Question about SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx
SimpleTech 320 GB hard drive not recognized by PC
I have the same problem with the SimpleTech SimpleDrive SP-U35 500GB (pininfanina). It has been working fine for several months and this week my computer suddenly failed to recognize it and "could not find the software to install". Another computer gave exactly the same response.
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
My computer will not recognize the drive. Does it have to be connect to a power supply? I have it connected to a usb port
Windows 7 does not recognize SimpleTech 250GB external USB drive ...
answers.microsoft.com/...does-not-recognize-simpletech-250gb/f7ceccd0...
Just bought a new computer, running Win 7. Drive worked fine on Win XP. ... Windows 7 does not recognize SimpleTech 250GB external USB drive ... I find it hard to believe that a external USB 2.0 drive can't work with Win 7. There must be ...
SimpleTech dvi hdmi pc Hard Drives Questions & Answers ...
www.fixya.com > Forum > Tags > dvi hdmi pc > Hard Drives
Question about SimpleDrive 160 GB External USB 2.0 Hard Drive ... Question about250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive ... my PC does not recognize the external drive 96300-40001-001 Driver Problem: Check whether ..
Dec 18, 2015 | SimpleTech SimpleDrive 250 GB External USB...
My Simpletech 320 GB drive isn't being recognized by my computer. When I plug the USB cable in there is no recognition...the drive powers up properly. I am concerned since I have been saving data to...
The drive has just died. You might be able to salvage something from it if you take out the hard disk from it and you plug it inside a desktop - but don't expect too much, usually when they die they die for good and all the data is lost.
May 05, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
Black
Try to go through disk management and see if it works?
Open control panel then select administrative tools then disk management. Then in left column click disk management.
If you locate it may be it must be initialise by the system or need to create partition by formatting.
You can also check all the cables , the power cables the adapter , try to change the Usb cable also..
ok
Good luck !!
Jan 22, 2010 | SimpleTech 320GB SimpleDrive External by...
My simpletech signature driver 320 is not recognized by my PC
I had the same type of problem and found when I took the cover off that the harddrive worked loose from the plug. Pushed back into socket and reassembled, works great.
Dec 29, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
MISSING STORAGE SPACE
HARD DRIVE NEVER SHOWS TOTAL.ITS BECAUSE OF A CONFLICT CONCERNING WHAT SOME SAY IS A GB. ITS NORMAL AND YOUR DRIVE FINE.RELAX AND ENJOY.RICHARDM69
Dec 06, 2008 | SimpleTech 320GB SimpleDrive External by...
Computer doesn't recognize the external drive
I asume the connection is via an USB?
Try another usb-port and see if that helps, if not try to connect the disc on another PC (maybe a friends pc) and see is that pc recognize the disc.
Nov 21, 2008 | SimpleTech Signature Mini 250GB External...
Simpletech 320 gb
It has to do with the way computers count. Computers count in binary where we count in decimal.
Hard drive makers list there drives capacities in the decimal format, where windows lists it in it's binary format.
Wikipedia has a good explanation.
Also, the drive may have some preinstalled software on it that could be taking up a bit of space (it's usually not much).
May 15, 2008 | SimpleTech 320GB SimpleDrive External by...
SimpleTech 320 gb. Code 10 Problem
i doubt you can do anything about it. Code 10 is a hardware failure, so you will have to return it and get your warrenty.
Apr 28, 2008 | SimpleTech 320GB SimpleDrive External by...
SimpleTech SimpleDrive Pininfarina 500GB External USB 2.0 Hard Drive - Onyx Logo
189 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
