Question about Dual XDMR7710 CD Player
How do you get to the setting on the XDMR7710 for the sub woofer.... my beats but not like i want it too its very soft and the bass just blurs it alot???
  • 15,935 Answers
CLICK HERE for your owners manual.
This model does not have a dedicated subwoofer output.
You must use the crossover on your amplifier (if equipped) or install a seperate crossover to eliminate frequencies above 80Hz from the subwoofer output.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 18, 2009
What is a sound bar woofer and function
A woofer is a device that producers low frequency bass sounds. Often in a form of Sub Woofer. Bass sounds are not directional. So once set up it will give the rumble and vibration needed to the sound system.
Dec 27, 2016 | Audio Players & Recorders
My powered subwoofer no longer works through the receiver
if you have your front and centers set to 'small' you want your Bass out to be subwoofer only, and the rca jack labeled 'sub out' is the only place to connect your sub to if you want to control the frequencies with your reciever. I dont know the brand of your sub, or the inputs on the back of it to advise you where to connect, but it sounds like it worked for you at one time, but suddenly it does not
Mar 05, 2013 | Audio Players & Recorders
How do you adjust the bass levels on a Yamaha HTR6130 receiver? I can get the display to show Bass 0db, but what button changes the settings?
When you touch tone button on your front panel repeatedly, you will get two option for setting bass and trebble, when you select Bass immediatly press your updown Sound field Program Button.
Please note:for better sound if your using Small front speaker keep bass to 0db and select the low frequency through sub woofer and program manually LFE from only Sub woofer and addjust CUT off frequency of Subwoofer to 160 and incase if your bass is not clear put it into rev mode.
Oct 05, 2009 | Yamaha HTR-6130 Receiver
Sub woofer is blowing up and down even when head unit is off
This is an internal power supply failure - most likely a failed capacitor or bad ground trace..
Your amplifier requires repair.
To verify this - remove the RCA cables and if the "heartbeat" is still present - take the amplifier to a local repair shop that specializes in car audio and tell them your symptoms.
Jun 10, 2009 | Sony XS-L121P5 Car Subwoofer
I can't get bass thru the spkrs
So when you aren't using the sub woofer there's not enough bass, so you need more out of the other speakers. Chances are the front speakers are set to "small" in the receivers menu, change it to "large"if your front speakers have a 6 inch woofer or larger. Note: If you leave the sub on, the input signal to it will be greatly reduced when the speakers are set to "large". Hope this helps.
Feb 12, 2009 | Sony Audio Players & Recorders
Djust
alot of times its not just the amp that gives you better sounding bass.. A lot has a to do with a few other factors as well.. first off your subwoofer.. the bigger the subwoofer the deeper the bass. Some woofers exturde, or flex differently depending on the quality and structure of the woofer.. 2nd is gonna be the sub box. different size boxes will give your sub diff. depths of bass. ... general idea is the bigger the box deeper the bass. But if your woofer is not supplied enough power a big box is useless.   With that size amp your best bet is too run a single woofer. Probably a 10inch woofer would sound the best.. but it in.75cub inch. sealed box.. should sound great.
Nov 11, 2008 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
JVC TH-M606
You need to take apart tthe sub woofer and check the connection to bass speaker for continuity. It sounds like an internal broken connection to speaker on sub woofer unit.
Aug 12, 2008 | JVC TH-M606 System
HTS 6500/37 sub woofer
the reciever should have a "subwoofer level" setting, or a "bass level control" If you cannot find this then try to place the "sub-woofer" away from walls and elevate it from the floor. This will reduce it's loudness/ intensity at annoying frequencies...
Good Luck
Jul 25, 2008 | Philips HTS-6500/37 System
Dual XDMR7710 CD Player Logo
102 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
