Question about GE Nautilus 24" Built-in Dishwasher
I need to order a control cycle knob for my 2001 dishwasher
I am trying to locate a control knob for a Nautilus dishwasher purchased in 2001
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 7 Answers
Try this site, if you live in a large enough center you may have a store in your area. It's a great resourse site, type in your model number, has exploded views of your machine.
http://www.reliableparts.ca/
Posted on Apr 18, 2009
Door latch
The safety latch needs adjustment or is loose or worn out if you open the door on door side top you would be able to feel the the safety switch with your finger click on and off it should click very easy if not replace it make sure Dw is off or disconnected.good luck
Oct 14, 2013 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus dishwasher won't continue through cycle unless pressure is applied on door.
Hi, In reading about your dw problem, you are in need of a complete door switch assembly. You will need the full model number, and then find your nearest ge supply house to purchase the part. Hope this helps.
Jan 20, 2011 | GE Nautilus 24" Built-in Dishwasher
Need part# of door seal gasket for GE Nautilus GSD4100J00BB
Enter your model # at www.appliancehelponline.com this is the part # AP3798079
The part is in stock and all parts come with installation instructions.
Jul 12, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwasher won't cycle
Sounds like you need a new timer. Costs about $50 - $60. I had the same problem. The knob now turns. Hope this helps.
May 18, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus detergent cap will not open
Sometimes these get gunked up and need to be coaxed....so take a butter knife...insert it in the edge of the dispenser tray...pry gently...all the while turning the timer control knob...it should pop open at one point if not try a little more pressure...and once open .clean thoroughly..if it persists you may have a timer or control panel issue...also use factory recommended soaps...
I hope this helps...Good Luck and Good day....thank you for rating my effort.....The Fang.
Mar 14, 2009 | GE Nautilus 24" Built-in Dishwasher
GE dishwasher model # GSD2200Z02AD
yep you need a new timer part. on your search engine type in ge dishwasher model number then scroll down to find timer part number order it only if your can take broken one out if u cant then u need to call repairman.
May 13, 2017 | Dishwashers
Dishwasher knob is stuck
dont turn the knob counter clockwise it could damage timer try prying the knob off it could be shoved in to tight
Dec 13, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Ge nautilus dishwasher
Check inlet valves as if you have 2, it may fill using 2 inlets (hot & cold) but only rinse on using 1 ((cold only). So if the cold inlet is faulty, then you will only notice on the rinse. If thats not it then chances are it is the controller unit. regards
Jul 22, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus 24" Built-in Dishwasher Logo
101 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
