Question about Lands Phones
Nokia 5700 not booting
While software update due to power failure. my nokia 5700 not starting. It shows a white screen and switch offs.
You could format the unit by pushing the “green phone key”, 3 and * together while powering on the unit
Posted on Sep 23, 2008
Look frind u do lash it with latest versionand 7 pin cable,i will b 100% ok
Posted on Mar 09, 2008
SOURCE:
My nokia x 3 switches off eveytime, what can be wrong. shows a white screen then switches off
For this you need to flash your handset(if it is under warranty contact the service center)
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option) *Install the "NOKIA Software Updater" *Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
Thank you
Don't Forget To Rate
Jan 25, 2011 | Nokia X3 Cell Phone
My Nokia E63 is not starting. When I power on, it just displays the Nokia logo as part of the welcome video and then gets stuck there. It does not even switch off from there. Please help!
There is a problem in booting of the software.Due to virus or any corruption in software.
Initially try hard reset by following the details in th following link
http://en.kioskea.net/faq/470-how-to-reset-your-nokia
Remove memory card during switch on.
If the reset does not work update the Nokia firmware using Software updater or by updating firmware from Nokia care.
Dec 03, 2010 | Nokia E63 Cell Phone
When i have switch on the phone the display is showing white screen so what is the problem can u give a solution
This problem is due to software problem or due to a virus
there r 2 solutions for this problem....
1. Update ur mobile software using the latest Nokia Software Updater present in Nokia PC Suit (update).
This is ur own risk. U should have a stable internet connection and the full charging of ur mobile battery as if ur mobile update is interrupted, ur phone no longer works. So Be Careful.
2. Simple go to ur nearest nokia care center and give Rs.300/- if u dont have warrent and get ur mobile updated. If u have warrenty, it is free .
CAUTION: BEFORE UPDATING OR TAKING TO THE NOKIA CARE, PLEASE BACK UP UR DATA PRESENT IN THE PHONE MEMORY. BECAUSE ONCE UPDATE STARTED, UR DATA WILL BE LOST PERMINENTLY.....
ENJOY UPDATE!!!
Nov 15, 2010 | Nokia 7210
Hii My Nokia 5130 Express Music phone doesnt start up. It shows "test mode" on plugging the charger. Even otherwise, on starting the phone the Nokia logo appears ten the screen goes white and switches...
please format your phone using first switch of your phone then press the star(*) three(3) and call button holding these button and switch on the screen displays blank white screen for sometimes and then on .
Oct 20, 2010 | Cell Phones
The phone does not switch on.. when I press the power button, the Nokia logo shows with a small vibration as usual but then the screen starts blinking white a few times before switching off.
your phone got deads its happens many times when firmware is not properly updated,try to update your phone firmware but be care or send it to nokia centre
Sep 06, 2010 | Nokia X3 Cell Phone
Nokia N70 not getting switched On
i got the same problem with my nokia 3110..i've just took out my memory card,sim card and battery and after 5 mins i kept battery inside and switched on then it worked,next with sim card and again with 3 of 'em..now the problem is solved
Dec 02, 2009 | Nokia N70 Cellular Phone
My nokia 5700 start withaout lite nokia came and than switch off
try this way your problem will be solved
Switch-off your phone.
1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone.
Remember, do not let go the 3 press and hold keys until you see a formatting word screen show!
2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Sep 28, 2009 | Nokia 5700 Cellular Phone
My 3110c Hangs When I Switch It On
FLASH UR MOBILE OR GO NOKIA SITE DOWNLOAD NOKIA SOFTWARE UPDATER SOFTWARE AND UPDATE IT FREE UR PROB SOLVE
Aug 28, 2009 | Cell Phones
White Screen Only
Your phone software is corrupted ,you may need to install the phone software (firmware) in order to work ...
Good luck...
Nov 17, 2008 | Nokia N70 Cellular Phone
Nokia 6300 does not boot up when started
Try this:
Take your SIM card out.
Make sure your phone battery is fully charged.
Press * 3 send at the same time and turn the phone on. Keep them pressed until the reset screen appears.
Give it time to reset.
Yes! I know. You need someone to press the ON button.
Mar 26, 2008 | Nokia 6300 Cellular Phone
Lands Phones Logo
182 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
