Question about AOpen MX36LE-UN (91.89Q10.101) Motherboard
Aopen mx36le-un motherboard replaced
Replaced MB with another exactly the same[used one off ebay].Followed troubleshooting manual on fixya page 95-98.Powered up MB with no cables,fine pressed CLT/ALT DEL MB rebooted fine.Turned off power connected ide cable rebooted,on screen says dectecting ide drives ....... nothing eles.
I can hear from HD a continuous faint beep sound.
Could i get your opinion,anything i have missed.
Thankyou Jason
    Sergeant:
    Novelist:
  • 197 Answers
If your HD is connected via IDE (a wide, flat cable) try reversing it. If not, go into the bios and make sure that your SATA ports are enabled, all IDE functions etc.
If not, your drive could be fried. If you have another computer to test the drive in, that would be handy.
Posted on May 05, 2009
As I do to boot by usb on my motherboard aopen MX36LE
Look in the BIOS Setup boot options for anything to do with USB. e.g. 'Legacy USB Kbd' enable.
Aug 05, 2013 | Asrock P4VM890 Motherboard
ALL I NEED IS A ******* PIC SO THAT I CAN SET THE FKN SWITCHES
this should help you:
http://www.fixya.com/support/p365396-aopen_mx46_533v_91_89u10_061_motherboard/manual-16556
or
ftp://ftp.aopen.com/pub/manual/mb/mx46533v/mx46533v-ol-e.pdf
good luck
Apr 29, 2011 | AOpen MX46-533V (91.89U10.061) Motherboard
AL ENCENDER PARECE QUE ARRANCA ...PERO ENREALIDAD NO HAY SEñAL DE VIDEO.....QUE PUEDE ESTAR PASANDO
Checa los modulos de la memoria ram, abriste el cpu o algo por el estilo? instalaste algun nuevo software? checa las conexiones del monitor posiblemente el vga esta flojo.
Feb 18, 2010 | AOpen MX36LE-UN (91.89Q10.101) Motherboard
I have already changed the the power supply, but the computer don´t start no beep, only the the red led on the mother board light
The motherboards green LED light sends 5volt to the bios battery to keep it charged. It is normally called, standby LED.
Pull you're bios battery and check its current voltage. Use a volt meater. It should read 3 volt DC. See page 30 in you're manual. If you don't have you're manual you can download it from the link provided;
ftp://ftp.aopen.com/pub/manual/mb/ax4speun/ax4sgul-ol-e.pdf
You'll need Adobe reader installed to view the manual link. You're bios battery may need to be replaced. On the other hand the relay as shown on page 30 may be defective. If this is so, you will not be able recharge the bios battery. There is no fix for this other than replacing the motherboard.
Mike
Jan 22, 2010 | AOpen AX4SPE-UN Motherboard
I am installing an AOPEN AX4SG-N motherboard without a manual an I'm trying to figure out the correct placement of the conectors comming from the front of the case ie; power led power on etc. Could someone...
You can download the complete user manual with the installation instructions by clicking this link:
ftp://ftp.aopen.com.cn/pub/manual/mb/ax4sgn/ax4sgl-ol-e.pdf
You will find the Front Panel Connections on page no:35 of this manual.
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Dec 13, 2009 | AOpen Computers & Internet
Problem about ram
if the manual says that the board can support max of 1gb ram then each slot should support max of 512mb each. hope this helps
Aug 24, 2009 | AOpen MX36LE-UN (91.89Q10.101) Motherboard
I have problem about ram
If the manual says this motherboard support up to 1 GB RAM, you cannot put 2 GB. You can put 2x 512 GB RAM or 1GB RAM
Also try to upgrade your bios, maybe a better bios version supports more than 1 GB RAM.
Cwss4joe@msn.com asks Does the AOpen MX34-U
Yes it has onboard audio.
Here is a manual link:
ftp://ftp.aopen.nl/pub/manual/mb/mx34u/mx34u-ol-e.pdf
You can go to the Aopen sit eto download the driver if it is not working.
Go to http://usa.aopen.com/download.aspx and Select Motherboards in the drop down Product Selector. Then select your MB model #. Then select the category...if you need the Audio driver, select Driver. (Manual, Bios, etc.)
Thanks for using Fixya.
Wayne
(Note: The manual link is from Netherlands. Had trouble with US site.)
Jul 11, 2009 | AOpen MX34 (91.88510.101) Motherboard
No display on monitor.
More than likely you have a bad CPU. I've seen this several times.
Nov 07, 2007 | AOpen MX36LE-UN (91.89Q10.101) Motherboard
AOpen MX36LE-UN (91.89Q10.101) Motherboard Logo
273 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
