Question about Samsung RS2534 Side by Side Refrigerator
Small fan inside freezer noa working
Fan in freezer not working
Frigidaire side by side freezer at 22 degrees
Posted on Sep 24, 2011
  • Samsung Master
  • 43,501 Answers
Posted on Aug 12, 2010
Freezer works but fridge doesn't for Doc Henn. I couldn't see your video but more common reason for this would be the small fan usualy behind the inside back panel of the fridge. The freezer is the pa
Check to make sure the light in the fridge shuts off when the door is closed. You'd be surprised how much heat is given off by that light. If it stays on either take it out or replace the switch.
Apr 02, 2013 | Refrigerators
Side by side freezer is working but the refrigerator is not
The freezer is the only section that actually produces cold in a refrigerator. If you open the freezer door can you hear a fan running blowing the air around inside the freezer? This fan is located behind the rear panel on the inside rear wall of the freezer. If you cannot hear the fan running it is either not working or has a defrost issue which is when you remove the rear panel to check the evaporator fan motor you would see the evaporator coil. If the coil had any build up of ice on it this would have to be defrosted with a hair dryer and message me back if you find this and I will tell you how to test the defrost thermostat, the defrost heater, or the defrost timer or adaptive control in some units. Following that you assure that the fan is working you would then go to the rear upper small door located inside your refrigerator and check the diffuser which is the small door that opens and closes letting the cold air inside of the refrigerator. There is also a thermostat control in the ceiling of the refrigerator that controls this door as well. You would first remove the diffuser and assure there is no ice build up and that the small door does open and close if it does not then replace the diffuser.If you have any further questions message me back. Please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks
Rick
Aug 18, 2011 | GE Refrigerators
Motor in the backs works lights works small fan inside the cool side is not working when pluged in problem will not cool
the fan in the freezer is supposed to circulate the air through out the entire box both ref/freezer. If you take back wall off the freezer and their is frost build up, the compressor and all associated parts that make it cold are working fine but that fan isn't blowing the air and the fan needs to be replaced.
Gene
Aug 06, 2011 | Amana Refrigerators
The fan on my true t 23f does not run. i check it is not getting power is there a fuzz or capacitor for this thanks
Are you talking about the fan inside the freezer? If yes, check the following items. The door has a switch that turns the lights off when the door closes, it also turns the fan off when you open the door. If it isn't working right the fan won't come on. There is also a round temperature senser on the coil inside the freezer called a "clickson" that keeps the fan from coming on until the coils are below 20 degrees, it may be bad. If you are low on freon, your coils may not be getting cold enough to trip the clickson. Feel of the small copper line going from the compressor to the coils on the outside of the freezer. It should be almost hot enough to burn your skin if you have enough freon. One other thing to check is the defrost timer. It is a box about 4 inches wide and 8 inches tall with a door on the front of it. Check the connections inside to be sure you are getting power through to the fan. Let me know how it turns out.
Oct 04, 2010 | True 23 cu. ft. / 651 liter Commercial...
I turned the power on my freezer as now we decided to use it , before it was working fine it became very hot inside and the fan on the top didnot start?
Too many things can go wrong, but try this first, The fan on the top must be turning got the unit to work. Sometimes when a unit sits up for a while the fan bearings freeze up. Try trurning the fan with your hand of a screwdriver if it has a shroud around the fan. It may start moving and ususally when it does it will be arright after that. The inside will be hot because it will go into a defrost cycle 3 or 4 times a day and that puts a lot of heat inside the unit. Also the door frames are heated. Check to see if the compressor is running. If it is the small copper line going over tt the fan will be very hot. If not its not running. Co to start with clean the radiator coils on the outside and make sure the fan by the compressor is running.
Sep 17, 2010 | Traulsen 24.2 cu. ft. / 685 liter...
Refridgerator not cold but freezer working fine
okay this is what you check for, is your freezer back panel covered with ice, if it is then take the panel off and check your heaters for continuity and look at your bimetal thermastat.
another checking point is do you hear the fan running, if not then you need to replace evaporator fan.
Nov 11, 2009 | Amana ABB1927DE Bottom Freezer...
MY REFRIGERATOR IS NOT COOL PROPERLY, I HAVE SET THE TEMP. TO 8, BUT THE INSIDE TEMP. ONLY 56F. THE FREEZER IS OK
There is a small fan which moves the cold air from the freezer side to the refrigerator side. Make sure that this fan is working. They are easy to replace; however, the inside panels of the refrigerator must be removed to get to them.
Oct 09, 2009 | Maytag MZD2766GES Side by Side...
Hello, my fridge is not cooling well, but my freezer is working fine, can you identify the problem? There is no ice jam where the cool air comes from freezer to the fridge.
Can you see the coil in the freezer? It may be located behind a panel accessible from inside the freezer. Even though the air duct is clear if the self defrost is not thawing the coil daily it will turn into a block of ice and stop the air flow from the small fan. The other option would be the small fan motor stopped working. Either way its an easy fix in most cases and parts for either job should be under $50.
Sep 15, 2009 | Maytag Refrigerators
Temp inside fridge is 46degrees. Besides
46 degrees is still below normal room temperature so it seems that the unit is cooling....you do not mention whether it is 46 degrees in both the freezer and the food compartments.....if the freezer is still cold...say below freezing or near zero but it is hot (46) in the other part of the refrigerator then there are probably 2 possibilities:
1. The small fan inside the freezer may be stuck and not spinning...they seem to go bad or at least stop spinning regularly on many freezer compartments. For most designs the fan must be running to circulate the cold air inside the freezer and also send some of the cold air over to the normal food compartment. When these fans shaft get stuck they will often emit a high pitched noise if they are able to turn at all. Of course if not turning t all then there is no sound. Determine if the fan is working....if not you will probably need to replace it and problem fixed. If the fan is working then look at the design of the plastic leavers etc inside the unit that control baffles between the freezer and food compartments. It may be a simple matter of sliding one of these controls to make it colder where the food is stored. some of them also have an electronic control for this so look for that knob and turn it to colder...not the actual refrigerator thermostat but one that controls what they call "balance" between the freezer and food areas.
Aug 21, 2009 | GE Refrigerators
Kenmore model 66792 bottom freezer
Hi , check at the back if can find small motor the infeller is inside /if small motor hamming infeller inside are full of ice , let the timer rotate manually hear cracking of ice smelling like burning , that the hot coil burning, if does not burning coil has problem.
Jan 16, 2008 | Kenmore 62832 / 62834 / 62839 Bottom...
Samsung RS2534 Side by Side Refrigerator Logo
184 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
