Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fisher paykel won't finish spin cycle
The machine goes through all cycles until the final spin. I removed the sheet and tested for a code and it indicated I have a problem with my clutch or pressure tube. I removed the agitator and unscrewed the plate holding the tub in but I can't remove the wash tub from the barrel.
  • 69 Answers
To remove the tub you need to remove the spin motor magnets and stator, then using a tube soket undo the tub nut and it will come out. (not EASY JOB)
Posted on Sep 23, 2007
Aquasmart wl80t65dw1
Hello Tim. This is an annoying issue with the FP washers from the GWL15 and up. You will need to replace the main control, p/n 421232NAP If the unit is under warranty, call Fisher Paykel for service. If not, the control costs $168.00 US and is a fairly simple proceedure to replace.
Apr 09, 2014 | Fisher and Paykel Washing Machines
F&P Washing Machine. WL80T65DW1. Washing cycle doesn't end...
Hello Tim, This is a frustrating issue on the F/P washer. You will need to replace the control board in order to solve this problem.
F&P GWL11 Washer Stops at rinse - Error Code 37
I hate to say it but it sounds like the controller. I used to have one that had a similar problem that was fixed with a diverter and a controller. Another year or two later it was doing the same thing, so we just replaced it. Just a warning.
Jul 08, 2012 | Fisher and Paykel Washing Machines
My Fisher & Paykel washing machine continually stops and beeps on spin cycle GW703. Move clothes around and continue, goes for a while and stops again, seems it is sensing it is unbalanced.
There should be a tech sheet located underneath the control panel that has a fault code matrix. Compare the lights to what you see on the sheet, and read the details.
Mar 05, 2011 | Fisher and Paykel Washing Machines
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
The rinse and spin cycles never end
I have seen this often on another brand. Once it starts malfunctioning on the rince/spin cycle, the boars needs replacement.
Nov 13, 2009 | Fisher Paykel EcoSmart GWL15
Paykel fisher wash problem
its possible, depending on problem with unit, if youd like you can acess a tech sheet behind the console,theres a pretty good desription of common troubles encountered and fix it solutions.
Feb 27, 2008 | Fisher and Paykel GWL11 Top Load Washer
Doesn`t finish cycle
Thanks for the information !
Sep 19, 2007 | Fisher Paykel EcoSmart GWL15
Fisher & Paykel GWL10 US won't spin
If the machine still has water in it, the drain pump is jammed or there may be an obstrution in one of the hoses. It is most likely the drain pump. Switch off the machine at the wall and unplug it. Tilt machine against a wall and look underneath. On the right you will see the drain pump. It looks upside down. Unplug the wiring harness to the pump and remove pump by turning it clockwise while at the same time releasing the little white clip that holds the pump in place. Clean thoroughly and replace pump.
Sep 16, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
264 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
