Question about Sanyo DS31520 31" TV
My TV won't turn on.
Does anyone know if there is a fuse I can replace? The tv is only 4 months old.
    President:
  • 1,348 Answers
Warranty.once you tamper with it,it is void.
besides there is 30000 volts in there and it is dangerous.
the picture tube stores the high voltage,and is there even unplugged
Posted on May 16, 2009
13" EMERSON TV WON'T TURN ON?
What can anyone advice what to do with a dead set? Contact any experienced service technician.
Dec 05, 2012 | Emerson SpongeBob SquarePants TV
JVC AV56P776 Projection TV Green Light Flashes Won't turn On
Could be an open internal fuse or power supply failure
Jun 17, 2017 | JVC Televison & Video
I have a samsung LN-S3238D lcd tv. the unit is approx 3 - 4 yrs old. last night when watching tv the tv shut off by itself and will not turn back on. normally when the tv is shut off, the red led light is...
Hi replace the fuse in the wire connecting the mains plug. It's generally located within the 3 pin plug.
If you are lucky it maybe just a fuse blown out.
Thanks
Jul 06, 2017 | Samsung LN-S3238D 32 in. LCD HDTV
Picture Problem -- TV Does not Turn On
I don't think the picture tube (CRT) failed.
If you have no sign of life at all such as a lit LED or similar, the unit either has a blown fuse (could be inside) or the power supply has failed or at least is starting up as it should.
But before getting carried away, plug a lamp or other device into the same outlet to be certain that the set is getting AC.
Then, check your user guide to see if they specify or list any fuse in the specification section.
If you find mention of it and replace it only to see it fail again, then there was a reason for the failure of the first fuse too, meaning it will need service.
Jul 13, 2008 | Toshiba 34HF83 34" TV
Disney TV (only 5 months old) just stopped working.
I have a Disney cars tv with built in dvd player and after 2 months it stopped working. The power will not turn on, the light just flashes once and then goes off. I have tried replacing the fuses and it did not work, could you please help me.
Jul 05, 2008 | Disney 13" TV
32'' Panasonic TV, 4 yrs old, keeps blowing the fuse
Hi Mendi.
I had a similar problem, in that I could not find the proper fuse for my set. I bought a bit higher amp fuse from Radio Shack and it ended up blowing a couple months later. I've since pulled the TV down and replaced it with an LCD set, so I've solved my problem.
But, to address yours, I don't think the amp difference would not be the problem. Likely, there is a power issue on your set causing it to draw more amps and become out of specification. Using a higher amp fuse would buy you more 'capacity', but if its blowing those too (repeatedly), its likely a real problem in the set. I'm not a TV technician, so I can't tell you why. I'd suggest taking the thing in for service (cheaper than the house call) or if that is too expensive, looking at putting your money into a set that won't give you those problems. Or, just keep replacing the fuse until it doesn't fix the problem.
Sorry I cant help much more.
May 13, 2008 | Panasonic CT-36SL13 32" TV
Maxim 32'' monitor style tft lcd tv
Maybe your tv has a busted fuse replace it same value. if a new fuse busted again it means your tv has trouble maybe in primary or secondary power.
Apr 10, 2008 | Televison & Video
Tv. does not turn on sometimes? philips 63pf9631d/37
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
Well I think that if you would have a service manual for this set that would help a lot, I can send it to anyone who wants it via email/gmail. Let me know if anyone want one.
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Dec 01, 2007 | Televison & Video
Sanyo DS31520 31" TV Logo
53 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
