Jvc dvd/hdd recorder model dr-mh20sek
Display flashes "loading" hdd starts but machine doesnt respond to remote or front buttons dvd drawer doesnt open when asked and machine refuses to do anything will just flash if left and doesnt shut down there were 2 capacitors in the power supply with raised tops these have been replaced but fault still persists any help greatly appreciated
  • 2 more comments
  • fishingbloke Oct 03, 2007
    many thanks problem solved capacitors in the power supply were the problem a schematic was very helpful
  • curlin Jul 01, 2008
    Same problem with the dvd player it just says 'loading' So how do I change or check the capaictors please
  • zikoziko May 15, 2009
    I have the same problem. Device flashes loading when switched on. Can someone provide me with a schematic (and instructions ;-) that would allow me to attempt to fix the device please?
  • coestman May 11, 2010
    What value or data have D5103 and D5105?
Replace D5103 and D5105 ( Under Heatsink! ). As a precaution replace C5103 and check R6108 and R5109. Any electrolytic capacitors with domed tops should be replaced. This fix also cured machine that flashed the DVD and HDD lamps but had no other functions.
Posted on Jan 28, 2009
  • swindlers Jun 06, 2011
    Same problem. All 470 uf capacitors changed, and a couple of the 22uf 50v ones...difficult but problem solved. Now functions well.
    Genius:
  • 1,139 Answers
OK changing the caps only resulted in proper filtering and voltage smoothing and did very little to solve your problem. Now what swollen caps are a sign of is an over voltage condition. what I would suggest because you may have a bad voltage regulator, is that you have to get a schematic and measure the voltage levels on the power supply to determine if they are correct or not. This will tell you if the regulator is bad or not. You do have a power supply problem you just have to determine where in the power supply. This can be done with the schematic and a voltmeter.
Posted on Sep 18, 2007
Loading keeps blinking Nothing works anymore. even power of no longer works
Check for dried up electrolytic capacitors on the DC-DC converter C5318, C5340, etc.
Nov 13, 2009 | JVC DR-MH30S DVD Recorder
How do I delete files stored on the HDD of my JVC DR-MH30S?
Use edit on you remote. this will bring up delete
Nov 05, 2008 | JVC DR-MH30S DVD Recorder
Toshiba Hdd/Dvd video recorder. Moved unit to a static caravan,comes on ok but when using the remote to use it ,no matter what button I press I get the message 1. DR-OFF Can you please help ?
Hold both the channel up and down buttons on the front of the recorder for 3 secs until DR1 shows in the display. Try it and let me know if it worked..
Apr 16, 2008 | Televison & Video
JVC DR-MH30S DVD Recorder Image file
ciao! tutti vittime del dvd rec [jvc dr mh20-]..jvc dr mh 30...jvc dr mh 50..e un risolvere dell problema di LOADING...il mio jvc dr mh30..di 6 mese e roto ..ma trovo risolvere..difetto e nel hdd,160gb..e in corrozione..e roto hardisk,solo sistema operativo.......con softer COPY CLONE PRO..free da iternet.scarica nell cd room..nel avvio dell pc,che sono due hdd,uno rotto ,e uno buono..guarda instruzione dell cd..e tutto ok,per copy di hdd..e tutto ok per legare poi nell dvd rec jvc dr mh 30..ho provato io e tutto ok...ma io ho trovato hdd dell dvd rec jvc dr mh20..e io ho un dvd rec jvc dr30..ce un problema picollo dopo copy cloner,,mio dvd rec mi conosci solo 80gb..ma perche e in origine da dvd rec jvc dr mh20[80gb]..cercho un hdd di dvd rec drm h30..opure jvc dr mh50..per copy cloner,mio hdd,per conosciere 160gb..opure 250gb..atentti problema di LOADING..e nell due alimenti di hdd..e suporte di dvd..sono quattro line..12v..terra..terra..5v....sono simille anche perhdd..anche per suporte dvd..controla nel condizione di LOADING..se non sono precise..voltaggio..persempio..12v=10v..opure 5v....4.2v..e perdita..da un contesatore electrolitica.e asciugato da lavoro fastidiosa.......se aiuto da poco..non lo so aspettiamo nell mio e-mail....arivederci[ agimqosesda@yahoo.com ]
Apr 14, 2008 | JVC DR-MH30S DVD Recorder
JVC DR-M10 DVD Recorder not working
Contact JVC @ 800-252-5722, the "loading" is a known bug and they will fix this defect at n/c even if it's out of warranty period.
Mar 12, 2008 | Televison & Video
PROBLEM WITH MY DVD-HDD VIDEO RECORDER
Yes there is a high probability that the 5v power supply has suffered damage. Anyways just check if the drive is ejecting properly without placing any DVD. If it doesn't then its confirmed that the ps is the culprit. try it and let me know..
Feb 23, 2008 | JVC DR-MH30S DVD Recorder
Not responding after flashing "loading" for 1 minute then get message R-Lk --:-- on display
Hard drive issue or power supply. Power supply prone to bad capacitors (look for leakage/swollen tops)
If hard drive faulty you'll need a new one which is no small task. Disk contains firmware and custom file system and smallest I've got image is 10.7gig
Feb 02, 2008 | JVC DR-MH30S DVD Recorder
JVC DR-MH30S LOADING
Had this JVC recorder for a couple of years, It has always take ages to
boot up and start working now its stuck on "Loading" on the display.
Anyone no of a reset seqence that will restart the machine
Nov 20, 2007 | JVC DR-MH30S DVD Recorder
JVC DR-MH50S
Just had the 2nd diagnosis for the error - "digital PCB" at a cost of £252 - BONKERS! Have e-mailed JVC to see if they can make the cost of the repair reasonable, got a positive reply they want me to send my proof of purchase, serial no etc. & they'll consider dropping the cost significantly. On top of that just found same model on ebay, ex display £130. baught it, was prepaired to pay upto same for the repair - gunna swap HDD for mine when it arrives, the stuff on there was the main reason i wanted it repaired. Still gunna try to get mine fixed for nowt though through JVC! May as well try for nothing!
Nov 10, 2007 | JVC DR-MH30S DVD Recorder
"please wait"!
Is there not a drawer open/close button? Please wait usually indicated wrong type of disk and it is not being read or faulty laser. Switch it off and switch on then press the drawer release before it starts trying to read.
Jul 16, 2007 | JVC DR-DX5 DVD/HDD Recorder
Televison & Video Logo
422 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
