Question about GE JGRP17 Gas Single Oven
Noisy fan in Smeg oven SA398X
I want to lubricate a noisy fan in this oven. Can you show me how please?
  • kathyvichta Apr 18, 2009
    found the problem thank you for your help - in fact it was scraping on something - a piece of paper or label...
  • 640 Answers
Does the fan sound like a squeling or rumbling?Is the fan blade itself scraping on something?
Posted on Apr 18, 2009
  • anthony james
    anthony james Apr 27, 2009
    I think you should have givin me a fix ya rating!!!
  • June Blagdon
    June Blagdon Sep 15, 2013
    It's sqweeling very loud
Noisy fan and no heat
Kitchen aid is made by Whirlpool. There is a very good chance the then thermal fuse on the back of the oven has tripped. Whirlpools are very prone to this fuse tripping after a clean cycle. The noisy fan is just that a noisy fan it will probably need replacing. I have replace a couple of them over the years. When you pull the oven out to replace the thermal fuse replace the fan motor at the same tiome.
May 06, 2014 | KitchenAid KEBC207 Electric Double Oven
Why is our double oven fan so noisy?
u may need to first check if the fan is not impeeded by debris and oil build up etc. or have a broken impeller
Apr 30, 2014 | Whirlpool RBD305PD Electric Double Oven
Noisy fan
Only graphite lubricants are heat resistant. The fan could be worn out, bearings just well done. (oven humor).
Nov 28, 2013 | Ovens
Oven fan working. just no heat.
Most common problem will be a faulty oven element. Also check the wiring at the oven element terminals, it could be burnt off.
Feb 17, 2011 | Smeg SE280X Stainless Steel Electric...
Why is the fan so noisy?
If the fan is noisy, then it is probably due to worn bearings, or possibly worn or loose fan blade/s
In my experience it it is usually due to worn bearings.
The only guaranteed cur is to replace the fan motor.
Dec 02, 2010 | Baumatic B187 Stainless Steel Electric...
Creda Cordialle fan assisted oven is so noisy what can I do?
If it is the fan that is noisy, check for loose fan or the fan blades catching the cover, if all o/k, then it will probably be a worn fan bearing, only solution would be to replace the fan motor.
Nov 07, 2010 | Hotpoint Ovens
I have a Smeg SUK80MFX oven. When the oven is on the fan is very noisy. How difficult is it to replace the fan motor ?
Not too difficult, but you will need to remove the back of the oven from behind to get to change the fan.
Then its a case of disconnecting the wires, unbolting the fan, fitting the new one and reconnecting.
Remember to turn off the power bfore starting work.
Feb 08, 2010 | Smeg Ovens
Very noisy fan
Hi
you need to replace the fan as this will be the cooling fan which cools the oven down. and can not be disconneted .
regards
Mar 21, 2009 | Kenmore Ovens
Zanuisi top oven making noise
Yes , there is a cooling fan located at the top of the oven
It could be the fan blades catching, or a noisy fan bearing.
You would have to access it by removing the top oven cover to check., and yes it could be as a result of having it cleaned.
Plz rate my solution.
Thanks.
Dec 31, 2008 | Zanussi ZDF490 Electric Double Oven
GE JGRP17 Gas Single Oven Logo
1,052 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
