Question about Toshiba Satellite 1410-S173 Notebook
Replace keyboard on Toshiba Satellite 1410-s173
Need to replace keyboard on my Toshiba Satellite 1410-s173. What srews should be removed in order to gain`access to the keyboard area?
  • Anonymous Mar 29, 2014
    How can i unlock my keyboard coz it's not working?
  • Toshiba Master
  • 5,660 Answers
First remove the AC adapter (Charger) if plugged in. Then remove the battery.
Next step is removing the Keypad Securing Strip. This is a plastic cover right Above the keypad, and below the LCD screen. Looking at it, you'll notice on the Left and Right sides of it, that it has a U-shape.
This U-shape covers the LCD screen hinges.
Take a small flat tip jewelers screwdriver, and come from the right side of this plastic strip. You will see a thin parting line, where this plastic strip meets the laptop body. Your flat tip goes in this parting line. You have to use finesse. It's doubtful you'll break the plastic strip, as it's REAL tough! But if you slip, you could scratch the plastic. (Actually, it's pretty hard to scratch that plastic! Just thought I would caution you. The plastic strip is made of a spaceage plastic. Pretty tough stuff!)
The plastic strip has tabs around the edges, every so often. These
plastic tabs snap into place, and hold the Keypad Securing Strip on. When you begin, it's a little tough to get that flat tip down in there. (Remember ->Jewelers screwdriver!)
Plus, you may be at one of the points that there is a tab. Usually there is a 'dimpled' flat place, that looks like a flat tip should go there.
With the flat tip jewelers screwdriver inserted a little, ease back on the screwdriver, and lift the plastic strip up.
It will look like it's bending. If you have another flat tip Jewelers screwdriver, or a small butterknife, you can insert it, and hold this part up. Then take the other flat tip, move over a little, and start lifting up.
Once this Keypad Securing Strip starts coming up, it will come to one of those tabs, and the tab will come up and out. You'll hear a POP, and think you broke it! You didn't.
Go along the edge, and keep popping this strip up. Use caution, as to how far you insert that flat tip screwdriver!
There are tiny little wires under there, and you don't want to pinch one, or tear it loose. Keep the flat tip, about a half a fingernail length in, and you won't.
Once you get towards the other side enough, the strip will let loose, and come up.
Without disconnecting the wires, see if you can lay the strip towards the back, and lay it out of the way. Towards the LCD screen. You are trying to get to the screws, that secure the keypad. They will be in a metal strip for the keypad, and towards the LCD screen.
I can't remember at this point if there are two, three, or four screws. You'll be able to see, and you'll know.
(Use Caution! You can easily drop these screws! They might go right into the body of the laptop. You MAY be lucky enough, to pick the laptop up, turn it over, and gently shake the laptop, to have them fall on the table. You MAY not be so lucky, and have to disassemble the entire laptop, to get to them!)
IF, the Keypad Securing Strip will not lay out of the way, so that you can get to the keypad screws, you'll have to remove it.
It isn't tough, but it looks daunting the first time.
You will see small White connectors in the middle of the cables.
Two wire cables, if memory serves. These connectors are small White rectangular blocks. There is a Female and a Male. You just take your fingernails, and ease the connectors apart.
Don't worry about how they go back together. They are different sizes. You just match up the size.
Now with the keypad securing screws removed, ease the keypad forward a little, and bring the front of it up to a tilted position. (Towards the LCD screen is the front of the keypad) You don't want to bring it straight up, as there is a flat ribbon cable you need to disconnect. The flat ribbon cable attaches at the back of the keypad. (Towards you) It has a White connector.
This connector is different, from the ones you have disconnected already. The connector itself has a locking 'bar'.
This thin rectangular piece of plastic, goes across the length of the connector.
It is positioned at the front of the connector. It comes forward, towards the flat ribbon cable end, that is connected to the keypad.
It slides. It only slides so far, then stops. It is at this point, that you remove the flat ribbon cable itself. The one towards the keypad. There will be No connector on that flat ribbon cable. It will be just the ribbon cable itself.
When you reattach it, you just slide the flat ribbon cable back into the White connector. Then you ease that locking bar back into position. The position that it started from.
Now reverse your steps.
Posted on Apr 18, 2009
  • Michael Winge
    Michael Winge Dec 18, 2015
    Hello Joe, I was wondering if you could make a video of how to accomplish this. I have a Toshiba satellite P50 and the steps you mentioned seems like it applies to my laptop.
  • joecoolvette
    joecoolvette Dec 24, 2015
    Michael go to Youtube and -> Toshiba Satellite P50t-A Teardown/Opening/Take Apart. Not my video.
Toshiba 1410 cooling fan replacement
Contact a Toshiba repair center in your area, Alternatively a computer technician will do.
DIY install, components may be found on Gumtree or e-Bay.
Take care!
damnor01
Apr 28, 2012 | Toshiba Satellite 1410-S173 Notebook
How to change RTC battery of Toshiba Satellite 1410
RTC battery is located underneath the palmrest - to the left of the touchpad - they don't usually die, as they are Lion rechargeables. Unless your Satellite 1410 is losing date and time every time it is turned off, you probably don't need to replace it. But if you need to replace it, make darn sure that you replace it with a rechargeable and nothing else.
If you need to get to it, you'll need to remove the keyboard, then the square aluminum bracket above the heatsink, then get to the bottom, remove all the F6 and F26 screws, then you must make sure to disconnect the WiFi antennas. After that, the top case (including the palmrest) will unsnap from the bottom case and you'll be able to see the RTC battery.
Aug 30, 2011 | Toshiba Satellite 1410-S173 Notebook
On start up my computer says rtc battery is low or cmos checksum is inconsistent. Press (f1) key to set date/time. I press f1 but nothing happens. blank screen. I can press ctrl alt del and it will restart...
Your RTC battery or CMOS battery is either dead or too low to keep the correct settings, windows will not operate correctly without the proper date and time kept. This battery has to be replaced for your system to operate. Below is the service manual that will advise you of the proper procedure to replace the battery. Once the battery is replaced, reboot the laptop, go to the BIOS screen and reset the date and time, then reboot as normal. In the case of your particular laptop, the laptop has to be disassembled down to the lower case and motherboard. The included service manual has the procedure for this.
http://tim.id.au/laptops/toshiba/satellite%201400%201405.pdf
Nov 11, 2009 | Toshiba Satellite 1410-S173 Notebook
The m and caps lock keys on my Toshiba satellite
Bad keyboard. This series have a higher frequency of keyboard problems because ... well .. the keyboard cable got folded by design. Just replace it. The A40's uses the same keyboard as a A10, A15, A55, A60, A64, 1400, 1405, 1410, 1415, 2400, 2405, 2410, 2415 ... and many others. A new replacement keyboard should run about $20 on eBay.
Replacing the KB is easy: lift up the power button board above the keyboard, remove the three screws holding the keyboard down, then remove the keyboard connector cover panel, and you'll be able to disconnect the keyboard.
Oct 11, 2009 | Toshiba Satellite A40 Notebook
How do i get to run the cd to repair os
From BIOS setup, change the boot order as the firsy boot device as CD/DVD drive. Reboot the after inserting bootable OS disk in to drive. It will prompt you to press any key to boot from CD. Follow the steps.
Jul 14, 2009 | Toshiba Satellite 1410-S173 Notebook
How to manual on replacement of cmos batter in Toshiba 1410-S173
cmos battery is present inside the motherboard...go to tosibha website and enter ur model no...der u can download the hardware mannual for the particular model
Jul 04, 2009 | Toshiba Satellite 1410-S173 Notebook
Need to replace keyboard on my Toshiba Satellite 1410-s173. How do I gain access? Which screws should be removed and which should be left alone?
The plastic strip above the keyboard - you need to remove it (start by using a small, flat screwdriver and using the Windows key as leverage). After that, it's three screws (L, middle, R), then set it upside down over the touchpad, and disconnect the cable by lifting the connectors up.
That oughta do it!
Apr 18, 2009 | Toshiba Satellite 15" Flat Panel LCD...
Toshiba 1410. Won't turn on
Sounds like a dead battery, You need to try it with an alternative battery, most laptops won't aeven switch of if the battery is damaged, also try ro pull out the motherboard and find for dry joints. i.e. any lose transistor or capacito and try to re-solder it, the put the laptop back together,
Feb 27, 2008 | Toshiba Satellite 1410-S173 Notebook
Toshiba cmos battery disconnect
on a Satellite 1415-S115 You will have to open up the clam shell and remove all of the B25 and F6 screws from the bottom, as well as the B16 and B6 screws under the keyboard. To remove the keyboard, pry up the trim piece that holds the power button with a sharp nife a stanley blade is always usefull remove the three screws. mind the wireless wire leads there a pain.
The CMOS battery will be under the right side of the hand rest, next to the mouse. It has two leads and the battery is in a blue bag.
simply replace the battery and reassemble your laptop.
Dec 07, 2007 | Toshiba Satellite 1415-S173 Notebook
Toshiba Satellite 1410-S173 Notebook Logo
270 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
