Question about Kenmore 659 Electric Dryer
Kenmore Ultra Care Electric Dryer
When I cleaned the lint filter a pencil rolled in the hole. When I turned on the dryer a terrible grinding noise started. How can I get the pencil out of the filter area?
  • 291 Answers
You have to go in the back.. take loose the blower cover and pencil is probly in parts after hitting blower fan.. check fan for broken blades ect.
Posted on Sep 17, 2007
Is dryer ok to use while pencil in lint vent?
SHOULD BE OK BUT U CAN TAKE APART CABINET AND CLEAN VENT OUT
Aug 21, 2014 | Kenmore Dryers
Making loud noise
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
The drum rollers or idler pulley/belt would be suspect. The link above will help on all makes and models.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 19, 2017 | Haier HLP140E Electric Portable Dryer
Help - problems with screaching/grinding sound - small smell of burning
Did you remove the filter chute? My dryer was making a heck of a racket and I found a wire inside the blower housing:
Service manual and more
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 14, 2011 | Kenmore 659 Electric Dryer
I have a Kenmore Ultra Fabric Care Dryer. It does heat up, but takes four times longer than normal to dry clothes and no lint is appearing on the lint filter. I checked for a clog in the dryer vent and...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 08, 2011 | Dryers
A pencil fell into the lint trap of my dryer...now the dryer is making a grinding noise. Not sure how to remove it.
Take the lint trap out and turn on the dryer and it should force the pencil out through the outside vent by the blowing action of the air.
Apr 01, 2011 | Dryers
Hello I have a Samsung dryer model # DV337.Today I went to use it and cleaned out the lint trap. After I put the trap back I herd a Klink noise. I then turned on the dryer and it was making a noise like a...
When you pulled the lint filter something may have fallen into the blower which is just below the filter. Use a flashlight to try and see down the chute, if you cant find what is stuck there, you may need to call for service to disassemble the dryer to remove the object so it does not destroy the blower.
Apr 19, 2010 | Samsung DV337 Electric Dryer
Kenmore 70 series model 97576200
You have a bad thermal fuse , usually caused by lint blockage from the filter or vent hose .
Jul 06, 2009 | Kenmore 659 Electric Dryer
Kenmore elite HE4
THE AIR FLOW THROUGH THE DRYER BEGINS UP THROUGH THE HEATER AND INTO THE DRUM THROUGH THE HOLES INSIDE THE DRUM TO THE LEFT IN THE REAR.
THESE HOLES ARE METALIC IN COLOR AND MAY SHOW SIGNS OF DISCOLORATION DUE TO THE HEAT OF THE HEATER ASSEBLY. FROM THERE, THE AIR WILL FLOW ACROSS THE CLOTHES AND THROUGH THE LINT FILTER.
IF YOUR LINT FILTER IS LOCATED ON TOP OF THE DRYER,
THE HOLES WILL BE IN THE BACK WALL OF THE DRUM ON THE RIGHT. IF YOUR FILTER IS LOCATED IN THE FRONT OF THE DRUM, THE HOLES WILL BE JUST BELOW IT.
USUALLY, LINT WILL COLLECT DOWN INSIDE THE SPACE WHERE YOU INSERT THE FILTER ON A FRONT LOCATION.
PULL THE FILTER OUT AND LOOK DOWN INSIDE. USE A CENTER CARDBOARD FROM GIFT WRAP TO CLEAN OUT THIS AREA. FLATTEN OUT THE CARDBOARD ROLL AND PUT IT DOWN IN THE SPACE ATTACHING THE OTHER END TO A VACUUM CLEANER HOSE.
ALSO, DISCONNECT THE DUCT WORK FROM THE REAR OF THE DRYER AND CLEAN OUT THE DRYER DUCT AND THE HOUSE HOLD EXHAUST DUCTING. WHEN REATTACHING THE FLEX DUCT TO THE BACK OF THE DRYER, MAKE SURE THERE ISN'T ANY EXCESS FLEX DUCT SNAKING BEHIND THE DRYER. CUT IT TO THE LENGTH NEEDED. MAKE SURE IT ISN'T FLATTENED BETWEEN THE DRYER AND THE WALL WHEN YOU MOVE THE DRYER BACK INTO PLACE.
Apr 01, 2008 | Kenmore Elite HE4 Electric Dryer
Increased drying time; removal of lint behind tumbler ???
I have a top loading Kenmore High capacity dryer that is over 10 years old, it has been working very well, unfortunately when cleaning the lint filter my wife dropped a piece of paper down the lint duct hole. The paper evidently fell to the bottom of the lint duct. I am unable to reach the paper from the top of the dryer where the lint filter is inserted.The dryer now makes a grinding type noise when it is turned on. Can you tell me how to reach the paper and remove it
Mar 28, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore 659 Electric Dryer Logo
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
