Question about Jl Audio 12W3 Car Subwoofer
Fixing the middle piece of the sub
Hi i just got a 12" JL W3 sub from a friend. the problem i have is that the middle little circle piece seemed to of came seperated from the main part of the cone. half of it is still stuck on there and the other half just flaps around when it is being used. is there a way i can take this piece off and glue it again? or just put some glue under where it is loose at? my friend took it in to a local car audio shop and they said that i have to send it in to JL. i was just wondering if there is another way around this. if so what type of glue should i use? i was thinking either super glue or rubber cement...
  • 655 Answers
Hello stoge52,
Many people do their own speaker repairs and it is many times perfectly satisfactory. The folks who do a lot of it are musicians who seem to bang their equipment around quite frequently.
The problem with your JL sounds like the dust cover and not the cone itself, so you are lucky in that respect. Repairing the cone is more involved and it's rather tricky to duplicate the thickness, rigidity, and original elasticity of the cone. It's usually best to simply replace the cone, a process called "reconing". But gluing the dust cover is perfectly acceptable and not much of a job at all. Don't try super glue. It won't work. I'm not sure about rubber cement, though, but I've never heard of anyone using it. Many pros use silicone sealant. Either black or clear looks best for speaker repair. A somewhat better product is a tennis shoe repair product called "Shoe Goo". It's a little lighter and remains more pliable than silicone sealant, making it a better choice for lighter speakers. You can usually find "Shoe Goo" at larger sporting goods stores. If you want to use something that is made especially for gluing speakers, here's a link to a product called "Prosound Loudspeaker Recone Adhesive" and is advertised as the same black adhesive as that used by many major speaker manufacturers. It's $19.99 for 8 fl oz, more expensive than silicone sealant. Is it better? I don't know. But if it were MY JL, I'd probably spring for it.
http://www.prosoundservice.com/m9_view_item.html?m9:item=PROSND-RECONEGLUE8OZ
You may want to gently remove the dust cover entirely from the speaker and make sure that there are not any tears in the cone itself. If there are, you should repair them first.
Also, when you reglue the dust cover, wait a MINIMUM of 24 hours for the glue/sealant to set up and cure properly. If you start the sub thumping before the glue has fully cured, you'll have the same problem again. One other thing, use just enough glue/sealant to do the job. Don't think that more is better. A consistent thin layer on the entire surfaces being joined is best. A gob here and there will not hold for very long.
The alternative is to send it out for repair. And since it is a JL, I would not send it anywhere but JL. Be advised that is not going to be cheap. And it's going to be time consuming. Probably at least 25-50% of the cost of a new sub and probably a minimum of 3-4 weeks, sometimes longer. And don't forget, you'll pay shipping both ways.
Hope this helps.
Posted on Apr 18, 2009
Whats the best way to wire an mtx thunder152 to an jl audio 12 w3-d6 duel voice coil sub
Take both positive leads to the positive of the amp. Both negatives from the sub to the negative of the amp. Utilize the bridged output connections. This would present a 3 ohm load which would be around 100 watts rms (rough estimate)
Aug 17, 2016 | MTX Car Audio & Video
What's the airspace a 12 inch jl audio w3 need?
You're gonna need .5 cubic ft minimum
Sep 18, 2012 | Car Audio & Video
Ripped center part
You can glue it as long as it is still fuctioning, of course let it dry completely before using it again.
Jul 02, 2009 | JBL GTO1204D 12" 1200 Watts Subwoofer Car...
Is a 15 w3 d-4 better then a jl audio w3-d2
All of the JL W3 subwoofers are essentially the same. The "d2" and "d4" suffix refers to the voice coil configuration. "d2" = dual two ohm coils, "d4" = dual four ohm coils. Depending on the number of subwoofers in your system and the amplifier(s) you are using to power them, one or the other of the configurations may be "better".
Generally, you want to have the load on your amp to have the lowest possible impedance consistent with the amps capability to operate properly with that load. It's normally referred to as "impedance matching". Greater power (watts) is produced, and louder sound, when the amp can deliver power at a lower impedance.
If your amp is only capable of supplying power at 4 ohms, you want to make sure that the configuration of your sub(s) represents a 4-ohm load. If the load is higher, say 8 ohms, then your amp can only deliver about half the power of which it is capable. It would be OK to run them a 8 ohms, but they would not be as loud. On the other hand, if the load was lower, say 2 ohms, your amplifier would soon overheat and go into protect mode.
So the trick is to first decide on how many subs you want. Then choose an amp/sub combination that "matches".
The DVC or dual voice coils just gives you more options in selecting and configuring. Say you want 2 subs and you are going with the 15w3 d-2. Your amp is the JL Audio G-MAX monoblock. The amp puts out 1200Wx1 Chan. at 2 ohms or 600Wx1 Chan. at 4 ohms. You would wire both of your subs voice coils in series making each sub 4 ohms, then wire the 2 subs in parallel to your amp making the final load 2 ohms, the best "match" for your amp.
Mar 29, 2009 | Jl Audio 15W3-D4 Car Subwoofer
How do i wire a jl w3 to a jl 500/1 mono
wire the sub in series it will give you best bang
Mar 16, 2009 | Jl Audio 12W3 Car Subwoofer
Trying to find out wat the watts are on a jlw3 12 and a jlw0 12
The JL 12W0 needs 125 watts RMS. Sealed box it needs 1.5 cubic feet. Ported it needs 2.5 cubic feet.
The JL 12W3 needs 300 watts RMS. Sealed box it needs 1.25 cubic feet. Ported it needs 1.75 cubic feet. I wouldn't suggest running these subs together.
Jan 17, 2009 | Jl Audio 12W3 Car Subwoofer
Subs
6ohm i believe i have a pair of them though and i wired them to 1.5ohm
Sep 30, 2008 | Jl Audio 12W3 Car Subwoofer
One of 2 subs stopped working.
ya the sub is blown or the amp channel is blown
Apr 09, 2008 | Jl Audio 12W3 Car Subwoofer
Jl sub not powering on
ok try your sub on another amp is first find out if that works or not if it works then there's a good chance you amp is knackered
Feb 22, 2007 | Jl Audio 10W3v2 Car Subwoofer
Jl Audio 12W3 Car Subwoofer Logo
441 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
