Question about JVC Televison & Video
JVC AV32D303 after a storm the picture wont come on and the red on-timer light next to the on off button is blinking
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
Jvc av32d303 screen went blank power went off and timer light came on. eventually I starts flashing ever couple of seconds and never stops. Does nothing else
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 14, 2014 | JVC AV-32D303 32" TV
Blinking timer light, No picture or sound.
Ur high voltage is dead,the FBT,the flyback transformer,the big black block of plastic with a red wire with a cap hook to the CRT(tv tube).That is dead.
Sep 27, 2009 | JVC AV-36D302 36" TV
RED BLINKING TIMER TV WONT TURN ON
Page 40 on the PDF link below may help - Ask me if you need further assistance.
Thanks
Len
http://resources.jvc.com/Resources/00/00/99/51798Cien.pdf
Feb 28, 2009 | JVC AV-32230 32" TV
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
Well, I have found out that the number of red light blinks is a "blink code" that indicates the nature of the fault with the TV. Usually these are various failures of internal fuses or circuit boards. There's a fair amount of information on threads at techlore.com on this, so try searching there. Teh specific codes and manuals are usually it seems under license from Sony and not available for free to the public. Sorry!
Oct 17, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Wont power up, red blinking light (on timer)
Refer to the trouble-shooting section of your manual. Usually, with this technology, the lights (Lamp/Temp) on these sets are also used at diagnosis/fault indicators... so, your manual should tell you what a flashing TIMER light represents. If the manual, doesn't provide this information, then ring JVC and ask one of their technicians.
Jun 26, 2007 | JVC AV-36F702 36" TV
JVC TV - No Pic or Sound-Blinking Red Timer Light
No sir... Nothing short... The red blinking timer light indicates the the protect circuit has it shutdown. That's happened because something has probably shorted along the B+ line. If it were here in the shop I would be checking the following: IC911 Str-G6624 regulator PC921 Tlp421 F905 5a Pico Fuse C931 160v/100uf cap and the HOT of course 2Sc2539 One or more of these parts has probably failed but usually not all of them.. So it's not an expensive repair. Now, while you're having that done also have them do the following modifications for greater reliability if it hasn't been done already: Remove D701 you don't need it. Install C705 (47uf/16v) in space provided (near Ic701 Pin 22 ) Replace jumper W122 with ferrite bead (Qqr0582-001z) Add a cap(47uf/16v)between pins 61 and 64 of Ic701 neg to pin 64 and pos to pin 61 This is per a JVC bulletin that the shop you take it to may or may not have. It's a simple and inexpensive modification and will add a measure of reliability to the years this set has left. As a footnote, take the set into the shop yourself and pick it up when it's done. This will help keep the cost down. All-in-all should be less than $150 if all the parts above got replaced. If you have any questions don't hesitate to ask. Hope this helps Bill 360-642-4993
Jun 07, 2007 | JVC AV-32230 32" TV
I believe I've answered this one or one identical to it:: If not, No sir... Nothing short... The red blinking timer light indicates the the protect circuit has it shutdown. That's happened because something has probably shorted along the B+ line. If it were here in the shop I would be checking the following: IC911 Str-G6624 regulator PC921 Tlp421 F905 5a Pico Fuse C931 160v/100uf cap and the HOT of course 2Sc2539 One or more of these parts has probably failed but usually not all of them.. So it's not an expensive repair. Now, while you're having that done also have them do the following modifications for greater reliability if it hasn't been done already: Remove D701 you don't need it. Install C705 (47uf/16v) in space provided (near Ic701 Pin 22 ) Replace jumper W122 with ferrite bead (Qqr0582-001z) Add a cap(47uf/16v)between pins 61 and 64 of Ic701 neg to pin 64 and pos to pin 61 This is per a JVC bulletin that the shop you take it to may or may not have. It's a simple and inexpensive modification and will add a measure of reliability to the years this set has left. As a footnote, take the set into the shop yourself and pick it up when it's done. This will help keep the cost down. All-in-all should be less than $150 if all the parts above got replaced. If you have any questions don't hesitate to ask. Hope this helps Bill 360-642-4993
Televison & Video Logo
761 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
