Question about Dryers
Dropped something in dryer trap
I dropped something in the lint trap on my dryer how can I get it out?
  • 221 Answers
You can gain access or remove the lint trap by popping the top of the dryer up, then remove the front panel.
Posted on Apr 18, 2009
  • rsindlin Jun 12, 2011
    The Maytag Centennial is not designed to easily "pop" the top. Once the top is up, removing the 2 Torx screws still doesn't let you remove the front panel. Many dryers, including the old one we had, did work this way, but the Maytag Centennial is poorly designed/constructed.
How do I retrieve a stick dropped down the lint chute?
if there is no water any where I would first use the wand of a vacuum cleaner that is going ( not the head just the pipe section)
Oct 11, 2015 | Dryers
Carbio Dryer Lint trap won't go back in.
If its that kind that is curved slightly and drops in from the top then most likely there is a lose screw head sicking out blocking it. Most dryers the top comes off after removing four screws or so. Then you can look inside. If you have to get into the back though you will have to remove more but its mechanically very simple. Just a drum with a motor and a pully that has a timer. If it has the lint trap inside the door then your best bet is that something came loose and is obstructing it. Again probably a screw or piece of plastic.
Dec 07, 2014 | Whirlpool Cabrio WED7600XW Electric Dryer
I dropped something in the lint trap. How can I remove the object?
depends what model , some lint traps are on the top and some are in the frt
Oct 09, 2014 | Kenmore Dryers
Dropped something down the lint trap
If it's a metal utensil that responds to magnetism, try a magnet on a string, or one of those telescoping magnetic picker-upper tools to get it out.
Jan 22, 2014 | Amana NDE2330AY Electric Dryer
Dropped something down my kenmore dryer 90 series model 110.60922990. I can see it at the bottom of lint trap but cannot reach it.
You will have to take the back off the mach then remove the lint trap cover I think there are 5 screws slide the cover the side and you should be able to remove whatever it is make sure to unplug the mach.
Jan 06, 2011 | Kenmore 64902 Electric Dryer
Dropped pen into lint trap. Now Dryer makes a screeching noise.
The pen has fallen into the blower housing and is hitting the fan blades.
Unplug the dryer!! Remove the two screws at the top of the lint trap. Remove the rear panel. Remove the four screws at the bottom that attach the lint filter housing to the blower housing. Then, remove the pen from the blower housing.
Apr 06, 2010 | Kenmore Dryers
I can't put the lint trap back into the slot it is supposed to be in. Have been using this dryer all day. I cleaned the lint trap out and it still won't slide back in. The lint trap is on top of dryer....
You probably have lint buildup inside the machine. try reaching inside it with a brush or something to clean it out. Also, it may be dusty, but run it for a few seconds with the lint trap out. That may blow the obstruction out.
Mar 07, 2010 | Dryers
Combination washer dryer full laundry center does not heat to dry clothes
1) check the lint trap, and reach way into the dryer to remove all lint.2) Look at the dryer motor, and make sure that it spins freely (toys and small objects fall into the lint trap and drop into fan. While there make sure you remove all lint
Aug 29, 2009 | Frigidaire Dryers
Dropped bleach pen into lint trap. How do I get it out?
its not too hard to get out.
you will need a #2 phillips screwdriver and or a 1/4" socket driver
remove lint trap
remove 2 screws at lint trap
unplug unilt
open the top (2 clips between lid and front panel in the crack, push them with a butter knife or putty knife to release top) opens like a hood
pull out dryer and pull off rear panel
on the left hand side there is a metal duct like thing lol
that leads to the lint trap at the top.
there should be 4 screws at the bottom where it gets round.
remove them, and wiggle the duct open. your pen should be there..
May 25, 2009 | Kenmore 62602 Electric Dryer
Dryers Logo
470 people viewed this question
Top Dryers Experts
