Question about Home
My dryer belt broke ,I need a break down pictuew of where it goes . whirlpool dryer mdl#leb6200kq2
  • 49 Answers
I don't have a picture, but the belt will go around the motor output wheel and the dryer drum itself, aswell as a tensioner usualy close to the motor. the path should be worn into the dryer drum, and be hard to miss
Posted on Sep 20, 2009
Start button starts dryer and dryer stops when button is released.
Ge dryers have a belt sensing switch inside that won't let the dryer run (just as you describe) when the belt breaks or comes off. My guess is you broke a belt. With door open---hold in button door switch and hit the start switch to get it too run a few seconds. Watch the drum and see if it turns. My guess it will not. Belt is a long skinny band that goes all around the drum outer area and then down around the motor.
Jul 09, 2015 | GE GTDP180GDWW Gas Dryers
Whirlpool Dryer turned on all lights and selection operate. When you push hold button to start. The Dryer clicks and does nothing. All lights and selections remain same. MDL # GEW9250PW0
check for a broken belt,there is what is called a "broken belt" switch down by the drum motor inside the unit and when the belt breaks or come loose it shuts off this switch to prevent the unit from heating and running to protect against fires from no movement and air flow
Dec 18, 2010 | Whirlpool Dryers
The drum on my Whirlpool dryer model LEN2000LW0 stopped turning around. I'm guessing that a belt broke?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 15, 2010 | Dryers
Need model number or part number for whilpool dryer
The model number for your dryer is usually located on a plate or sticker inside the door on the body of the dryer hidden by the closed door.
The most common (but not the only) belt number for Whirlpool dryers is 341241 and the idler arm for that common dryer has tabs that fit into the floor beneath the motor drive pulley. Take a loop of the belt with ribs inside the loop and pass it through the opening below the roller and loop it around the motor pulley. If it's the most common unit the end result should look like the image below for Whirlpool:
Belt Configuration
Good Luck
Sep 07, 2009 | Whirlpool Dryers
Belt broke on Whirlpool elec. dryer. How to remove front panel?
Pull out the filter from the top and get those screws out that attach the filters housing to the top. Then get a putty knife and release this spring clips holding down the top. Then get the 2 screws off from inside and raise up an inch to release the panel clips.
a9023be.jpgUse my handy belt routing GUIDE to see how dat old idler goes
Apr 10, 2009 | Dryers
Whirlpool dryer heats but the drum doesn't rotate
There is usually a large belt that goes around the drum to turn it ...it is either fallen off the motor pulley , broke .....or the motor may be gone in it ....not sure if there are any fuses for the motor on your dryer .
If you can tip the dryer over the bottom is usually open and you can see the motor and belt from there
Jan 09, 2009 | Kenmore 64952 Electric Dryer
Replacing belt on cloth dryer
Here's a site which has pictures to guide you:
http://repair2000.com/wpoolbelt.htm
Step 11 has a good view of how that idler goes back in. Good luck on your repair!
Nov 24, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool oaisis dryer will pwr on, but when start pushed-clicking noise and dryer won't start. Must pwr dryer back dwn to be able to change any timer setting, but dyer still will not start. ????
Model is 110.6705 Oasis Kenmore elite. Have removed back cover and have found drive belt broke. is there a seensor to shut motor dwn if belt breaks? Will order belt replace and see if thay resolves issue. Thanks
PS
No code given.
Oct 16, 2008 | Whirlpool Dryers
Dryer will not start
could be the start switch might be gone,there is a clip the hang down when u open the dryer door,it might be broke or the belt might be broke.
Mar 22, 2008 | Whirlpool LER5636P Electric Dryer
Home Logo
104 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
