just your stiff cap and the caps inside your apm charging. Usually you charge the cap before you introduce it into the system to prevent that spark but a cap that size doesn't create a huge spark. good luck
Nov 18, 2009 | Car Audio & Video
Amp protection circuit has been activated
sometimes the protection circuit will enable because of a bad speaker i would suggest taking the load off of it by removing the speaker wires and turning it back on. if it stays on take an ohm meter and check the speakers should be between 2-4 ohms load.
May 01, 2009 | Onkyo A-9555 INTEGRATED DGTL AMPLIFIER...
Can't connect amp to speakers
MOST amps have a small plastic plug in the center of the amps speaker output sockets use a small screw to pull these out.
CABLE GUY.
Feb 22, 2009 | Cambridge Audio Azur 540A Amplifier
Speaker distortion on high end
Sounds like classic dry joint on speaker terminal ROTELS are well known for it,if you can use a soldering iron or know someone who can resolder the pins where these terminals are connected,always make sure amp is unplugged from wall socket before ...
Dec 18, 2008 | Onkyo M-282 2-Channel Amplifier
Onkyo 9555 protection circuit
Make shure your speaker wiring is solid hookup to amp and spekers (NO CROSSED WIRING). Also make shure speakers are not wired in parallel or the speaker impeadance will be to low and amp will kick out.Turn speakers off then hook up headphones and crank up volume then see if amp kicks out.If it does you have an internal overload and needs serviced. If it playes ok then you must have speaker problems or wiring.
GOOD LUCK
BIGREDl
Mar 26, 2008 | Audio Players & Recorders
Onkyo A-9555 INTEGRATED DGTL AMPLIFIER (BLK) System Logo
429 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
