Question about HP E427 Digital Camera
Memory card problem
It is a hp E427 digital camera it was working fine. but suddenly it says the card is not readable and battery is down even with the new batteries.
Use batteries with higher mah value prefereably above 2000 mah .use energizer or duracell
Posted on Sep 24, 2008
SOURCE:
I was taking pictures with my digital camera and all of a sudden the lcd screen said memory card not readable, need to format card. i selected cancel. the card is full of pictures from a recent vacation. ...
Could you please tell me the type of camera (model) and the type of memory and the computer that you are running? You might need to purchase a memory card reader and plug it into your computer and then eject the memory card from the camera and insert it into the memory card reader. Some computers come with a memory card reader in them. I would try that first.
If you filled the memory card past its capacity, you may have compromised the photos that are on it.
Mar 12, 2011 | Cameras
I have a E427 amera --I have lost the instructions--are you able to E-Mail me the instructions, and also what type of cable to use, since all was lost. Thanks Carole
You can download the manual from
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=1844261&lc=en&cc=us&dlc=en&lang=en&cc=us
You might want to consider NOT connecting the camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Dec 06, 2010 | HP Cameras
My agfa camera all working but put memory card unlock coming
The error you mentioned is usually when the memory card is unreadable because it is locked. If you check the picture below you can see that there is a lock button. If you slide it down the memory card will be locked and will not be readable, if you slide the button up it will be readable and will be unlocked!arjuun.jpg
Dec 06, 2010 | Agfa DC-730i / AP1100 Digital Camera
HP PHOTOSMART E427 CAMERA IT WORKS FINE WITH NO SD IN IT BUT WHEN I PUT ANY SD IN THE CAMERA IT SAY THAT IT DOES NOT HAVE THE RIGHT FORMAT... note, it gives me an option to format or cancel ive chosen...
1. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. 2. Insert the card and again, go into the menu and do the format thing again. Do not stop to select one of the choices the camera has offered before. Go straight into the menu and format from there.
Sep 06, 2010 | HP Cameras
BROKEN lcd display
look up the model number on ebay and then find sub heading for parts- order part and install
May 13, 2009 | HP E427 Digital Camera
The card on my Photosmart HP E427 appears to be locked all of the sudden. I get a message that says "cards is locked" - What caused this and how do I unlock the card?
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Mar 17, 2009 | HP PhotoSmart M437 Digital Camera
HP photosmart E427 camera--No power!!!
dear,
if you are a technical person or can handle the electronics then open it from the screws and see if the cable or points that connects battery to the circuitry are broken or desoldered or unwired...
if you cannt handle it so dont try.. get it repaired by a technical person near u...
regards,
Oct 26, 2008 | Cameras
Camera only dowloads half the pictures on memory card
I know some of my cameras have a 'on board memory' and chip. Most likly the desired pictures are there, or the memory card conection (in the camera) is not making a full connection. can you clean the contacts?
Apr 21, 2008 | HP Photosmart 635 Digital Camera
HP E427 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
