Question about Ecoquest Flair Air Purifier
Makes a funny sound when turned on
I cleaned the air purifyer and when I put it back together, now it makes a zzzt sound when you turn it on. Can you tell me what is wrong?
  • cuttingquart Apr 19, 2009
    The problem is in the purifyer. The fan runs smoothly. I tried both solutions and neither worked.
I had the same problem and it was the metal flaps that touch the glass cartridges. I took them out and pressed them down so that they had a tighter fit on the slides and the zzzt sound went away. Since my fan quit working, I knew it had to be another problem than something touching th blades. Hope this helps.
Posted on Apr 19, 2009
    Genius:
  • 1,027 Answers
Something is touching the fan blades.
Posted on Apr 18, 2009
Makes a hissing sound after I clean it
It may be a little late that I am answering your conundrum, but once you clean it, put the unit back together, tip it upside down until you hear a "click" and then turn it on. No hissing :)
Dec 24, 2010 | Sharper Image Ionic Breeze GP (SI730) Air...
I cleaned the unit and it will not stay on, I turn it on and it makes a clicking sound and turn off
Hi stella1221,
I work for the Ionic Pro company. Please call customer service at 800-875-8577 and they will be happy to assist you. Thank you, Mary
Nov 16, 2010 | Ionic Pro TURBO Air Purifier
Makes hissing sound, then immediately clicks to "clean"
you need to turn it off and remove plates,put in kitchen sink and spray with windex and dry with paper towels, now clean the bottom of the three plates too.
before you reinstall the plates look down inside you will see three thin lines of metal,make sure there is no lint or dust on them,reinstall and let set for five min. to allow any windex that might still be wet then turn on low for a couple of min.then go to medium
Dec 28, 2009 | Ionic Pro TURBO Air Purifier
Ionic Breeze GP S1830 - makes a sizzeling noise
Funny you should post this when you did as I just finished reassembling my S1730.
Mine was making very loud noise, arcing violently, smoking slightly and would give a good shock when you touched the plastic covers(yes dirty plastic will conduct electric current).
1. Unplug the unit
2. Take the plastic covers off, front has four screws and back has snap at bottom, both slide up when loose.
3. Wash the plastic covers
4. take the light out and clean it with windex
5. Vacuum the inside, be careful of the two corona wires
6. Find the bead on each corona wire and while turning them slight so the edges scrapes the wire, move them back and forth to scrap the white power off the wires
7. scrape the cone shape plastic that the corona wires runs into, this build up is the primary culprit of the arcing which is the noise you hear. be careful of the corona wires again. I used an exacto knife and gently scraped it, sandpaper has been suggested elsewhere, once done scrapping, wipe down to clean any residue. The top cones are only part accessible, after cleaning mine the noise still persisted but acceptably lower than before. I think if you completely take apart the unit you can clean this cones better.
8. Reassembly is the same is opposite of disassembling.
Hopes this helps you.
Aug 21, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Sharper image ionic breeze quadra air purifyer
I believe you have the same problem I have with my quadra. They have a fuse that is located in a very hard to reach area in the lower section of the unit. You have to look very closely to even find it. It's sodered in place place so one can't just change the fuse and turn it back on. Mine is blown and I can't figure out how to remove it. I was wondering if I could just by pass it but that wouldn't be safe.
Apr 15, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
I need to clean my Eco Quest Living Air purifyer plate...
clean with 50/50 ammonia/water, scrub with toothbtush, clean contacts with q-tip
Mar 01, 2009 | Ecoquest Breeze AT Living Air Purifier
The Kenmore air filter will not turn on.
Check the switch and make sure that it is getting power. You can also disconnect the connectors to the swiitch plug the unit back in and touch them together if that works then you know the switch is bad
Feb 14, 2009 | Kenmore EnviroSense 85501 Air Purifier
I have a lc1060 where do you put the vicks and the water at... Can you please Help me
What you have is an "air purifyer ionizer", not a humidifyer. humidifyers warm up and some people like to use vicks vapor rub. But you don't own one of those. So no you would be able to do that with this machine.
Jan 29, 2009 | Bionaire LC1060 Air Purifier
Sparks, rythmically every 3 seconds a cracking sound where the air purifyer is plugged into the wall
the sparking of the purifier by the plug is NOT good. it can be a fire hazard. there is a short within the switch. the best thing is to make sure that your under warranty and then call the manufacturer to get a replacement.
Aug 02, 2008 | Bionaire BAP825-U Air Purifier
Ecoquest Flair Air Purifier Logo
150 people viewed this question
Top Ecoquest Air Purifiers Experts
fordexpert
Michael Youngman
Michael Youngman
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
