Computer does not support 1920 x 1200 monitor resolution
My new monitor supports 1920 x 1200 resolution. My computer only supports 1620 x 1200 resolution. What do I need to do to modify so my computer supports resolution up to the 1920 x 1200 resolution
  • 272 Answers
That should be a graphics card related issue. may be, and should be the card you are using is not capable of showing that much resolution. May be you are using the built in supplied with motherboard. Please try a Driver update. If it does not work, pleasr think about installing a graphics card that is capable of showing that much resolution.
Thanks.
Posted on Apr 18, 2009
My computer monitor shows a message "out of range". I can't get rid of the message or show anything from my computer.
The resolution your computer is sending is greater than the maximum support resolution of your monitor that isn't working or is a resolution not supported. Connect one of the monitors that works and turn down the resolution to something small (800x600 or 1024,768) and then switch to the original monitor back, you should see a picture and can adjust the resolution to something larger that the monitor supports.
Aug 08, 2014 | Westinghouse L1928NV Monitor
Get my display to 1920 x 1080
When you are in display options and can see monitor 1 and 2... when you select 2 you should be able to adjust the display resolution there.
If you cannot do that for some reason, try the video card software that is specific to your video card as there might be better options in there for managing monitor 2.
Jan 20, 2014 | ViewSonic Computers & Internet
What dose it mean when screen says out of frequency
This error indicates that your video card resolution is set igher than the monitor can display. Try booting into safemode and changing the resolution.
Here is a link to the Gateway site spec page for that monitor.
http://support.gateway.com/s/MONITOR/7003943/700394318.shtml
The maximum resolution it will display is 1024 X 768 which is very low for current video cards, your card may not go that low. Check it if it does not go then you will need to get a new monitor that supports the resolution that your computer can put out.
Feb 19, 2012 | Gateway FPD 1520 15" Flat Panel LCD...
I can not get the resolution of 1366x768 for our new monitor.
1366 x 768 is a widescreen resolution. it depends on the monitor if it supports this resolution.
Apr 22, 2010 | Computers & Internet
When booting up my windows is loading and then my screen goes black and come up with an error: recomended resolution is 1280x1024... how do I fix this?
Most probably your computer has a higher resolution or refresh frequencies set in Desktop Settings than supported by the monitor. It might be also, that you have previously installed a monitor driver for a different monitor model, and the computer is using resolutions and frequencies supported by that previous monitor, with which your new one can't cope.
The solution would be to boot the computer in safe mode (hit F8 key when the computer is starting, you can hit it a couple of times, until you see a menu; choose "Safe Mode" and hit Enter).
Go to Desktop Properties, change to Settings tab, and click "Advanced" button. In the new window choose "Monitor" tab and change the monitor to "Plug and Play monitor". Click OK to accept the settings and close both windows.
Now reboot the computer - it should start with a rather low resolution, but the picture should be visible. Now you have to go to your Desktop Settings again, Advanced tab, and move the resolution slider to position 1280x1024. Accept and enjoy.
If the computer still doesn't boot, go to safe mode again, go to Control Panel, System, Hardware, Device Manager, drill down to Monitors, and delete all the monitor devices installed. After a reboot, system should start up and find new hardware, and install Plug and Play monitor. Set the optimum resolution of 1280x1024 as written before.
Nov 18, 2009 | Samsung SyncMaster 710VT TFT LCD Monitor
Windows xp got re programmed and no says no syc when starting and when gets to windows home page cuts off and says input not supported
you have done wrong setting for resolution
connect your computer with another monitor that support higher resolution. decrese resolution setting of your computer then connect your monitor that is creating problem and make sure for click on apply not on ok when you change resolution.
dont press enter without seeing the result of new resolution.
Basic problem is with your resolution you lower your resolution and it will solve your issue.
Have fun
Oct 02, 2009 | Acer AL1916W 19" LCD Monitor
Just bought an Acer AL2216WBD flat panel monitor. Have an old Dell computer; "Jewel Quest" game loaded. When I plugged in the new monitor, tried to play the game. Good sound but no picture. Only "input...
the resolution is incorrect for that new monitor , it does not support it, attach the old monitor reduce the display resolution and then hook in the new monitor, up the resolution until it fails again and do nothing it will reset to the last good display resolution and you can leave it there.
hope this helps
Mar 06, 2009 | Acer X193W LCD Monitor
Envision LCD EN-7100e Monitor "Input not supported
Either your display card is not supporting the LCD resolution.
Apr 23, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Resolution problems
Colsult your user manual or online documents, this may be an incompatible resolution for your monitor, whatever it is.
Oct 03, 2007 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
325 people viewed this question
David Payne
David Payne
