Need wireless printer to work everytime i turn it on without trying to find new ways to make it work!
Every time i plug my wireless printer into an outlet, and turn it on, it always sais its disconnected and won't print. To make it print once i had to reinstall it, once i had to reconfigure it, the next time i went to printer properties and unselected "enable bidirectional support". all these redos allowed it to print, and once again i need to print something. I had a disc that came with the printer and I try to use it to make the printer work.What can I do to just plug it in, turn it on and make it print like a connected with cable printer would work?
    Problem Solver:
  • 6 Answers
Are you using Windows? If so, when it boots (if it comes up clean then do this)
1) DO NOT TRY TO PRINT
2) Check the status of the printer (enable,disable,offline, etc)
3) The one you want to see is enable or ready.
4) By the way,you want bidirectional 'ON' because your printer won't print correctly. (That's if you have a bidirectional printer)
5) If it is showing any of the codes in step 2, try and correct them.
6) If that doesn't work, check your printer for any loose wires or connections and check the wall outlet to see if it is plugging in correctly.
7) If that doesn't work, get your owner's manual out and see if you can ran a diagnostic test on it. Some printers have a built in program that will let you do this.
8) Last but not least, go to the website of the manufacturer of your printer, go to either FAQ's or knowledge base. Look for either an error code you have seen or description of the problem.
Hope I haven't confused you to much, I just recently retired from the federal government after working on computers for 22 years.
Posted on Aug 05, 2009
Dell Dimension 4550 and HP printer 2410. Everytime computer is turned on, it detects new hardware and reinstalls the printer, and repeats the process again. After that, the printer seems to work OK.
disconnect the printer, go into device manager and delete all the printers listed there. go onto the printer manufacturer website and download the drivers manually then install them. Hook the printer back up.
Aug 25, 2012 | Dell Computers & Internet
Router operation without Internet connection.
Yes i can help you with this
You dont need internet connection
Feb 12, 2008 | Linksys Wireless-G WRT54G Router
We have an oj8500 (not wireless) printer connected to one computer operating on windows xp. We can to add a computer operating on windows vista to the printer. is there a way to do it that works? if so,...
Yes, if both these computers are on a network (wireless or wired, doesn't matter), the printer can be shared on the XP machine and then found and installed on the Vista machine.
The only disadvantage is that the sharing machine must be on all the time in order to make the printer available to the other computer.
To share a printer, open the Printers and Faxes applet from Start Menu -> Settings, right-click your printer and choose Sharing. The system will guide you.
Afterwards on the Vista computer you must install a new printer and tell it to search for a network printer - it should be found and installed quite easily.
Please come back and rate the solution if helped or post a comment for further assistance.
Thank you for using FixYa, the community-based help site :)
Jul 24, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I have an ongoing problem with my HP Officejet 6500 wireless printer. Everytime I need to change the three color cartridges, I get the same error message: "The following ink cartridges appear to be...
This normally happens when the "window" on the ink cartridge is dirty. It may not even appear to be dirty, which is hard to tell, because it is a cloudy and dark gray color, but it still needs cleaning.
The manual (at least on 6500) says to clean the little "window" on the cartridge. For some reason this needs to be done even though it is new and you receive the message.
If cleaning with a normal cloth does not work, try cleaning it with some rubbing alcohol as well as this usually does the trick.
This has unfortunately been a common problem with the HP6500 printers.
May 05, 2011 | HP Officejet 6500 Wireless All-in-One...
I am attempting to scan a document with my X4650 without success. The copy function works with no problems. I have used the scan function to my computer on numerous previous occassions without problems.
How is your printer connected to your computer, wireless or hardwired with a USB cable? If wireless, check the status of the WiFi light on the printer (green = connected to a network, orange = not connected to a network). Try to turn off/on your printer. Doing this usually fixes minor communication issues. This article in the Lexmark website might also help resolve your scan problem: No Communications Error When Trying to Print or Scan.
Apr 18, 2011 | Lexmark X4650 InkJet Printer
My Brother printer will not find an IP on the router. I've tried multiple ports, but all I ever get is zeroes, no IP, but the router works fine, I'm connected to it right now. Everything else thats...
The best way to have this printer work is to connect it with an lan cable. Here are some steps to check if the printer will work again.
Disconnect the lan cable from both ends. Make sure that the printer shows the blue solid light, Try to do the factory and network card reset. First turn off the printer by pressing he switch button on the right side. Press and hold the GO button while turning it on, then press go button 8 times as fast as you can without delay. Once you see the blue light solid again turn off the printer and do the network card reset. Turn off the printer by pressing the switch button on the right side. Press and hold the GO button while turning it on, then press go button 7 times as fast as you can without delay. After 1 minute reconnect the lan cable from the router to the printer. Wait 1 minute again the press the GO button 3 times without delay, it should printer the printer setting page that shows the correct IP address.
Hope this will help.
Feb 27, 2011 | Brother HL-2170W Laser Printer
I have an HP Photosmart Premium Printer Cd055a and it is connected to my wireless network. However, everytime I send something to the printer it says that the printer is offline. The wireless radio on the...
Check the IP addresses of your computer and Wireless Printer. It should be in same range. For Example if your PC is configured with static IP 192.168.1.1 then your printer IP address should be 192.168.1.x (First 3 octact must be same).
If IP addresses are in same range then try to PING Printer IP from Computer command promt in this way
ping 192.168.1.x (where x is Printer IP address) if reply is comming. then Goto start menu , Printer and faxes and double click priter and remove check mark "Printer is Offilne" Printer Menu.
Mar 11, 2010 | Office Equipment & Supplies
Wireless Router doesn't work without unplugging it
Find the reset button on it, if it has one and press and hold it for 40 seconds and wait for all the lights to turn green.
Jul 11, 2017 | Xincom XC-DPG602 Router (XCDPG602)
Lexmark all-in-one x4690. I am trying to set it
Turn on the wireless on printer , Go to printer option in control panel , Clicked on add printer , Then click on wireless and bluetooth device , Let the wizard detect the printer, once detected put the disk and run software installation Post reply if you need any help, You can contact me for any help +91-9958531192
Chandan
Sep 10, 2009 | Office Equipment & Supplies
!!!HEP!!! Zyxel M-302
Have you tried enabling the Wireless Zero service? In Control Panel/Admin Tools/Services, scroll down to Wireless Zero and enable it. Some cards use their own interface, some use Wireless Zero. Do you have Wireless Icon showing in the System Tray? You should be able to access the settings by Right-clicking this icon.
Jun 29, 2007 | Zyxel M-302 (M302) 802.11g/b Wireless...
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
