Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
I have a kenmore elite and none of my dishes are coming out clean
The upper shelf is especially dirty.....does the dishwasher have a trap that needs to be cleaned or what Please help I hate rewashing everything after I run the dishwasher !!!
  • 1 more comment
  • ventipeb Apr 18, 2009
    thank u will check this out
    Novelist:
  • 108 Answers
Well, if the motor is moving, try adding a half gallon of /hot/ water before you start the cycle (just pour a saucepan full directly into the dishwasher). If that sounds like it is doing a lot more "blasting" than it was before- you probably need a new water inlet valve, or perhaps to take your water inlet valve off and try to clean out the screen. Problem being, you arent getting enough water into the washer before it starts washing.
It is located at the front of the machine behind the panel under the door.. but as a check, make sure that the valve under the sink that sends water to the dishwasher is all the way open, as this can cause the same problem.
If you do decide to remove the valve, be sure to cut the power at the breaker, or unplug the dishwasher, and turn off the water valve under the sink.
Posted on Apr 18, 2009
On my Kenmore model 665.13489K900, it does not clean well and appears to have a problem with getting or circulating water inside to all areas, especially the top shelf.
Check the center wash arm assembly. If the center wash arm isn't getting water, all of the dishes in the upper rack will come out dirty. Check to be sure the center wash arm assembly is mating properly with the water supply nozzle in the back of the dishwasher. Also check to be sure the little holes in the center wash arm aren't clogged or blocked. * Run empty cycle using vinegar and baking soda lime scale problem will resolve.
Nov 13, 2013 | Kenmore 15912 Built-in Dishwasher
My Kenmore Elite dishwasher leaves soapy residue on the dishes leaving them looking dirty., especially in the area of the soap dispencer. What can I do to resolve this problem?
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Aug 16, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore Elite Dishwasher leaving crud on dishes
yes it is under warranty so call whomever sears i imagine and raise hell you bought it in good faith so tell them to fix it right or replace it with a new one.if Sears they are pretty good re complaints so get on the phone and get it done good luck
Dec 12, 2009 | Kenmore Dishwashers
Kenmore Dishwasher not cleaning dishes - especially top rack.
put a pump kit in the dishwasher..and the water coming up is a house drain problem
Aug 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite dishwasher 655.16463300 not cleaning dishes
The inlet screen is at the bottom of the unit. Clean it out and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 08, 2009 | Kenmore 24 in. 16463 Built-in Dishwasher
Kenmore dishwasher not cleaning properly
Look in the inside for any screen that would be easily removed, some dishwashers have a self cleaning filter so you may not find it. I have a lot of other tips for you if your dishwasher is not cleaning so check it out.
http://tclaundryrepair.com/dishwasher
Feb 17, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishes on top rack don't get clean
The following suggestions will greatly enhance the ability of your dishwasher to clean all of the dishes thoroughly:
1. Rinse all of the food off of the dishes before you put them in the dishwasher.
2. Run the hot water into the sink until it is as hot as it gets before you start the dishwasher.
3. Do not pack the dishes into the dishwasher, just put in a reasonable number without crowding or stacking them on either shelf.
4. Pull the top shelf all the way out to be sure that the water connection at the rear of the top shelf is connected. Sometimes, this connector comes disconnected preventing the water from entering the top spray assembly.
THese things should make a huge difference.
Good luck with this and please rate my answer. Thanks. Joe
Feb 03, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Dishwasher is not washing dishes.
Make sure your water is at least 120 degrees and change to a dishwasher detergent with a water softener and a rinse aid in it.
Jan 31, 2009 | Kenmore 24 in. 17032 Built-in Dishwasher
Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
not a dumb question,
is the bottom dishes coming out clean? there is a chopper that breaks and will trap food and not clean the top rack.it is not easy to replace.but not impossible.
Oct 23, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishes not getting clean
brittgee, there has been a number of service flashes on this model. One that has to do with the upper spray arm assy. Complaint is poor washability; gritty glasses, food redeposited on glasses, especially in the corners. They redesigned the upper spray arm to improve water spray to all corners of the upper rack. The new part number is 8269022. They also redesigned the third level spinner for more consistant rotation and better washability. This was also under a service flash. Part number.8193768. Other reasons for poor wash would be; low water temperature, rinse aid disp. not working, loading etc. Catriver...post back.
Nov 25, 2006 | Kenmore 24 in. 15933 Built-in Dishwasher
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
243 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
