Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Digibox connection need to connect digibox to tele to vcr but dont know which scart goes where. Av1 or 2? Digibox only has one scart coming out. Tele and vcr have 2 scarts. Have tried various combinations. Any ideas for me?
  • 520 Answers
If you look at vcr rear the scarts usually indicate one as tv(scart to tv) so connect scart from sat to scart next to that one then another scart from tv scart to tv in any scart.
I have sky , two dvdplayers (one recorder) and my projector all linked up and a video sender in line so as to watch anything downstairs on tv upstairs.
Posted on Mar 10, 2008
Try looking on the links from a thread on connecting a PVR on bbc.co.uk's POV digital pages
Posted on Dec 21, 2007
SOURCE:
How can I set up a Bush Digi Box with 2 scart sockets to a Sony combined DVD & Videao Recorder with 2 scarts to a Sony TV with 3 scarts
Bush Digi box - 'TV' SCART to TV
Bush Digi box - 'VCR' SCART to DVD/Video recorder 'TV' SCART
The digibox will pass through when the DVD/VCR is playing.
Aug 30, 2014 | Televison & Video
Wil my tv work with out remote
There are quite a few ways to connect cable box, DVD, receiver and TV together. At a minimum---Connections between DVD and a/v receiver: For Audio, either digital coaxial, digital optical or simple RCA (CABLE ONE); If you did not use RCA you need to connect Video with either component or s-video (CABLE TWO). For connection between a/v receiver and TV: either component, s-video or RCA (CABLE THREE) You did not mention how your cable (or sattelite) box is connected. You could use same set-up as between DVD and a/v receiver for another one or two cables depending on set-up used.connecting the speaker wires of an RCA TV to an amplifier: The signal that is fed to the speakers is not designed to be fed to the line-level inputs of your amplifier. You'd need some kind of conversion and I can't tell you exactly what that would be.
Get some double-screened satellite cable and fit a female TV plug to it (or a male plug with an adapter). Connect it to RF Output 2 at the rear of your Digibox. Fit a TV plug to the other end and plug it into your TV.
Temporarily disconnect the aerial feed from the Digibox aerial socket. Switch the Digibox on to get a picture on your main TV. The Sky Digibox normally sends its signal out on UHF channel 68 so go to the second TV and tune it to 68 (or tune it till it finds the Sky picture).
Now plug the aerial cable back into the Digibox. If there is now interference on the Sky picture on the second TV (or on the terrestrial channels) your Sky signal on 68 is causing interference. Press [services] 401 [select]* and set the RF output to a different UHF channel number. You need to connect it via a Scart lead on your main TV in order to see the menu.
*In the new EPG (April 2009) it's [services] 001 [select]
Try each RF output channel number in turn (21 - 69) and retune the second TV until you get clean pictures on the terrestrial channels and the Sky channel. Also check the picture from the VCR (if connected).
This is just a brief overview. If you need a real in-depth explanation you should read the "Piping TV Around the House" Ebook by satcure.
Nov 22, 2011 | AOMNI Corporation Televison & Video
Lost arial connection
Have you made sure that the correct 'source' has been selected on your TV? What does the TV show? Does it show, for instance, the menu?
Connect it all up and turn on. Now repeatedly press the button on your tv remote that changes the signal input. This button will be marked as a square or circle with an arrow through it, or will me named source or input. With any luck you should see your digibox.
May 03, 2010 | Sagem PVR 6280 Freeview DTV Receiver /...
How do i connect my dvd video/cassette recorder so it plays and displays through the t.v. I have a sat. dish
connect one scart from tv to digibox and the other to the dvd player then connect both machines with a third scart then tune both machines using the tv remote
Jan 25, 2010 | Televison & Video
Equipment and Locations (Denons are physically 15ft apart) Room 1 Sky Plus Satellite Digibox; (without HDMI outlet), but with one optical, one scart-video, and two Scart outlets. Panasonic DMR-EX77EB DVD...
Hi Martin,
A wiring Schematic is not that you should be looking. What you need is large feeders to understand hot to connect to various ports to give your desired output.
Jul 03, 2009 | Denon Audio Players & Recorders
To connect analogue VHS/DVD player to digital Tv via digibox
if your digi box have two scart socets that no problem.one of them is mark ( to vcr ) and another is mark ( to tv ) or use rf cable
Aug 10, 2008 | Televison & Video
Sagem digibox connections
I think it´s impossible.
May 29, 2008 | Sagem Televison & Video
Broken coax input to back of tv
NOT REALLY BUT YOU COULD GET ROUND IT BY BUYING A £20 DIGIBOX (FREEVIEW BOX) AND CONNECTING IT TO THE TV WITH SCART AND ARIEL GOES INTO THE DIGIBOX (FREEVIEW BOX).
MEANS YOU CANNOT WATCH ANALOG ON THE TV ANYMORE BUT DIGITAL IS MUCH BETTER.
Nov 12, 2007 | Protron PLTV-26 26 in. HD-Ready LCD...
When watching dvd having showing or fade background
yes it can be down to signal degradation especially via scart lead, make sure you use a decent scart if you buy an expensive one you can tell the difference. Run a cable from your sky digibox direct to your tv to see if the picture improves.
Oct 05, 2007 | LG 42PX4DR 42 in. Plasma TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
136 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
