Question about HP PSC 500 All-In-One Printer
Printer will not turn on.
Tried another power source ie power cord and adapter, still will not turn on. Printer has been working great for more then 6 yrs.
  • TORJACK82
    TORJACK82 May 11, 2010
    what of printer do you have?
    try isolate the power supply of your printer
    Problem Solver:
  • 11 Answers
For that situation the logic board or main board of your printer have problem sometimes the diode near to the power source of the adapter, try to check that diode if deffective replaced it with signal diode 1N4148 suerly it works
Posted on Apr 18, 2009
Of 3 lights: green on right and red in center are flashing, unable to stop them.
How to fix blinking lights Printer lights blink in certain patterns to tell you about specific problems. Read this document until you see the pattern that your lights are making. The solution is below each pattern. NOTE: There may be more than one reason why the printer lights are blinking, so you may see several solutions. PRINT CARTRIDGE light RESUME light POWER light Off Off Off c00106861.jpg c00106862.jpg c00106863.jpg Problem
The printer will not turn on.
Solutions
1. Check the power cord or power module connections at both the printer and the power source (power outlet, power strip or surge protector).
2. Try disconnecting and reconnecting the power cord or power module to the printer.
3. Try reconnecting the power cord or power module to the power source or try a different power source.
4. Verify that the printer is connected to a power outlet that works.
5. Make sure there are no additional switches turned off, such as those on a power strip or surge protector.
6. Check the power breaker to make sure the power source is working.
If these solutions did not fix the problem, have the printer serviced. http://h10025.www1.hp.com/ewfrf/wc/document?docname=bud09170&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=59129
Dec 09, 2010 | HP DeskJet 940c InkJet Printer
No power
If it is not getting any power at all, only one of three things: cord is fried/dead; could be the outlet, try something else in the same socket; or, the board in the printer is dead.
1. Press the POWER button to power on the printer The device has a <POWER> button.
Connect the power cord from the printer to the electrical source.
Press the <POWER> button.
Wait until the device has completed its cycling process before submitting a print request or completing installation.
2. Disconnect and Reconnect AC power adapter or power cord to the device and electrical source
  • Disconnect the AC Power Adapter or power cord from both the device and the electrical source.
  • Then reconnect it.
  • If you are still unable to obtain power to the device, try another power outlet.
  • If possible, try connecting power directly to a wall outlet (as opposed to using a surge protector or power strip...just as a troubleshooting measure).
3. Disconnect and reconnect the electrical cord to ensure a secure connection 4. The iP6000D may require repair
For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 8:00 a.m. - 12:00 midnight. EST, Saturday 10:00 a.m. - 8:00 p.m., excluding holidays).
5. Try a different electrical source / outlet
this will surely fix your problem..
Dec 06, 2007 | Canon Pixma iP6000D InkJet Photo Printer
I have a lexmark x125 all in one printer, it dosnt turn on ,y tried changin the conection cord all th troubleshotters but nothing happens please help me
Great job on changing the connection cord. Also, try removing the power adapter from the printer. The power adapter is the rectangular black box behind the printer where the power cord is attached. Wait at least 30 seconds before plugging the power adapter back in the printer. Properly secure it behind the printer. If that doesn't help, I suggest you contact Lexmark Technical Support to further investigate the problem. Thanks
Jul 20, 2010 | Lexmark Pro X125 All-In-One InkJet Printer
Lexmark 2600 wil not turn on, no lights, nothing absolutely zippo. Definately has power from the mains switch so could be either the transformer into the printer or within the printer itself. have tried...
Unplug the power adapter from the printer. The power adapter is the black box behind the printer where the power cord is attached. Leave power cord attached to the power adapter and the other end of the power cord plugged in straight to a known working wall power outlet, bypass any surge device or power strips. There should be green LED light on around the power adapter's silver contacts. If none, make sure the power cord is properly secured. If that doesn't help, that's the main problem. If LED light is on, plug it back in the printer in the right position and properly secure it in. If printer won't automatically power on, press the power button. If that won't help at all, the printer itself is the problem. I hope I can assist you more on this.
Jun 28, 2010 | Lexmark X2600 InkJet Printer
No power
probably you already checked the following:
changed power cord
changed power source/outlet
checked for any obstructions inside the unit
check your warranty status (starts from the date of purchase)
no user-serviceable parts in there, unit is service/replacement bound
tip : having it repaired costs more than buying a new one
Aug 30, 2008 | Lexmark Office Equipment & Supplies
MP830 will not power on
Here is what Canon has to say:
Solutions for Printer won't power up Issue: The device does not power on
1. Disconnect and Reconnect AC power adapter or power cord to the device and electrical source 2. Disconnect the power cord and wait approximately 10 minutes 3. Press the ON/OFF button to power on the multifunction device 4. Disconnect and reconnect the electrical cord to ensure a secure connection 5. The MP830 may require repair 6. Try a different electrical source / outlet
Here is a snip of my notes on the same subject for an Epson printer:
Well, first things first I guess:
  1. Try the printer in a different outlet (other side of room, or similar, not same power Jack)
    1. If you have power here, your issue is likely the outlet, not the printer.
  2. If the power cord has an "on" LED, check to see if it is lit up while plugged in.
    1. If you have an LED with no light while it is plugged in, you are looking at a power adapter that is no longer working
  3. If there is no "on" LED to check, your next best bet is to take your printer and power cord to a store that sells printers, and ask if you can "try" a new chord before buying it. (most stores will allow this to keep customers happy)
  4. You may also want to check with the manufacturer if the chord is found to be bad, as some will send replacements free of charge.
  5. The last option is that there is an issue inside the printer. This is not likely, though it is possible. Most printers have an external power adapter that keeps any power issue outside of the printer, but I can't tell from the Canon site if this printer has one or not. (It would be a black box between the plug and printer.)
    1. This can also be checked by "testing" a new chord at a store. New chord, still no power, internal issue.
      1. If this is the case you will want to contact Canon if the unit is still under warranty.
-Hope this helps.
May 27, 2008 | Office Equipment & Supplies
Printer doesn't turn's on
Per Canon:
Solution: Disconnect and Reconnect AC power adapter or power cord to the device and electrical source
Secure all Power Connections
If this does not work, have you tried a different outlet to ensure that the outlet isn't the issue? Also, when you press the POWER button, does the printer respond at all, or is it basically dead?
Please post back if you need further help, otherwise, thank you for using and rating FixYa!
May 24, 2008 | Canon PIXMA iP1600 Printer
48 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
