Question about Sanyo DP32746 32 in. LCD Television
New tv DP26649 followed instruc. 1-4, will not go to #5 (menu)???
Hooked up to cable only.  Don't know what else to do. have plugged and unplugged and reconnected.??? Help!
Thanks for your mail.  As it turns out, my new TV does not have a proper "setup." The customer service rep in India says their "tech" people will call me on Monday or Tuesday.  We'll see.  If not, I'll probably return it and buy a different one.
Thanks, Dehliarock
Posted on Apr 19, 2009
My HDMI port 1 will not work tv says no signal is found. can I fix this are is it under warranty are recall.
Most likely bad HDMI cable. I know they look fine as the day you bought them but it is a good possibility.
Nov 08, 2014 | Sanyo DP26649 26 in. TV
Tv2 remote not working tv1 must be on
It sounds like the RCA cable is plugged into TV 2 ports on the back of the receiver.
Depending upon your receiver, towards the center on the back of the receiver, you have 3 rows of colored (2 - Red, White, and Yellow; 1 - Green, Blue, Red). The RCA for TV 1 should go in the middle row. Please let me know if you have further problems. Thanks.
Dec 16, 2011 | DISH Network IR Remote Control
The DP26649 model TV has three inputs; video one (which is fine and has all color and everything), video 2 (if you plug them in certain ones the best i can get is full sound and all but its black and...
OK, here is the breakdown on whet you are doing wrong.
Video 1 - Composite -
Video - Yellow
White - Audio In - Right
Red - Audio in - Left
Video 2 - Components - HD - RGB = Red, Green, Blue
Video -
Red - Red Colors
Green - Green Colors
Blue - Blue Colors
Your GameCube will only work on Video 1, unless you buy an HD (Component cable). You will need to buy HD cables for your device connected to Video 1 to work on video 2. I will assume it is a DVD player. This is a high definition cable to produce a better picture. Let me know if you do not completely understand
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 06, 2011 | Televison & Video
I am hooked up via VGA and have the lime green cable hooked up to my tv and the back of my computer but still no sound.
It sounds like you plugged into the TV headphone jack. Unplug it on the TV end so you do not damage anything.
You need to get a mini-DIN to RCA stereo connector. It will have a connector that fits your PC on one end in the lime green audio jack(mini-DIN), and the other end will have two RCA connectors- one white (left) and one red (right) that plug into AUDIO IN on your set. Make sure you follow your TV manual or menu as to making sure the right audio input is used with VGA, and it should work correctly.
Feb 18, 2011 | HP Computers & Internet
LCD TV is hooked thru cable box. When you use the
Try this (may not work):
1. UNPLUG power from TV at wall outlet.
2. Turn ON the TV (with no power cable plugged in).
3. Plug power cable back in (at wall outlet)
4. Turn ON TV (don't use remote this time).
Hope this works!
Sep 03, 2009 | Televison & Video
Can't get menu button to work on the remote
have you tried pressing the menu button on the tv itself?
May 23, 2009 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Connecting antenna -- No Signal
Hi Shelly_Eddie,
Here are a couple of things to try:
Is the TV set to antenna or cable? Use the menu settings
Be sure a wire end is not bent outside of connection, i.e. coaxial cable wires sometimes bend or hide back into the sleeve.
Reset the TV and do a channel scan, unplug and see what happens.
Let me know how you make out. Good luck.
Paul
My Website
Jan 28, 2009 | TruTech PVS31170S1W 17 in. LCD Television
Sony connectivity
OK, here are info...
first unplug TV and dvd recorder from AC outlet and put hdmi cable as follows...
at rear side of TV, you have 2 hdmi inputs, hook hdmi cable in any one of them and other end of hdmi cable will be hooked in hdmi out of dvd recorder rear side.
Now, plug both units in AC outlet and power up, go to TV menu > hdmi setup > and perform device list update.
TV will recognize dvd recorder and you will see dvd recorder logo screen.
Let me know if you need further info / help.
Dec 23, 2008 | Televison & Video
Sanyo DP32746 32 in. LCD Television Logo
504 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
