Question about HP Computers & Internet
Thinking about purchasing a HP loading dock HP DV2000(ES631AA)
Will this work with my new purchased laptop dv3 series?
  • HP Master
  • 13,433 Answers
Compatibility document.write(neg_specification_newline('HP Pavilion dv2000, dv6000, dv9000; Presario V3000, V6000 series; compatible (reduced functionality) with Pavilion ze2000, dv1000, dv4000, dv5000, dv8000; Presario M2000, V2000, V4000, V5000; HP Special Edition L2000 series using included expansion base adapter
Note: When using a notebook that requires the included Expansion Accessory Adapter, the following functions will not be supported on the HP Notebook QuickDock: VGA port functionality, stereo microphone (only mono is supported) and power button (must use the notebook power button).')); HP Pavilion dv2000, dv6000, dv9000; Presario V3000, V6000 series; compatible (reduced functionality) with Pavilion ze2000, dv1000, dv4000, dv5000, dv8000; Presario M2000, V2000, V4000, V5000; HP Special Edition L2000 series using included expansion base adapter
Posted on May 05, 2009
  • Ekse May 05, 2009
    that didn't come out properly.
    Compatibility HP Pavilion dv2000, dv6000, dv9000; Presario V3000, V6000 series; compatible (reduced functionality) with Pavilion ze2000, dv1000, dv4000, dv5000, dv8000; Presario M2000, V2000, V4000, V5000; HP Special Edition L2000 series using included expansion base adapter
Im on a laptop and the back light usually just flickers but the screen has gone dark and i have to use a flashlight to see the screen.
Replace the Inverter, rickeyjsmith.
An LCD screen cannot produce enough light by itself. An additional light source is needed.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp. (Lamp = Bulb)
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale in physical size.
(Average size is 3 to 5 inches long, and half the diameter of a No.2 pencil)
An Inverter is used to provide power to the LCD screen, and the Backlight.
90 PERCENT of the time the Inverter is the problem.
Which is a Good thing.
The Backlight is located inside the metal frame that hold the LCD panel layers together.
Usually on one side of the LCD screen.
{Some LCD screens require Two Backlights}
Replacing a Backlight is a job for a trained repair person.
The LCD screen is a composite of layers.
http://solutions.3m.com/wps/portal/3M/en_US/Vikuiti1/BrandProducts/secondary/optics101/
A lot of times the LCD screen is replaced for Backlight replacement, because some LCD screens require this.
Backlights cost more than an Inverter, and of course an LCD screen costs much more.
This is an example of an Inverter for an HP pavilion dv2000 series Notebook PC,
http://www.buy.com/prod/new-usa-lcd-inverter-hp-pavilion-dv2000-dv2100-dv2200/q/sellerid/23962916/loc/101/217117085.html
The above is ONLY an example.
An Inverter MUST be matched to THE LCD screen.
Stating Pavilion dv2000 is only stating the series.
The EXACT Product Number is located on the bottom of the laptop in a white Service Tag.
P/N = Product Number
Also, there is an HP part number on the Inverter.
Match the HP part number to the listing for the Inverter you are going to purchase.
A reputable seller will list THE HP part number so that the buyer will purchase THE correct Inverter.
How to replace an Inverter in an HP Pavilion dv2000 series Notebook PC;
1) Service Manual
I'm going to use the HP pavilion dv2000 CTO Notebook PC as an example.
The Service Manual is the same for All of the Pavilion dv2000 series of Notebook PC's,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=1817074&
On this page click on the file name >
HP Pavilion dv2000 Notebook PC Maintenance and Service Guide.
After you click on the above link it may take up to 30 seconds, or more, to see the first page.
In the meantime you will be viewing a blank white page.
The PDF file is downloading in the background.
In the Bookmarks menu to the left, click on the + sign to the left of >
Click on the + sign next to > Removal and Replacement Preliminaries
Read up on Anti-Static Precautions
Now go back, and click on the + sign next to >
Removal and Replacement Procedures.
Scroll the sidebar down, and click on > 5.12 Display Assembly
Direct information on replacing the Inverter is on Page 152.
(Page Number Box at the top of the PDF file, to the right of the blue Down Arrow)
I use a computer pick to ease up on one side of the rubber Screw Covers. You may have a similar device you can use.
If you are careful with the rubber Screw Covers, you can reuse them.
There is a contact cement on the covers.
Lay them down glue side up on a piece of paper.
(They do like to stick to the computer pick, and your fingers, however. Giving you a 'heads-up'.
Try to keep the glue side from picking up debris, however)
If you need guidance, no matter what it is concerning this procedure, please post in a Comment.
One more thing that pertains to the HP pavilion dv2000, dv6000, and dv9000 series of Notebook PC's, that I think you should be made aware of,
http://www.youtube.com/watch?v=bnkQNmKauEc
Regards,
joecoolvette
Dec 05, 2010 | HP Pavilion dv2000t Notebook
What are the appropriate steps to connect an external monitor to an HP Pavillion DV2000? When I try, nothing appears on the external screen... Thanks, RF
One of the function keys has a small monitor screen icon. Press that key while holding the Fn key, and you will enable the external monitor connector. These laptops don't automatically sense when you've connected an external monitor. On some models, the first press enables the external monitor and shuts off the laptop screen. If that happens, press the keys again and the laptop screen will come back on.
Oct 14, 2010 | HP 417035-001 - HP Pavilion dv2000 Series...
I have a HP DV2000. Is there something I can use to turn the Expansion Port 3 into a HDMI port and connect to my HDTV? Thank you very much
we can purchase a port replicator or a docking station
make sure that that has a HDMI port on it
thats the only way we can take care of this issue
Dec 14, 2009 | HP Pavilion dv6000z Notebook
Compatibility between HP Quickdock 2.0 Docking Station KN745AA and HP TouchSmart tx2-1020us laptop for external monitor viewing
Your tx2-1020us is not compatible with the KN745AA as this device is only compatible with the following:
  • HP Pavilion dv2700 Entertainment Notebook PC series
  • HP Pavilion dv6700 Entertainment Notebook PC series
  • HP Pavilion dv9700 Entertainment Notebook PC series
  • HP Pavilion dv2600 Entertainment Notebook PC series
  • HP Pavilion dv4-1000 Entertainment Notebook PC series
  • HP Pavilion dv5-1000 Entertainment Notebook PC series
  • HP Pavilion dv5-1100 Entertainment Notebook PC series
  • HP Pavilion dv6-1000 Entertainment Notebook PC series
  • HP Pavilion dv6-1100 Entertainment Notebook PC series
  • HP Pavilion dv6600 Entertainment Notebook PC series
  • HP Pavilion dv6800 Entertainment Notebook PC series
  • HP Pavilion dv6900 Entertainment Notebook PC series
  • HP Pavilion dv7-1000 Entertainment Notebook PC series
  • HP Pavilion dv7-1200 Entertainment Notebook PC series
  • HP Pavilion dv7-2000 Entertainment Notebook PC series
You can find the compatibility chart by clicking here
You can find the compatibility information for the ES631AA by clicking here
To resolve your issue you should purchase one of the following:
To dock your notebook you need the HP QuickDock KN744AA#ABA or
You could get HP Notebook Media Docking Station
May 15, 2009 | Computers & Internet
My laptop's body broken
I but parts for laptops all the time at Impact. www.impactcomputers.com. They have cases and case pieces.
Mar 27, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
My dv2000 boots but screen is split into like 8 parts (each part showing same thing) there are some wavy lines..sometimes its ok ...i try to load windows vista recovery (from partition) - it crashes on...
I have the same problem that my screen splits into 6 but occasionally screen comes normally. I gave to HP service center and they told me to change my mother board. I was worrying about the cost of Mother Board bcoz it costs 1/3 of my purchased rate and also my warranty was expired just 2 months before.
So, I tried some way to fix this temporarily, while screen comes normally, I went to Safe Mode, it works fine. So, I got an idea, it works in less hardware access, I think, how it works when removing NVIDIA display driver. So, I removed it. Now, it works fine but there is a difference in display but that doesnt matter while comparing previous.
I'm still searching permanent solution. I'm planning to change the Hardware of NVIDIA card. Lets see,
Jan 19, 2009 | HP 417035-001 - HP Pavilion dv2000 Series...
Hp pavilion dv2000 notebook will not boot up
hi,
i m in Hong Kong. The stupid HP repair center charged US 90 just for inspection!!!!! They they said the whole motherboard had to be replaced, thts additional US 630 dollars, the thing is just 1.5 yr old. They also said i don get to keep the broken mother board after replacement. This is simply irresponsible, unethical, sleazy and UNJUST!!
Thanks. right now the computer is fixed for US70. when i hv time, i'll open it up and see if i can figure it out how it was fixed. The shop suggested tht the computer wont last too long. This is such bad quality for HP... Sorry, i hv to do the following for other victims to find this easily:
(can some creative netizen bring this to the public light to pressure HP to do the ethical things??)
bad quality HP. hong kong HP pavilion dv2000 series manufacture problem. HP unethical.
Sep 21, 2008 | Computers & Internet
DV9205eu display problem
HP has identified a hardware issue with certain HP Pavilion dv2000/dv6000/dv9000 and Compaq Presario V3000/V6000 series notebook PCs, and has also released a new BIOS for these notebook PCs, version F.39 for dv2000/V3000, and version F.3D for dv6000/dv9000/V6000.
Click HERE to update your BIOS
May 03, 2008 | HP Pavilion dv9000z Notebook
Computers & Internet Logo
314 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
