Question about ASUS Z92M Notebook
Disc drive not reading
The disc drive not showing up in My Computer or the disc drive showing up but not reading the disc. The sound is also skipping/stuttering.
  • 385 Answers
Update the O/S,
Type DXDIAG in the run box, to check your audio.
Device manager, disc drive properties, roll back or update the driver, let it search the internet for it.
Same for sound, device manager, sound,video and audio devices properteis, roll back or search for updated drivers, let it run.
Reduce hardware acceleration poss too for sound.
or poss drive failure.
should be good.
Hope this helps
Ric.
Posted on Apr 18, 2009
Windows 7 wont recognize dvd when i put hallmark card studio in dvd player
Try cleaning the disc (clean cloth going from middle out, not in circles). On the computer that does read the disc, try copying the disc contents onto a flash drive and then try installing the program from the flash drive instead of the disc if the computer still refuses to read it after cleaning the disc.
Dec 26, 2014 | Hallmark Computers & Internet
When i try to install homefront i got an error of data2.cab cyclic redundancy check
This sounds like a dirty or damaged or defective disc. You might try it in another computer... or simply attempt to read the files with your disc drive just to see what happens. (Try copying some files from the disc and pasting them to your hard drive to see if they can be read.) If you keep getting the same message, or another computer really takes a lot of time to read the disc... you probably have a disc problem
Sep 03, 2011 | Computers & Internet
My cd/dvd rom do not play when i i insert cd.what can i do?
Try navigating to Start Button/ My Computer/, then Double-click the CD or DVD drive. If no CD or DVD drive shows up in My Computer, there is a problem with the drive. if no disc shows up in the Drive, it is a problem with reading the media.
Mar 27, 2011 | Computers & Internet
I have an HP Pavilion dv6700 Notebook PC with Intel(R) Core(TM)2 Duo CPU T5750. It is using Windows Vista. Sometimes when I turn my laptop on the CD/DZD Drive will show in MyComputer and sometimes it...
Im not an expert on CD drives but I have had this case happen in many times. If it sounds like its starting then randomly stops it sound more of a hardware disk problem. You may want to try reinstalling drivers or getting a new computer.
May 22, 2017 | HP Pavilion DV6700T Notebook
Hard drive doesnt show up when plugged in
Hi
Thank you for your query
If the hard drive is making a knocking/clicking sound, then unfortunaltey its on its way out.
The read arm that reads the metal discs inside the drive is heating against the discs, thus causing the knocking sound
I would recommned that you replace the drive ASAP
I hope this helps
Feb 28, 2010 | LaCie Computers & Internet
Disc driver not reading discs
Can be several reasons
1. Disk is upside down
2. Lens is durty. Use CD/DVD cleaning disk
3. Disk is recorded in higher speed than your driver can read (for instance reading speed is 16, but disk is recorded on 24).
4. DVD drive is damaged or not connected properly.
Good Luck
Dec 10, 2008 | LG Computers & Internet
Cd drive showing instead cd-rw/dvd drive
Step 1: Unplug any cables that are connected loadTOCNode(3, 'moreinformation'); a. Unplug any cables that are connected to the video outputs of the computer. b. Try to read the disc again. c. If you still experience problems with the disc, go to step 2.
Step 2: Update the DVD driver loadTOCNode(3, 'moreinformation'); a. Contact the manufacturer of the DVD Drive to obtain an updated driver for the DVD drive, and then follow the manufacturer’s instructions to install the driver. b. Try to read the disc again. c. If you still experience problems with the disc, go to step 3.
Step 3: Obtain a hardware-based DVD decoder or software-based DVD decoder loadTOCNode(3, 'moreinformation'); a. Contact the manufacturer of the DVD Drive to obtain a hardware-based DVD decoder or software-based DVD decoder, and then follow the manufacturer’s instructions to install the decoder.
Note Many video adapters help decode DVD discs. However, the video adapter may not fully decode a DVD movie. b. Try to read the disc again. c. If you still experience problems with the disc, make sure that the sound card in the computer is compatible with the DVD drive.
Note Hardware and software decoders usually need a sound card to play back DVD movies. d. Try to read the disc again. e. If you still experience problems with the disc, contact the manufacturer to obtain a new disc. .
Remove Duplicate Drives loadTOCNode(2, 'moreinformation'); Remove any duplicate CD-ROM or DVD drives being loaded by Windows. To do this: 1. Click Start, point to Settings, and then click Control Panel. 2. Double-click System. 3. On the Device Manager tab, click View Devices By Type. 4. Double-click the CDROM or DVD branch to expand it. 5. Note the properties for each device listed in the branch. To do this: a. Click a device, and then click Properties. b. Click each tab in the device properties dialog box, and then record the device information and settings. c. Click OK. 6. Click OK, and then close Control Panel. 7. Restart Windows in Safe mode. To do this, use the appropriate method for your version of Microsoft Windows.
Aug 02, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Dvd rom problems with my macbook
Does the computer immediately return the discs after they're inserted or do you have to manually eject them? If it's trying to read the discs then there could be a problem with the type of disc. However if it just ejects the disc immediately, there could be a recognition problem. So, if your computer doesn't recognize that a disc is in the drive, you can check several things. 1. Check to see that the computer actually reads DVDs. To do this, open the System Profiler in the Utilities folder. Click on ATA/Devices and Volumes/Disc Burning. Those are three different options but each will tell you if the drive actually does run DVDs. If it shows DVDRW or DVD, but if it only shows CD or CD-RW, then it won't play a DVD. 2. If it shows that it accepts DVDs through the System Profiler, then you'll need to check to see if the actual drive is attached. You can open your computer through the battery with a screw driver. Once open, you'll need to check the connecting cable to the drive. If it's attached properly/securely, you may need to take it to a technician. The drive me be malfunctioning and need professional repair.
Feb 19, 2008 | Apple MacBook Pro Laptop Computer with...
DVD READING PROBLEM
Hi , look in software store having a cd cleaner , to clean the optic laser of the dvd./ something block the reading of the data of the dvd disc.
Jan 16, 2008 | Sony (1-796-293-13) Plug-In Module DVD...
ASUS Z92M Notebook Logo
106 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
