Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
26 side by side with ice maker doesn't work
MOD. GS6SHAXMS00
SER. SP3047564
drinking water works. But ice maker isn't making ice? Thank you for any help you can offer.
  • Anonymous Apr 20, 2009
    the same problem, Ice maker do not make ice
  • rmeredith Apr 21, 2009
    The ice maker does not make ice. I have used a hair dryer on the black tube that fills the ice maker in the past, and that worked, but I'm not having any success now. There is no water in the ice maker and I don't know why. Anyone help? Thanks.
    Genius:
  • 1,198 Answers
The water control valve can get clogged or fail. Follow the line from the supply( did you check for filters there?) to the bottom of the fridge. The valve may be just like the one on a washing machine. It has a wire filter in it too. Test it for flow, unhook the pipe to the ice maker and see if water comes out of it when it is energised. I made a test energiser out of a power cord with the same connectors that the valve has.
Posted on Apr 25, 2009
My ice maker isn't getting water in to make ice. I can manually pour water into the maker, let it freeze, and get the maker to get the ice out, but no water comes in. GE model GSHS5KGX. Side by side...
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 26, 2011 | General Refrigerators
I have a side by side with ice/water dispenser on the freezer side of the door. a couple of months ago the ice maker stopped working and just today the water stopped coming out the dispenser and none of...
1light not work , may lightbuld loose in the socket , or door switch
2 ice maker not work? may the ice maker arm shut-off. sut-off arm to be on(sure be down position)
3 is the ice maker switch in the off positio ( on some models)
4 is the freezer door not closed completely ? if it will not shut all the way,push the door firmly shut for the water dispenser poblem
5 check water filter. or water valve clogged or bad? replace them if necessary
good uck
Jan 11, 2011 | Whirlpool Refrigerators
Ice maker just stop making ice but water still works
LG refrigerator ice maker stops making ice but water stills works
Mar 27, 2010 | Admiral 26 cu. ft. Side-By-Side...
Ice-maker has stopped working. Mod. ED25LFXHT02 Ser. SL0435597
Has it stopped because it ain't gettin water? Or has it quit because of internal failure of some sort. A nice thing to know is just how ice makers work. The ice maker does all the thinking. It calls for water and it knows when to take a dump. Nothing else in the ice box makes the ice maker do what it do. If you have no ice in the mold add some H2O to it and see if it indeed kicks out some ice. If it does then you needs ta look at replacing the water valve and even the water filter (I would). If you have ice in the mold but none in the bucket then that could be the ice mild thermostat. An easy fix. I have repair photos,video,and manual: HERE
Mar 27, 2010 | Refrigerators
Water in door works but ice maker quit .its a roper side by side mod#rs25aqxfnoo ser#sg1235753
That ice box uses a dual solenoid dual mechanical valve and operates the water on one side and ice maker on the other. The solenoid for the icemaker (which has a smaller water line) might be open or the mechanicals inside may be fouled with sand and sediment or lime deposits. If that checks out then the thing that powers that water valve is the ice maker itsel. So if your water valve is good then your ice maker is bad most likely. I have a page which shows repair photos and manual: HERE
Feb 14, 2010 | Refrigerators
Ice maker not working, water not going in tray.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
iuoiout
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Ice Maker Problem
my ice maker stopped making ice. Green light is on. Drinking water is ok
Feb 17, 2008 | GE GSS20IEP Side by Side Refrigerator
I replaced both silinoids and the ice maker. The ice maker will freeze water but not fill with water. My refridgeratoor is an a Amana
Dec 16, 2007 | Whirlpool ED2FHSS Side by Side...
Ice maker not making ice
Same thing happened to me. I unplugged the refrigerator, plugged it back in and it worked. I guess the computer system reset itself. Easy fix.
May 13, 2007 | Maytag MSD2756G Side by Side Refrigerator
Ice Maker Not Making Ice
There is no pump per say.. the water pressure is all that fills the ice maker and provides water to the drinking dispensor. The solenoids are also different, one activates for ice maker and the other for drinking water. The fastest way to check water flow is to swap the wires on the solenoids so the drinking water "power" will now power the ice fill solenoid. Once the plugs are swapped and you press the drinking water lever the ice maker should pour water out the fill tube. If that works then you know the solenoid, tube, etc. are all fine. I'd suspect then that the ice maker fill solenoid isn't getting power when it is suppose to fill. Let me know what this test result is.
Jan 23, 2007 | Samsung RS2534 Side by Side Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
318 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
