Question about Philips DVP3340V
Vcr not working
I just bought this unit and installed it to a Polaroid lcd hdtv using the YPbPR cables and the white and red audio conections. The dvd works great but the VCR will not play, I used several different tapes. It will rewind and FF but nothing else will operate. I cannt even bring up the intial settings. Thank you Bill
  • Anonymous Jan 02, 2008
    yes sir the vcr will not work when i am trying to set it to record,there is a message that reads"unusable signal" also there is no area to indicate what channel i am wanting to record from.
How to set channel for recording
Posted on Feb 25, 2008
Samsung DVD-V3650 DVD Player / VCR Combo no sound when connected via component cable
Component connections between your DVD player and TV (they will be colored red, blue, and green) carry video only. You will need to connect two more cables for left and right audio channels. The connectors for these audio cables will be colored white and red for left and white respectively.
Nov 04, 2017 | Samsung DVD-V3650 DVD Player/VCR
How do you connect a polaroid lcd tv to a polaroid vcr/dvd combo?
does it have HDMI INPUT/OUTPUT? OR Audio video input/output? First you must have a cable for either of those two. HDMI (from the lcd tv) to HDMI (vcr/dvd combo).
audio/video input (from the lcd) to audio/video output (from the vcr).
hope this helps.
Jul 06, 2011 | Polaroid TLX-01911C LCD TV
Trying to connect vcr/dvd to tv. Do not have
you need to have your basic rca cables (yellow, red and white). The cables you are referring to are composite cables and if you do not have component inputs on your tv they will be useless. You can use rca cables on any tv that has video.
May 15, 2010 | Televison & Video
Black and white only when playing a DVD or VHS hooked up to my Sony Bravia 32" LCD TV.
What type of connections are you using?
If you are using coax cable check to make sure that the TV is on the proper channel that the DVD/VCR is switched to i.e. 3 or 4.
If you are using Componant video (red, green, blue, and red, white) verify that the green is plugged in all the way on both the TV and DVD/VCR and try connecting it to a different Componant input on the TV.
Note: the TV may be YCbCr, and DVD/VCR YPbPr or vice versa these two types usually are not compatible with each other. YCbCr is a digital signal and YPbPr is an analog signal.
If you are using A/V video cables or (yellow, red, white) check the DVD/VCR video setting to see if it is in progressive scan mode, as this can cause a problem with some TV sets that are not compatible.
Feb 05, 2010 | Goldstar GVR-E435 VHS VCR
Can't connect Samsung VCR DVD combo
this will only workif the vcr has a up convert feature whit out up convert it will not work you will have to connect vcr whit yellow red and white cables then dvd and vcr will give u the picture, if u connect dvd with commponent cables if u tv has this input picture from dvd will be better
Jan 26, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Cant hook it up
This unit does not have a standard coax cable (screw on) connection for and output..
You must use RCA or component video cables to attach to your television.
red and white is the audio left and right respectively and yellow is video. This unit also has S-video outlet for video. It also has what is called component video which is Red Green and Blue or maybe labeled YPbPr.
Depending on the inputs on the back of your television you may be able to connect in a variety of ways.
Jan 12, 2009 | Philips Magnavox DVD/VCR Dual Player
DVD/VCR hook up to HDTV. No audio on DVD or VCR, no video on VCR
When you use component audio, it may shut off the side a/v audio settings. Try restoring all defualts (any changes you have made will be lost by doing so) according to p. 32 of the manual:
Menu --> Setup --> Reset --> Yes
-Tha Mp3 Doctor
Dec 29, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp 42" lcd remote code for a polaroid vcr/dvd
I may be able to help with your Universal remote and your Polaroid LCD HDTV.
You can find some Polaroid HDTV Remote Codes here.
I hope that helps.
______________________________________
Polaroid FLM-3232 Manual Download
Polaroid FLM-3232 Service Manual Download
Dec 03, 2007 | Polaroid FLM-3232 Television
Philips DVP3340V Logo
100 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
