Question about Kenmore 24642 Top Load Washer
Washing machine fills with water then stops running
Washing machine fills with water but then stops running, does not agitate and continue through cycle. Water had to manually be removed from machine.
  • 57 Answers
SOURCE: Frigidaire front load washing machine won't stop filling
it sounds like your water valve is bad or you pressure switch is bad or hose from pressure switch to tub is cloged
Posted on Feb 16, 2008
  • 185 Answers
SOURCE: simpson esprit washing machine
put a new pressure switch in it
Posted on Mar 26, 2008
  • 1122 Answers
SOURCE: washing machine is not rinsing and spinning
LID SWTICH BAD,THANKS-MIKE
Posted on Jul 23, 2008
SOURCE: Washing machine fills, but won't agitate
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
Posted on Aug 29, 2008
  • 62 Answers
SOURCE: Kenmore series 80 washing machine
This is usally a timer problem that is shorted
Posted on Oct 20, 2008
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
The water will fill the tub, agitation will begin,
Yes, you have it figured out...
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
May 05, 2010 | Washing Machines
Help! My fisher paykel washing machine won't stop filling up!
If the water continues to fill even if unplugged the water valve is sticking and needs replaced. if removing power turns the water off the water level pressure switch is bad or there is something plugging the sensor tube somewhere.
Eric
Nov 22, 2009 | Washing Machines
Washing machine continues to fill when starts
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Oct 01, 2009 | Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Water running out when washing machine is filling?
Hi jojolevaokah
Water siphoning out the drain line
If the water is continues to fill and water is draining while it is filling or agitating, Check the height of the stand pipe. It should be about 36" above the floor. If the height is correct it may need to have an anti-siphoning valve installed into the drain line.
Apr 07, 2009 | Whirlpool LSQ9520L Top Load Washer
Whirlpool AWO3761 stuck mid-cycle
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Feb 07, 2008 | Frigidaire ATF6000ES Front Load Washer
    Kenmore 24642 Top Load Washer Logo
    367 people viewed this question
    Sal DeAngelo
    fordexpert
     Brian Main
    Brian Main
