Question about Air Tools & Compressors
Ok i really don't think that the spray jets are getting either enough air pressure to push the spray out or that it isn;t getting enough solution so how do i check to see whats wrong and how do i fix it?
  • 226 Answers
Air pressure, normal everyday gun you will want at least 50lbs air pressure at the gun - and there are inline pressure gauges that will go on the end of the gun for pressure adjustment & to read the pressure. As far as paint, if you have a viscosity checker, use that, otherwise, make sure you have the proper thinner/reducer and or hardner in the paint since most paints you cannot spray without reducer cause they are too thick. If you have used the gun before and not cleaned it, it it likely plugged up and can be cleaned with laqquer thinner in most instances, and the metal guns can be left overnight in gun cleaner or gasoline if they are really plugged up and then cleaned with the lacquer thinner. hope this helps. Rick
Posted on May 04, 2009
Driver side windsheld washer not spraying
Check the pipe feed under the hood for any kinks in the line.
Remove the pipe feed carefully and using a high pressure airline, blow back in the reverse direction of the water, back down the washer jet. This fine washer jet is prone to becoming blocked. If you don't have a high pressure airline, then you will need something very fine and flexible, yet stiff enough that when you insert it down the washer jet holes, it can disturb any blockage down there. Although I haven't tried one, you might use a yard brush nylon brush filament.
Nov 04, 2012 | Cars & Trucks
2006 mazda tribute.The battery has been replaced and the alternator is not putting out quite the correct voltage but isn't really bad yet I don't think. It's will start ok for 4 or 5 days
Your going to need to replace the alternator, it may be charging the battery slightly and enough to get through a few days of starting the vehicle, but you will need to get the alternator replaced.
Sep 08, 2012 | 2006 Mazda Tribute
Our 1984 Ford E 350 Brougham XL RV was running great, but now when we start it, it only runs for about 30 seconds. We've been checking the fuel pump relay and wiring having to do with it. We are...
check the fuel filter, it could be clogged,, try this , get some carb spray ,, spray it into the air intake,, while someone turns the vehicle over, if it runs as long as the spray is being applied, but stops when you quit spraying ( don't use to much , just do this as a test , ) then your fuel filter is clogged or the fuel pump isn't supplying a constant pressure of fuel, Now, if when the spray is being shot into the carb, and when the key is released into the run position and the vehicle stops,, your ignition is shot, and needs replacing
Sep 10, 2011 | Ford E-350 Cars & Trucks
Best way to find vacum leak
spray with starter spray and listen for change of engine note ??
Sep 07, 2011 | 1996 Ford Explorer
I have a 1990 LeSabre Station Wagon that hasn't been run much over the past 10 years. We have run it a little the past year and the air conditioner isn't working. I changed over the fittings to...
this is normal as there isn`t enough freon to keep the clutch on long enough to do anything thus lack of pressure in the system.also there won`t be enough freon and pressure in the system to show up any leak if there is one.
May 09, 2011 | Buick LeSabre Cars & Trucks
I need to clean carburetor on 340gx honda pressure washer. How would I do this?
pour large amounts of liquid carb cleaner into the gas tank
Let it run for a couple of minutes then shut it off and let it sit for a couple of days.
Aug 16, 2010 | Honda Garden
79 yamaha XS 750 crank no start
well here goes your problem probably in the float bowl area water sediment blocked low speed jets if you do not want to do a complete tearmore down just clean the jets and float bowl.
Use a carb cleaner soak the jets make sure you can see through them the small low speed jets specially.
if you have access to air blow the jets clean.
spray any passage ways with carb cleaner reassemble good luck.
Apr 23, 2010 | 1979 Yamaha TX 750
Seems to be no pressure . water spray jets noy
sometimes if dishes aren't rinsed well food gets caught in the pump intake reducing flow,try clearing intake of pump
Jan 31, 2010 | Dishwashers
I replaced the spray arm seal, but the arm still wont spin. I get water but not enough pressure to turn the top arm. The bottom arm works fine. Should the top arm turn easily when pushed by hand. It...
arms should turn freely. spray arms are only rotated by water spraying out from angled jets at end. check for blockage in spray arms - sweet corn and rice are the worst offenders. take spray arms off and run water in centre hole and see it runs out of all the jets freely
Apr 08, 2007 | Whirlpool GU2400XTPS Built-in Dishwasher
Air Tools & Compressors Logo
215 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
