Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Cannot get ice out through the door
The lock on the door is unlocked the green light on cube ice is lit up no ice will come out the green light for crushed ice is lit up but no ice will come out
I have not fixed it yet i expected to get help here guess i was expecting too much
Posted on Apr 18, 2009
My power locks will only unlock with the exception of the rear switch. Can you tell me the location of the lock relay so I can check it.
  • Aux Relay Box #4 is in the rear driver's side removable panel with the tire jack. This Relay box holds the Door Lock / Unlock relays (ice cube type). It also holds the Driver Door Unlock Relay and the ACC Lights Relay (rectangular relays).
  • Nov 21, 2010 | 1999 Ford Explorer
    Where is the door lock relay located on a 1999 ford explorer? Electric door locks blows fuses. After replacing a fuse, the door locks will only work for a short time then blows fuse. I know the fuse/relay...
  • This Relay box holds the Door Lock / Unlock relays (ice cube type). It also holds the Driver Door Unlock Relay and the ACC Lights Relay (rectangular relays).
  • Oct 17, 2010 | 1999 Ford Explorer
    Can not figure out which relay for the power locks in my 1997 ford expedition
  • If you have an owners manual it will show you too.
    Sep 02, 2010 | 1999 Ford Expedition
    How do I unlock the ice-maker panel?
    Press the lock again to unlock. If the second padlock is on, press and hold for 3 seconds to unlock the child lock.
    Jun 28, 2010 | Bosch Evolution 800 B20CS80SNS Stainless...
    Where is power door lock relay on 1999 ford explorer does not lock with switch does open with switch
    Found this answer in anotherr forum and works for me. Power Door Lock Relay Location
  • Sep 03, 2009 | 1999 Ford Explorer
    Cubed Ice selected, crushed ice comes out
    ice maker works. water thru the door works. lock works. light works, alarm works.
    when i try to get crushed, ice cubes or quick ice.
    nothing happens
    Aug 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    Cannot get ice out the door
    check to see if theres a bad connection where the wires come from the freezer door and the frig itself under the upper hing cover
    Apr 21, 2009 | Refrigerators
    Icemaker stopped making ice.
    make sure you can see the green light is on which means you have power. if its lit,press and hold the cube size button untill i/m starts to cycle if i/m runs but does fill then your water valve is bad, if i/m will not start then your i/m is at fault
    Dec 13, 2008 | LG LFX25960ST Stainless Steel French Door...
    Ice maker does not dispense cubes
    THE SOLENOID IN THE ON THE ICE MAKER MOTOR IS NOT WORKING IT HAS ICE BUILD UP ON IT OR IT HAS A SHORT IT PULLS THE PLUNGER THAT OPENS THE FLAP THAT LET ICE CUBES FALL OUT. REMOVE ICE MAKER AND THER ARE 2 5/16 SCREWS THAT HOLD PANEL IN THEN UN PLUG MOTOR AND USE HAIR DRYER & DEFROST MOTOR AND SOLENOID SHOULD WORK IF NOT MAY NEED TO REPLACE SOLENOID.
    Dec 22, 2007 | GE GSS20IEP Side by Side Refrigerator
    Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
    80 people viewed this question
    Top Whirlpool Refrigerators Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Dan Webster
    Dan Webster
    Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
