Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
Trouble with my Seagate Barracuda 7200.7 hard drive
I was installing widows and I lost power while formatting the partition. Now when I boot the computer I get an error loading operating system message.
  • andrew361 Apr 18, 2009
    I did start from scratch and I keep getting the same message, "error loaing operating system", after I hit any key to boot from CD
    Windows starts to boot up when I unplug the hard drive. So I assume it is not the CD. Any help offered is appreciated.
  • 272 Answers
You should reinstall the operating system. Anything less may not help you. if you would provide, which wrive the os was and which one you were formatting, would help to provide more helpful solution.
Posted on Apr 18, 2009
  • Fixer Apr 18, 2009
    May be the setup cd is not 100% ok. please try another if possible or wipe it with cd cleaner or glass cleaner.....it might help.
    Sorry, if you dont like the solution :P
    If you have another pc, i think you have as you are able to write here, please add this HDD to that one. See, if it is working ok or not. If is working ok, try delete and recreate the c:.
  • 537 Answers
Start from scratch. Start the installation from the beginning
  • Mike McWhinney Apr 18, 2009
    When you boot up, unplug your removable hard drive. Your computer is trying to boot off it and finding no OS it reports missing operating system or similar error.
Bios cannot read hard drive
Hi Robert,
IT could be that the Barracuda drive is formatted for boot up. I would boot up with the drive that boots, and make the Barracuda a spare drive, so you can go in and first see if has any issues as a drive,(meaning sector 0 errors, and if you can access it, then you can format it as a boot up drive, or get what data on that drive off for your friend.
Good Luck Mark
Sep 01, 2014 | Seagate 1TB Barracuda Internal Hard Drive...
Hi I have a Seagate Barracuda ST2000DM001 2TB 7200 RPM 64MB Cache.It runs fine for a bit then it just diconnect itself,so you have to scan for hardware or you have to reboot the system.Is there a fix for...
Test your HDD (Hard Disk Drive): go HERE, click Downloads and download Seagate Seatools for DOS (free). Burn the ISO to a CD, set your 1st boot device = CD drive and reboot with the disk in the drive. When the tester loads, choose the Quick Test in the upper left corner of the screen. It takes 5-10 minutes and will give you a pass or fail. If it tells your that SMART has tripped, or gives a fail notice, your drive is failing. You should have a warranty on that drive with Seagate.
If the drive passes as good, change your data cable. I have seen bad cables cause problems. Also check the power cable.
If you still have problems, enter Administrative Tools\Disk Management. Find your drive, Right click on it, and click "Mark Partition as Active".
If still no joy, try changing the SATA port on the mother board that your drive is plugged in to.
If still no joy, contact Seagate customer help, they are very good.
Oct 08, 2013 | Seagate Barracuda 7200.10 / 500GB / 7200 /...
When I try to instal a windows vista on my computer it says that I should load the hard drive's driver. I don't have such a thing and I can't find it anywhere. I have a Seagate ST3160812AS Barracuda 7200.9...
i was wondering are tying to install additional partition or you wanted a dual boot? or simple want to install WVista completely from scratch? normally what you need to do is hit F12 go to boot menu then your bottable CD should be on the CD/DVD drive already and re-format your hard drive...
Aug 11, 2010 | Seagate Barracuda ST3160812AS...
Seagate barracuda external 500 gb hard drive usb not seen any longer,cables and power okay , tried on three computers
Verify what Drives have been detected by your Operating System by using Windows: Control Panel -> Admistrative Tools -> Computer Management -> Disk Management -> Your Hard disk(s) will be displayed with all existing partitions and any assigned drive letters.
Your external (or internal) drive must be recognized as having formatted partitions that have a drive letter assigned to each required partition.
Hope it helps: let me know how you go!
Dec 30, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Barracuda 7200.7
Hello Sir,
While windows is booting first go to BIOS settings by pressing "Del" or "Esc" then change the boot priority that is save the first boot priority as cd-rom and second boot priority as hard drive... so that you can boot you system with bootable cd...
And then while formating the system just delete the partion that is only "c:/" and install the windows in to that and don't even do anything to your "d:/" drive then you can get all your data back... Abd the cd should be bootable format...
Aug 22, 2009 | Seagate Barracuda 7200.7 Hard Drive
I have a seagate barracuda 7200 7 40GB, with 2 partitions: 1-(c:/)WindowsXP, 2-(d:/)for save my personal files.At PC startup, the message that appears is missing OS. BIOS detected HDD, but Windows CD no,...
you can take backup of D drive om other computer .
Conect your harddrive to that other computers CPU but make sure that your hardddisk is slave which has issue you can set slave your hdd with jumper read on harddisk.
then connect it to cpu with SATA or IDE .
Then winxp find that all partition then take backup.
AND IFyou haven't other computer you need winxp bootable disk.
Boot your computer with winxp disk then follow the procedurer then you see on screen
your old winxp for repair then when it ask for "r"
Presss "R"
thats it.
Thwen it repair your winxp then you can use easily.
Aug 22, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
I cannot install windows xp sp2 on my seagate barracuda 72000.10 500gb hard drive
I would suggest you go to the seagate website and download and burn out their hard drive test. run the test from boot and see if it detects a bad hard drive after it runs
Jul 11, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Barracuda hard disk 80gb
the first boot sector of the hard drive is corrupt so fdisk wont work
please use software to repair the boot sectors zero and 63.
usually the softwares are superfdisk which is free on net.
also if you fail use seagate disk manager bootable version. it will be very quick and handy in long term too to format seagate hard drives
Sep 17, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
It recognizes the new hard drive as a DVD drive
have you partitioned and formated it ? unless you do that to the drive it will not show up with a drive letter in windows. go into control panel, administrive tools, computer management, disk management - there you should see all your drives and you can partiton, format, assign or reassign drive letters to them. hope this solves your problem.
Apr 18, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Ultra ATA HDD
you can use partition softwares such as PQmagic to solve this problem
Dec 20, 2007 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
240 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
